help to config a secure wep
  • ivtec
    • Dec 2008
    • 1967
    Hi guys;i want to make a wireless wap secure,i connected a Toshiba WRC_1000 to ComCast TG862 main router but some linux ops pc wont connect to the secure wi-fi so i connected my own router and i went in the WRC 1000 but need instructions on how to make it secure?
    This page has the parameters to configure the Wireless LAN Security interface.
    can you in detail tell me what #'s and lettersi should put in the boxes
    802.1x
    802.1x Not Used Used
    WEP
    WEP Mode Disable 64 bits 128 bits
    Access Control
    MAC Address Access Control Disable Enable
    Allow ListComma separation ( Ex. 11 : 22 : 33 : 44 : 55 : 66 , aa : bb : cc : dd : ee : ff )
    • 30962
    Re: help to config a secure wep
    i can break WEP in about 7 seconds, you need WPA
    and a big password that is not just a word or string of numbers.
    • ddscentral
      • Mar 2008
      • 151
      • Lithuania, EU
      There's no such thing as secure WEP.
      You need to use WPA or, if your router is only supports WEP, get a proper router which supports WPA.
      • Ramee
        • Jul 2014
        • 218
        • Israel
        Hey mate
        I need to open wpa/wpa2 but can't find the proper devices, any suggestion?
          • 30962
          if by open you mean break,
          the only real weakness on wpa is dictionary attacks or bruteforce using scaled cluster computing using ps3's or gpu's
          start here - in the forums.
          http://www.aircrack-ng.org/doku.php
          • Ramee
            • Jul 2014
            • 218
            • Israel
            I got Beini but looks like the dictionary is empty.
            Thanks for the info.
            • diif
              • Feb 2014
              • 6978
              • England
              Have a look at this http://www.blackmoreops.com/2014/03/...yrit-cowpatty/
              Also if WPS is enabled on the AP then that is easier to crack than trying to bruteforce the wpa/wpa2 password.
              • ddscentral
                • Mar 2008
                • 151
                • Lithuania, EU
                That depends on the router. Some routers have countermeasures against WPS brute-force attack.
                  • 30962
                  most do, i'v tried!
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Ahh, it was a while ago i checked. Seems Virgin became aware and pushed out a patch to their SuperHubs in June.
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      Tkip on wpa has security issues that can let it be cracked, though not nearly as easily wep
                      use WPA/2 AES
                      • junktv
                        • Nov 2010
                        • 3063
                        Cracked cracked and cracked. NSA is in your router stealing your packets.
                        Make a long random passphase and forget to change log in or shut down remote log in.
                        • mhandley92
                          • Jan 2015
                          The easiest way to secure WEP is to not use it! Please use WPA/2 AES at least.
                          • ivtec
                            • Dec 2008
                            • 1967
                            hI mhanddley92: can you teach how to do a secure WEP that can be used on Toshiba WRC1000 wireless router that i have connected to Comcast TG862 Xfinity router to use
                            with my old wireless Linux and win Xp computers,
                            I've been using it without secure WEP and i don't want people next to my Apartment to use my wireless,
                            the Xfiniy TG862 router wireless only works with win7 OPS or very recent new hardware PCs with linux or win xp
                            This is what i get when i enter the Toshiba WRC1000 WEP secure wireless
                            menu.Thanks in advance.
                            802.1x
                            WEP
                            Access Control
                            • selldoor
                              Slow Learner
                              • 7870
                              Did you see this
                              http://forums.computers.toshiba-euro...?threadID=8457
                              suggests you cannot set it up wirelessly you need to set it up using an ethernet cable.
                              • ivtec
                                • Dec 2008
                                • 1967
                                Originally posted by selldoor
                                Did you see this
                                Thanks selldoor: i'll give it a try.
                                • ivtec
                                  • Dec 2008
                                  • 1967
                                  Did you see this
                                  Well at last i could do it and it was easier than i thought,and for doing it, once more Google is my friend; just red this article;
                                  http://support.apple.com/en-us/HT1344
                                  • AFajitas
                                    • 183
                                    If you insist on using WEP, then at least use MAC address filtering. That would make it somewhat secure.
                                      • 30962
                                      no it wouldnt.
                                      a wifi scanner will give the mac's of any connecting clients.
                                      a single command will then change the mac of the attackers nic.
                                      • AFajitas
                                        • 183
                                        Didn't realize it was so easy to break, but it seems you are correct after a quick Google search. Thanks.
                                        • DynaxSC
                                          ASROCK Z270 GAMING-ITX/AC - IR35201 - NEED THE VRM CONFIG FILES
                                          by DynaxSC
                                          I have an ASROCK Z270 GAMING-ITX/AC motherboard with a fried VCORE controller IR35201 (International Rectifier, currently Infineon).
                                          This chip is unfortunately programmable, so after replacing the chip, it needs to be programmed with a config file, which I do not have, as the chips is not readable any more (total short on power supply pin).
                                          Some of you maybe know, it is possible to read out the config file from a board with a working chip using the USB005 I2C adapter and IR/Infineon software called PowIRCenter. The software is available freely at Infinion...
                                          02-10-2025, 04:52 PM
                                        • ktcar214
                                          Need help for HP ProBook 445R G6 Secure boot key removal from BIOS dump
                                          by ktcar214
                                          Hello.
                                          I tried to add a custom secure boot key (for secure booting Linux) to my bios, but after this, my laptop bricked. After adding secure boot key (via PowerShell) and enabling secure boot my laptop turns on, shows HP logo, and after 5 seconds it turns off and on, and it repeats forever.
                                          My goal is to either turn off secure boot or remove my custom key from BIOS dump.
                                          I'll attach my bios dump (version R79_011700) from my bios chip 25b127dsig, my keys (PK/KEK/db), and bios dump from another HP ProBook 445R G6(I found it on this forum. URL: https://www.ba...
                                          12-07-2021, 08:57 AM
                                        • shadow666
                                          Router Xiaomi M4A Gigabit
                                          by shadow666
                                          hello
                                          i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                                          Mi Router 4A Gigabit Edition
                                          ROM CHIP is 16 MB
                                          i attached picture of motherboard​...
                                          11-30-2024, 03:49 PM
                                        • EasyGoing1
                                          UPNP, "Standards" and hardware that implements it
                                          by EasyGoing1
                                          I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                                          One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                                          So I decided to implement UPNP...
                                          07-16-2022, 07:12 PM
                                        • badcaps411
                                          Lenovo T15 gen 1 secure boot
                                          by badcaps411
                                          I have a Lenovo T15 gen 1 where I can't get the secure boot disabled. I think it is related to the security chip. The BIOS is completely free, no password or anything. The only problem is that the option to disable secure boot is grayed out. Trying to boot it, GRUB 2.02 starts and expects a certain Software. If you want to change something you need to enter a username and password. While experimenting, I was able to load the firmware from the hard drive. There I found signed files, in one also the hashed password (cracking probably not possible in lifetime). It was probably...
                                          12-08-2022, 01:00 PM
