"A Network Cable is Unplugged"
  • pentium
    • Mar 2006
    • 2778
    Re: "A Network Cable is Unplugged"
    Was streaming from twitch and youtube while connected to three IRC servers and it's been pretty quiet for the last 24 hours and everything seems to of calmed down.
    Man does bad ram do some weeeird shit.
    Find Nedry!
    Check the Vending machines!!
      master hoarder
      • May 2008
      • 12170
      #42
      Originally posted by joshnz
      Heat?
      Like I said, I don't want to troubleshoot the router in this thread. No, heat is not the problem. And both routers reboot when this happens, even though they are completely different brands and models.
      Regarding the bad cable comment - that doesn't explain why the router would reboot.
      I'm glad to see you have found the problem to your issue, pentium.
      • pentium
        • Mar 2006
        • 2778
        Actually, I'm curious. The only variable here other than the ram was the cover being off. Let me put that back on and see what happens in another 24.
        Find Nedry!
        • pentium
          • Mar 2006
          • 2778
          Another 24 hours under a full battery of regular use and still no interruptions.
          Problem solved.
          Find Nedry!
          • SeanB
            • Jun 2013
            • 41
            • South Africa
            #45
            So next time you need to run MEMtest386 for around a day to cook the ram and see if it fails.
            • RJARRRPCGP
              • Jul 2004
              • 6303
              That's definitely not a classic symptom!
              The usual symptom is a BSOD with code 0x00000050, 0x0000004E or 0x0000008E. Or a bogus file-not-found error.
              At least with a RAM slot issue, it looks common to get a file copy error when trying to reinstall Windows. Or BSOD 0x00000050. (PAGE_FAULT_IN_NON_PAGED_AREA)
              If you don't receive any of the errors I mentioned, the RAM is probably fine.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • pentium
                • Mar 2006
                • 2778
                No, I saw the page fault error but it only showed up once the backup was running. Otherwise the machine never showed any signs of a memory issue. Took five days to capture the BSOD in a state where the machine couldn't reset and I could actually see the damn problem.
                Memtest weeded out the problems to two 1gb sticks that were failing memtest in any slot. Right now I'm loping along with two Corsair 512mb DIMMs until some replacement ram shows up.
                Find Nedry!
                • pentium
                  • Mar 2006
                  • 2778
                  Son of a bitch. It's dropped out twice on me today already. Back to square 1.
                  Find Nedry!
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    #49
                    a day in the life of a network architect
                    Follow the white rabbit.
                    • pentium
                      • Mar 2006
                      • 2778
                      There's not enough alcohol in the world to make me feel better right now.
                      Find Nedry!
                      • LLLlllou
                        • May 2011
                        • 201
                        I told ya, garlic and holy water . . .
                        • tmiha71
                          • Apr 2010
                          • 130
                          #52
                          maybe some strange RAM error, but majority of hard to trace errors are due to faulty motherboard, and today that means - check caps first (if this error was not from beginning)...
                          And problem is - they, caps, could be visually good, but can make problems after some time of being stressed...
                          And memtest is tool, for testing RAM, if RAM passes all tests, with high probability, can be claimed that RAM is good - and fault is at motherboard (sometimes PSU, but motherboard if first place to look)...
                          And as so many times here repeated, CPU-vrm is first place to fix (highest load - can do all sort of nasty things to whole motherboard)...
                          • RJARRRPCGP
                            • Jul 2004
                            • 6303
                            I would check the traces to the ethernet port.
                            Arc A770 16 GB
                            • AidenGrayson
                              • Nov 2013
                              #54
                              Getting problem for the network and after checking all the system for 3-4 hours and at the end you came to know that your wire is unplugged is really messed up.No words
                              • pentium
                                • Mar 2006
                                • 2778
                                The NIC crashed again.
                                Going down for a reinstall.
                                Find Nedry!
                                • AidenGrayson
                                  • Nov 2013
                                  #56
                                  After uninstall download the new one browser don't use again that setup which you are using previously.
                                  • Patriarxis
                                    Ideapad s145-15api charging indicator LED is ON and windows shows charging (plugged in) even I have unplugged the cable
                                    by Patriarxis
                                    Hello.
                                    i have this problem with a lenovo ideapade s145-15api.
                                    The charging led stays on even when the charger is unplugged. Also in windows it shows that is charging.
                                    Do you have any idea?
                                    01-15-2025, 07:52 AM
                                  • flat-earther
                                    ASUS X54H laptop thinks it's always charging even with charger unplugged
                                    by flat-earther
                                    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                    Windows also shows ''Plugged in'' when charger is not connected.
                                    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                    If I let battery run out and say it has 3% Windows will...
                                    06-24-2025, 09:32 AM
                                  • howardc64
                                    by howardc64
                                    Problem
                                    08-04-2024, 10:36 PM
                                  • davg
                                    Home network connection problem
                                    by davg
                                    I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                                    03-06-2021, 07:13 AM
                                  • Patch2
                                    Cable Repair
                                    by Patch2
                                    I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
                                    01-02-2025, 06:04 PM
