Fans in old 1U equipment
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Fans in old 1U equipment
    my dad gave me a little oil pen with some air condition fan oil he put in there from a 20 year old container. Works great, no mess
      master hoarder
      • May 2008
      • 12170
      [quotc_hegge]Re-lubed fans don't usually last longer than a couple of weeks before they get noisy again.[/quote]
      That's because most people just do it the lazy way - remove plug and add lubricant. This is indeed only a temporary fix. What you really need to do is fully take the fan apart if you actually want it to work right in the long term. And by take apart, I mean take off the retaining/locking washer from the shaft and then remove the the blade assembly (the rotor).
      For dual ball bearing fans, just soak the bearings in oil and let them absorb it. That's it.
      For fans with a sleeve bearing (and also fans with a single ball-bearing), there's more that needs to be done - the shaft and the bearing must be cleaned thoroughly.
      Normally what I do is I wipe the shaft with alcohol using a small piece of paper towel. Then I rip that piece of paper towel into small pieces and insert them into the sleeve bearing after which I use a small screw driver to push them out. After this, I put the fan blade assembly back in the housing and move it in and out while also applying side pressure on it in different directions. The rubbing of the shaft and sleeve bearing is what does all of the cleaning. After this, I take out the blade assembly out again, and clean the shaft and bearing with alcohol one more time. If the fan blades are still hard to turn or make grinding noises, repeat above procedures until they turn freely. Finally, add oil or lithium grease (DO NOT use regular grease for this) and assemble the fan again.
      By the way, I just fixed 2 fans like this a few days ago. First one was a 120mm cheap Raidmax fan that was almost completely stuck. The other was a noisy (heavy grinding) 60mm single ball bearing fan (ball bearing on the front, sleeve bearing on the back) from one of those all-in-one kiosk computers (the ones with a touch screen). Both fans run whisper quiet now.
      • c_hegge
        • Sep 2009
        • 5219
        It can also be that the shaft (or bearings) wears down. If this happens, no amount of oil will put back the worn steel or brass.
        • b700029
          Banned
          • Sep 2010
          • 640
          Fans usually won't wear their bearings to that extent, because with just a little dryness they'll seize. Different from something like an engine where there's a huge amount of power that can grind away the metal really quickly.
          Originally posted by shovenose
          I could have got them for about $1 each, lubed the fans,
          and had some REALLY NICE 10/100 switches.
          With any luck they might end up here: https://www.badcaps.net/forum/showthread.php?t=6356
          • emil_t
            RTX3090 working fine but fans not spinning
            by emil_t
            Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
            04-12-2024, 06:54 AM
          • eccerr0r
            Server equipment... slow boot?
            by eccerr0r
            Is it normal for servers to take an eon to boot?
            I have two "server class" machines/boards now, with ECC RAM. Both take an eon and a half to boot.
            The specific one I have is a Supermicro board with an atom c2550 chip in it. It takes forever, almost a minute before it initializes vga if at all (for some reason it doesn't even init the onboard VGA port, I have to stick in a PCIe card). Machine almost seems dead before then.
            The other machine is an Itanium machine, likewise does not init VGA until at least a few minutes after power up.
            02-19-2023, 06:02 PM
          • omega
            Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
            by omega
            Hello all,
            as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
            Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
            02-09-2024, 03:34 PM
            Rack mounted ECB-A10H plus several buck converters set to different voltages with a 12 and 24 volt switching power supply
            Last night when I was doing a Google search on the internet I was searching for empty rack mounted enclosures and I found this website where I found some 5u enclosures for a reasonable price these enclosures are being discontinued so for this reason until I place an order I not going to post the website link because I need to make sure that we are working Saturday if we are going to work Saturday then I will place the order tonight and I will post the website for them
            I want to reuse my rack mount cart that I have not been using sense I have do my projects in my new shed but I going...
            09-13-2024, 06:47 AM
            HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
            This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
            09-06-2024, 11:39 AM
