How to check configuration on a modem
  • ricosavy
    • Jul 2012
    • 457
    • united states
    It is a model 3049c zoom v.92/v.90 trying to figure how to get to configuration settings.
    • 31256
    Re: How to check configuration on a modem
    AT commands from a serial terminal.
    • ricosavy
      • Jul 2012
      • 457
      • united states
      Do you have a link on how to do this
      • ricosavy
        • Jul 2012
        • 457
        • united states
        Stj my computer seems not able to detect the modem
          • 31256
          you need the right cable,
          a serial terminal,
          and the documentation for a start
          http://www.zoomtel.com/techsupport/d...conexant.shtml
          that's the drivers / docs
          specially at the bottom - AT Command Reference Manual
          here is a terminal
          • ricosavy
            • Jul 2012
            • 457
            • united states
            Ok will install and try it will i be able to get into the bios of the modem once everything is installed.thanks stj
            • ricosavy
              • Jul 2012
              • 457
              • united states
              For some reason it can not see the detect the device on com port 3
              • ricosavy
                • Jul 2012
                • 457
                • united states
                I do not have serial port on any of my computers i am using a serial port adapter to usb
                  • 31256
                  that should work as long as it has hardware handshaking, not just tx&rx - i suspect your cable may be wrong.
                  is it a modem cable or a serial extension?
                  it may have tx and rx (pins 2 & 3) the wrong way around among others.
                  • ricosavy
                    • Jul 2012
                    • 457
                    • united states
                    You were right it was cable now i am in
                    • ricosavy
                      • Jul 2012
                      • 457
                      • united states
                      What AT command would i input in hyperterminal to either qweary the modem or determine the timeout settings for carrier and inactivity?
                      • ricosavy
                        • Jul 2012
                        • 457
                        • united states
                        Just need figure out how to do this keep getting response ok but no setting
                          • 31256
                          first use the terminal program i linked.
                          second, ati = information if i remember right.
                          read the pdf on at commands.
                          once you change them how you want, you have to save the settings with something like at&0 or something.
                          not done this shit for over a decade, but it's coming back slowly!
                          ath to hang-up the line,
                          atdt[fone-number] to lift the hook and dial (tone-dial)
                          atdp for pulse-dialing.
                          • ricosavy
                            • Jul 2012
                            • 457
                            • united states
                            I unzipped the file file it was a php file i was able to view it but how to i install that program
                            • ricosavy
                              • Jul 2012
                              • 457
                              • united states
                              This all i get
                              • ricosavy
                                • Jul 2012
                                • 457
                                • united states
                                Pic
                                • ricosavy
                                  • Jul 2012
                                  • 457
                                  • united states
                                  I downloaded the terminal that was linked but when I open it all it brings up is a bunch of code. Is there a specific way I am supposed to open it up?
                                  • SteveNielsen
                                    Retired Tech
                                    • 2327
                                    It is a windows/dos executable file. You must Run it not View it.
                                    • ricosavy
                                      • Jul 2012
                                      • 457
                                      • united states
                                      The ati did not retrieve any information am i missing something
                                      • ricosavy
                                        • Jul 2012
                                        • 457
                                        • united states
                                        On the command
                                        • RetroComputingGrotto
                                          New Toy UNI-T UTi260B - What Settings?
                                          by RetroComputingGrotto
                                          I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
                                          After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
                                          I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
                                          09-02-2025, 08:36 AM
                                          LENOVO ThinkSmart M920q Zoom Rooms i7-9700T Specification for Upgrade or Repair
                                          This specification for the LENOVO ThinkSmart M920q Zoom Rooms can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkSmart M920q Zoom Rooms boardview and ThinkSmart M920q Zoom Rooms schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 01:58 PM
                                        • dreico33
                                          TL866 II Plus Check ID Error on various IC
                                          by dreico33
                                          Hellow guys , i really need your help here.
                                          Lately i have a problem with My TL 866 II Plus programmer, and to be more specific many times on various IC ( Winbond, Gigadevice Mx) i get Check ID Error while i am trying to read the IC. Has already been detected without any kind of problem, but the only to read them is to uncheck every time the "Check ID " option. After that i can read it erase it and re-program it only to get another error at then end saying that can not verify the programing went well so i have program failed. So i am trying to find out what is going on? I...
                                          11-04-2024, 03:13 PM
                                        • hasel17
                                          CH341a can erase and read but can't write and blank check
                                          by hasel17
                                          So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                                          Code:
                                          Checking for blank...
                                          (Press
                                          10-26-2023, 06:20 AM
                                        • i440bx
                                          Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
                                          by i440bx
                                          Hey there,
                                          I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
                                          The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
                                          It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
                                          As written above, I plugged in a new CMOS cell and checked...
                                          08-19-2024, 02:28 PM
