Fans in old 1U equipment
+ More Options
Posts
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    I felt a bit bad about it, but at work we scrapped about 4 Netgear 10/100 24-port rackmount switches... why? the fans were either stopped completely or made loud grinding noises and only spun at like 5 RPM
    Anyway, this evening my uncle gave me a server rack for my closet and a Linksys EFAH24 hub.
    Beside the fact that I have no screws to attach my server to the rack I'm pretty happy about it...
    Anyway, on the hub, the fan is bad it won't go at all, then after a few minutes it'll make a terrible noise and start spinning
    Thing is, the primary capacitor is quite bulged (probably because of the fan failure) but since the thing still works I'm ignoring it!
    Now, why oh why do these fans always die?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Fans in old 1U equipment
    high RPMs + long time = dried lube= failed fans.
    better fix that bulged cap if you want it to last... it works for now... but probably not for too awful long...
    sigpic
    (Insert witty quote here)
    • c_hegge
      • Sep 2009
      • 5219
      What brand is the fan? If it's a cheap off-brand then that would explain it
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        The fans in the Netgears and also my Linksys are all Sunon
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Sunon makes good fans. However, those are high RPM fans so it's obvious they'll catch more dust and fail faster than slower, quieter ones.
          A working TV? How boring!
          • c_hegge
            • Sep 2009
            • 5219
            Their ball and Maglev bearing models are good, but their sleeve bearing fans are pure junk IMO. I often see 80mm and 92mm models with locked bearings after 3-4 years of occasional use running at low speeds.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              i replace the 40mm ball bearing ones every few years in a common brand of cnc box.
              the psu is the size of a pack of ciggaretes.fan stops psu go boom!
              none go more than 3 years.they warn you by hissing.if it stops hissing it locked up.bring it in now!
              • lti
                • May 2011
                • 2557
                Sunon fans always made more noise and vibration than any other brand of fans. I have a 50mm Sunon fan that sounds like the bearings were never lubricated. Also, the Maglev fans still use ball or "Vapo" bearings and aren't any better than Sunon's other fans. However, the DR-Maglev fans aren't bad. I have one in a power supply, and it produces a normal level of noise and vibration. I don't know how long it will last.
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  If this is something to get exicted about, I'd infer that Sunon sucks
                  • smason
                    • 1652
                    Wow, really? After all your time here at Badcaps, you're willing to leave a bad cap in a device that you're using?
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      Actually I unplugged the hub and am not using it at the moment; if I ever do use it for anything serious I will order a new capacitor. Thing is, it's a short stumpy one so all the ones I've rescued from old PSUs wouldn't fit...
                      • mathog
                        • Mar 2010
                        • 2655
                        Are you kidding??? Replacement fans cost on the order of $10 each,, the replacement switches are going to be a lot more than that. Admittedly I have seen some peculiar fans in rack mounted network equipment. However most of the time it is just a standard 2 or 3 pin fan connector powering a 40mm fan. Did they at least open the units to see what kind of fans they were before junking them?
                        • NxB
                          • Feb 2009
                          • 1595
                          Its a company they always buy new.
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            I opened them, inspected them, tested them for power on, cleaned them, set them aside a week while contemplating ending up with them, then tossed them while cleaning the next Saturday.
                            But I can't end up with EVERYTHING, and the guy who puts stuff on eBay didn't want to deal with them.
                            And yes they were standard 40mm Sunon fans.
                              master hoarder
                              • May 2008
                              • 12175
                              Once you do it a few times, it takes under 10 minutes to take apart, clean, lube, and put back together a fan like that. And by clean, I mean brand-new-looking type of clean. Get to it already!
                              Lubed sleeve bearing fans last about 1 to 2 years for me, depending on their size. Never had problem with ball bearing fans and I've seen only a few get stuck from too much dust.
                              A bulged cap on the primary of a PSU can make a lot of things go wrong in the PSU - don't use it like that until you get it replaced. Like kc8adu noted, the PSUs will usually go bang if this is ignored. I've worked on one like that myself. Everything inside it was cooked. The plastic cap on the top of the primary capacitor turned into dust when I touched it - it was that cooked.
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                Well FUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                                I'm really pissed off right now.
