"A Network Cable is Unplugged"
  • pentium
    • Mar 2006
    • 2778
    THIS is wildly pissing me the hell off now.
    What happens is that on a random (but still happening multiple times a day) occasion that little balloon will pop up on the taskbar.
    Half the time nothing will happen and active connections don't skip a beat. The other half of the time everything dies and disconnects and it takes a few seconds for the network interface to go back to being connected and for everything to sign back in. If however you're doing something like file transfer or a remote session that all dies and you have to start over again. If you're in a game you have to reconnect and you can forget about hosting anything....
    I've replaced EVERYTHING hardware related. I've used three different network cables (two custom made and one pre-fabricated), I've changed ports on the switch and even bypassed the switch and gone directly to the router. I've even replaced my motherboard (my last 865PE bit the dust so I bought another) as to make sure it's not a glitchy NIC. Yet after all that it persists. It worked flawlessly when I was living in Vancouver. After I was setup here with my parents again I did a fresh install of XP. THAT is when the problems started to happen. Yes I have uninstalled and reinstalled the network driver. What the hell gives??
    Find Nedry!
    Check the Vending machines!!
  • mariushm
    • May 2011
    • 3799
    Re: "A Network Cable is Unplugged"
    Check the network cable (sometimes the jacks get loose).
    Check the actual network jack on the motherboard, just in case there's some pins that no longer flex properly or maybe they're oxidized.
    • pentium
      • Mar 2006
      • 2778
      It isn't that problem this time around. I've completely eliminated that possibility with multiple cables and cards.
      I can right now wiggle the cable ends to my hearts content while doing something like speedtest or a file transfer and the connection doesn't flinch.
      Find Nedry!
      • RJARRRPCGP
        • Jul 2004
        • 6304
        It may be a old bug in XP, especially pre-SP2!
        If you changed ethernet hardware, I would get XP X32 with SP3 integrated, if using XP X32.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • pentium
          • Mar 2006
          • 2778
          Technically I never changed ethernet hardware. There might be a different revision on the new board but I've otherwise never touched it.
          I'm currently up to date on my SP3 updates though.
          You do however remind me that this time around instead of installing from a shady burned pro CD I used an authentic Pro SP2 CD so I didn't have to fight the filesystem bug (XP partitons and formats up to 120gigs and after the install you need to use Partition Magic to expand the partition to cover the full terabyte of space).
          Find Nedry!
          • Mad_Professor
            A Mech Warrior
            • Feb 2011
            • 1587
            sounds like electrical or emi interference from something, try getting a shielded cable and see if that works.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              sound like Xp is craping out.
              Follow the white rabbit.
              • pentium
                • Mar 2006
                • 2778
                We just went over that when I mentioned I tried multiple cables. The stuff I built and crimped myself came from the same spool I used when I wired my apartment in Vancouver which had three times the run length (about 80') and it never had a problem.
                Not trying to be rude but is it possible to narrow id down to a specific section of the OS? I can reinstall but I really would not be looking forward to it and if it's from the same install CD again, what if it happens again?
                Find Nedry!
                • Mad_Professor
                  A Mech Warrior
                  • Feb 2011
                  • 1587
                  yes, but is it shielded? Just because it worked in Vancouver doesn't mean it's going to have the same result everywhere. Different environments have different variables. A shielded (cat-5e or 6 STP, not UTP) cable directly to the router and machine will eliminate that interference, giving you a clean environment to work this problem out.
                  Since you're so convince that the problem is other then common sense;
                  Have you tried connecting to the modem directly?
                  Have you remove the modem leaving only router and machine connected?
                  Have you tried connecting another computer (one completely different) to eliminate faulty hardware?
                  Have you tried using a crossover cable?
                  Have you verified that you are not getting dirty power, causing switches, routers, modems to momentarily drop due to bad poco supply or a failing UPSes, those little bricks and wall warts can't handle a brownouts or surges as well as a atx power supply.
                  • pentium
                    • Mar 2006
                    • 2778
                    I've been living with this for seven months. I've tried a lot of that.
                    -My modem is built into the router so a connection to the router is the simplest way to connect.
                    -See above
                    -Yes. I have attached my Toughbook and Thinkpad to the same lines and left my IRC client connected overnight. When I get up in the morning they are still connected. Try that with the PC and it will usually drop the connection sometime during the night.
                    -I don't see what a crossover cable will do
                    -This is the ONLY machine in the house that has this problem. No other system attached to the network suffers from this problem, including a machine at the other end of the house which mainly streams videos.
                    The cable I ran from the switch to my PC is from the same spool I used to network the rest of the house and supply my old roommates with an internet connection. If this was a shielding problem I would be seeing problems all over the house and my roommates would of been breathing down my back for almost two years but I'm not seeing them. No matter what external factor I consider and change the problem remains specific to this system and this OS installation.
                    Find Nedry!
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      Move on from that outdated OS. Windows 7 (or 8) Problem Solved!!
                      • pentium
                        • Mar 2006
                        • 2778
                        Find Nedry!
                        • Heihachi_73
                          • Jun 2012
                          • 713
                          That message will only appear if the cable itself has become dislodged, is faulty/broken or if the router has crashed or reset, or has a power issue. If the net actually does go down, Windows won't even say there's an error (as you are still connected to the router).
