I have a WRT54GS router showing signs of failure, and I'm wondering if it could be a bad cap...
The symptoms I have are:
- The Wifi signals disappears few minutes after the boot.
- The router makes a strange buzz noise (it sounds like an old fan full of dust)
Looking closely the board, I didn't notice anything obvious, but one of the two caps could be a little bulged.
Moreover the sound seems to come from there.
The "failing cap" is HERMEI 220uF 25V 105°C HT
diameter: 8mm
Lead space: 3.5 mm
Can you confirm it is a bad cap problem ?
and if so, which cap should I order for replacement ?
I'm currently in Switzerland so if you could also point me to a good and cheap reseller, it would be great.
Thanks.
diameter: 8mm
Lead space: 3.5 mm
Thanks.