                                Why? Because I made the "seized" fan in that Linksys switch as good as new with a drop of some random oil from the bathroom.
                                OMG now I am SO PISSED that we scrapped all those Netgear switches
                                I could have got them for about $1 each, lubed the fans,
                                and had some REALLY NICE 10/100 switches.
                                But no, I just throw them in the box and now they're a goner.
                                Man I act so STUPID sometimes
                                But honestly, I couldn't do that with everything because I ran out of space months ago and now my room is piles of PSUs and computers, etc.
                                I try to make up for the fact that I miss having my dad around by buying all sorts of random crap (laptops, tablets, etc.) and look where it got me... nowhere...
                                Sorry I'm a bit over-obsessed about some stupid worthless old networking equipment but I had a lousy day.
                                but I still feel bad about those switches
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  Re-lubed fans don't usually last longer than a couple of weeks before they get noisy again.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    depends on how you go about it.
                                    I recently re-did a fan by popping the rubber plug/bung and slowly packing the fan with white lithium grease... for slow fans (in this case, a PWM 90mm), it works great.
                                    for faster fans, I hear a drop of ATF via an oil can works well... having an oil can filled with ATF is good anyway; atf is cheap and is a good general purpose lube... I use it as chain lube (beats spray crap), bike gear lube (for 3 speed internal hubs), cutting oil, and generic lube.
                                    if you use tri-flo (too thin), sewing machine oil (also too thin), or god forbid wd40 (which is a water displacer, NOT a lubricant per se), yeah, the fan will return with noise. also don't be a noob and use vegtable oil like I did once... what a gooey mess.
                                    sigpic
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      i used rancid olive oil once... quite a mess...
                                      nah i have no idea what kind of oil it was lol
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        Well I'm using it in a non-critical part of my network and am going to see how long it lasts. Since I couldn't put the label back on I'm just leaving it open, which may or may not be a problem given that the fan is sideways.
                                        Oh well, we'll see, eh?
                                        • emil_t
                                          RTX3090 working fine but fans not spinning
                                          by emil_t
                                          Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                          04-12-2024, 06:54 AM
                                        • eccerr0r
                                          Server equipment... slow boot?
                                          by eccerr0r
                                          Is it normal for servers to take an eon to boot?
                                          I have two "server class" machines/boards now, with ECC RAM. Both take an eon and a half to boot.
                                          The specific one I have is a Supermicro board with an atom c2550 chip in it. It takes forever, almost a minute before it initializes vga if at all (for some reason it doesn't even init the onboard VGA port, I have to stick in a PCIe card). Machine almost seems dead before then.
                                          The other machine is an Itanium machine, likewise does not init VGA until at least a few minutes after power up.
                                          02-19-2023, 06:02 PM
                                        • omega
                                          Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                                          by omega
                                          Hello all,
                                          as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                                          Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                                          02-09-2024, 03:34 PM
                                          Rack mounted ECB-A10H plus several buck converters set to different voltages with a 12 and 24 volt switching power supply
                                          Last night when I was doing a Google search on the internet I was searching for empty rack mounted enclosures and I found this website where I found some 5u enclosures for a reasonable price these enclosures are being discontinued so for this reason until I place an order I not going to post the website link because I need to make sure that we are working Saturday if we are going to work Saturday then I will place the order tonight and I will post the website for them
                                          I want to reuse my rack mount cart that I have not been using sense I have do my projects in my new shed but I going...
                                          09-13-2024, 06:47 AM
                                        • b-slayer
                                          Asus Strix-G15-G513RM fans don't work
                                          by b-slayer
                                          I have an Asus Strix-G15-G513RM, who starts normally, but as the fans don't work, it stops and is really really hot,
                                          The Bios was the latest one, (327), but I managed to downgrade it to version 325 to see if it changed something,
                                          (as I read somewhere that a corrupted bios can explane my problem), but nothing, it just went full blow during the downgrade,
                                          (so now, i can say that the fans are fonctionnal), but as it restarted, the fans won't turn at all again.
                                          ah, and in the Bios, even when the temperature is really hot, the fan are a 0 rpm,...
                                          09-04-2025, 04:58 AM