                          I haven't had cable internet since around 1998, so I can't remember how cable modems work in this situation, whether they disconnect entirely when there's not net access or just sit there waiting for a connection to the outside world.
                          On a side note, hopefully you don't have bad caps like my old D-Link ADSL1 router did.
                          • SeanB
                            • Jun 2013
                            • 41
                            • South Africa
                            Try the simple thing of downloading a live Linux install and let it run overnight and see if the link dies during this time while doing something that draws a lot of data ( torrent client of the distro hosting the download will do as a safe legit load).
                            If not then you will probably be best off to reinstall XP, otherwise delete the drivers for the card and reinstall them again using the latest versions from the card manufacturers site. This will ensure you have no old software that can cause problems.
                            • shadow
                              • Feb 2007
                              • 732
                              Great advice. By following this you will tell if it is a software issue or a hardware issue.
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                this is almost certainly hardware!
                                btw when the derecho came through here last year and took out the power i ran on backup till time warners pole mount ups gave out.was about 9 hours.no disconnected cable notice when it went.modem lights went to acquiring downstream and stuck there.any request from the pc timed out.
                                the live linux test is the first thing i would have done if i were the o.p.
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  Then where the hell is the break?? I have performed every possible troubleshooting step possible. I've ruled out EVERYTHING. I even went out of my way to REPLACE hardware to the point I'm literally running a completely different system and a brand new run of network cable. I've reduced the number of physical network connections between the modem to the minimal possible configuration. This problem is exclusive to THIS windows install on THIS computer.
                                  You know what? Fine. I'll risk running out of valid uses of my Windows key and reinstall again and spend my weekend reinstalling and reconfiguring everything. Are you happy?
                                  Find Nedry!
                                  • Sparkey55
                                    • Jan 2010
                                    • 1523
                                    Try by-passing the switch completely. Connect the pc in question to the first network port only then reset the router and reconfigure it for that pc as master. Be sure to to set the router for port forwarding. A switch should not be used between a pc and router. switches by themselves can not handle internet traffic properly.
                                    • Mad_Professor
                                      A Mech Warrior
                                      • Feb 2011
                                      • 1587
                                      Just run a live cd of linux, like ubuntu or fedora. Also if your XP key runs out of onlines uses, just phone activate, it's not that hard. I do it all the time, takes like 10 minutes.
                                      • Mad_Professor
                                        A Mech Warrior
                                        • Feb 2011
                                        • 1587
                                        That shows how much you know about networking 101. Switches are used all over the world. Layer 2 switches are the standard and practically used in corporate, industry, residential; and managed switches can do dhcp and more, assuming you have a gateway upstream. Layer 3 are practically routers with out wan interface then you have routers.
                                        The ones that can't handle internet traffic, more like has trouble handling packets and are only used for packet capturing are layer 1 switches, known as hubs or dumb switches. These create too much congestion and should be used only for very small network deployments, or final mile setups in a big network like at a work station of 2-4 computers coming from a port on the wall going back to the layer 2 or 3 switches. Layer 1 switches, can't do anything, They are just dumb, all they do is a take a packet from any port it received on and forwards it to all remaining ports. Unlike layer 2 which receives the packet, reads the header, determines where the MAC is on the network, sends it on to correct port to the next device or computer downstream.
                                        Layer 3 are usually used to connect multiple layer 2 switches together and hook them up to a respective gateway or intranet servers.
                                        Having too many computers on a subnet causes problems for switches. You have to break up the subnet into 16-30 different parts so that congestion doesn't cause a problem. This is done by subnet masking. This is similar to cities and postal code, when a package is sorted we know exactly what belt it's sorted to based on the city in this case the subnet ip of 192.168.0.0
                                        When it gets to city then we have to break it down into postal codes which is where the subnet mask comes in like 255.255.255.0 and the house number and street, MAC:23:C5:14:08:52:8F using 192.168.0.50.
                                        To get an idea of subnet masking, here is a cheat sheet.
                                        http://www.aelius.com/njh/subnet_sheet.html
                                        Also this one is good since it shows what type of network class, like class C, B, A then just below what ip ranges can be used for subnet mask
                                        http://www.oav.net/mirrors/cidr.html
                                        But of course this is used for IPv4, it's much different on IPv6 which uses unique addresses, that integrates subnet mask into it's address.
                                        • Patriarxis
                                          Ideapad s145-15api charging indicator LED is ON and windows shows charging (plugged in) even I have unplugged the cable
                                          by Patriarxis
                                          Hello.
                                          i have this problem with a lenovo ideapade s145-15api.
                                          The charging led stays on even when the charger is unplugged. Also in windows it shows that is charging.
                                          Do you have any idea?
                                          01-15-2025, 07:52 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • davg
                                          Home network connection problem
                                          by davg
                                          I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                                          03-06-2021, 07:13 AM
                                        • Patch2
                                          Cable Repair
                                          by Patch2
                                          I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
                                          01-02-2025, 06:04 PM
                                        • japlytic
                                          Maximum speed should be marked on network ports
                                          by japlytic
                                          I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                                          One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                                          12-19-2024, 05:04 PM
