Never expected this to work
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Gigabit ethernet through 108 meters of sheilded cat 5e. was expecting at most tbase 100.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • mariushm
    • May 2011
    • 3799
    Re: Never expected this to work
    With good network cards on both ends (or good switch), it's possible.
    Years ago, I installed a FTP cat5e cable between two buildings and I know for sure it was more than 105 meters, I think it was in the range of 107-110 meters. It was working fine with no packet loss and transfers around 600-800 mbps 24/7 (students in university campus sharing movies and music between them)
      • 31293
      got any packetloss?
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5045
        • US
        I think 100M is 'safe' not strict
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          Try making 10base2 (thin ethernet coax) work over 1000'. Lots of packet loss but it did work and that was on a repeated (not switched) network with about 300 nodes. Things are only impossible until they are tried.
          • DarkInferno
            • Feb 2015
            • 23
            I was certifying the structured cabling at a collage a few years back and from one of the art studio pc labs that every point was over 200m with UTP... It did 'work' but the switch wasn't happy about it. Nor were they when we pointed out it at least needed re-routing to a nearer cab, taking a more sensible route, and hoping it came into spec, or possibly installing a small cab in the lab.
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              Ok from what I understand cat 5e is good for gigabit to 100 meters
              My pc
              • mariushm
                • May 2011
                • 3799
                The maximum length allowed by standards is 105 meters. Wikipedia says 100 meters but I know I remember it as 105 meters.
                There is some note in the standard ( ) saying something about 5 meters not included for patch cords and internal cabling but I'm not curious and patient enough to read the whole damn thing.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Cat5e is rated for 1Gbps at up to 100 meters including patch cables on both ends.
                  So if you don't have patch cables it will improve the signal.
                  And you say that you used shielded cables, which further improves things.
                  http://en.wikipedia.org/wiki/Categor...egory_5_vs._5e
                  • joshnz
                    • Feb 2011
                    • 969
                    • New Zealand
                    Doesn't sound as impresive now only 3 meters over length.
                    For some reason I had in my mind 30m for cat 5
                    aNd needed cat 6 for gigabit at 30m +
                    I think I was confusing cat 5e specs with cat 5.
                    Not looked it up.
                    Also this is a poe cable.
                    My pc
                      • 31293
                      spec's dont mean much when they keep improving the line-driver in the chipsets.
                      • hollox123
                        ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                        by hollox123
                        Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                        1. Laptop keyboard doesn't work
                        2. The backlight on the laptop keyboard doesn't work
                        3. The x2 side LEDs (red) on the laptop don't work
                        The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                        I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                        But I am strongly aiming that it is somehow a BIOS-related problem,...
                        05-11-2025, 08:05 AM
                      • resistor83
                        lenovo 330s-15ikb, led num lock key always on and numbers don't work
                        by resistor83
                        hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
                        I tried updating the bios but the problem remains
                        https://s...
                        05-29-2025, 08:06 AM
                        DYMO Rhino 5200 Industrial Label Maker that the backlight does not work any ideas
                        I just bought a used one for a decent price for a used device it prints very nicely and clean and clearly so I am not going to complain about it but I would like to get it working again anyone have any suggestions on how to repair this back light
                        If I can not get the controller to work properly then I will probably have an external power supply for the backlight because it is difficult to see the screen without out it
                        One —>the LEDs might be bad
                        Two —> the buck converter or regular might be bad
                        Three —> the controller might not...
                        08-08-2023, 05:12 PM
                      • vf fa
                        EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
                        by vf fa
                        Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
                        I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
                        So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
                        01-31-2024, 01:40 PM
                      • Rhaverz
                        My touchpad doesn't work, Asus laptop motherboard X455LJ REV 3.1
                        by Rhaverz
                        Good afternoon friends
                        I have an Asus laptop motherboard X455LJ REV 3.1 that the touch pad does not work, I was trying to check if something was wrong at the drive level but I did all the necessary installations and the touchpad still does not work.
                        I have a feeling that the error goes more to the board level because the touchpad is not recognized by the device manager and it is supposed that even if it does not work correctly it has to be detected.
                        I even checked that the data bus made a connection between the touchpad and the motherboard and everything...
                        03-30-2023, 03:56 PM
