Router conflicts?
  • stevo1210
    • Oct 2006
    • 4156
    Router conflicts?
    Im trying to set up a wireless network. The router is a dlink di-713p and the cable modem is a motorola surfboard... A black vertical thing with amber lights and a usb and ethernet port. Well i have everything connected but when i plug the pc in it keeps coming up with accquiring network adress and thats it... Like it's not giving an ip address. I have dhcp enabled on the router but no help. Whats wrong here? Is it the modem playing up or what?
  • stevo1210
    • Oct 2006
    • 4156
    Re: Router conflicts?
    The pc works fine and connects to the net if i connect it directly by ethernet to the modem...
    • toastygoodness
      • Jul 2005
      • 813
      reset the d-link router. i have a surfboard too. it should be able to detect whether or not the router has a dhcp server and turn off automatically. after you reset the router, DO NOT connect the modem to the router. test it out first by connecting your computer to a NAT (1,2,3,4 NOT the modem port) port. the router should act as a dhcp server for your computer. if not, the router has a problem, and you may have to do a factory reset.
      • weirdlookinguy
        • Sep 2007
        • 1638
        Go into the router config and clone the PC's MAC address. Maybe let it sit for a few minutes so everything can kick in and all should be well. I always have to do this when I put a router in for somebody with a surfboard modem.
        • seanc
          • Nov 2008
          • 1319
          Even if you do have to clone the MAC of the PC to get the Surfboard working, the PC should still get an address via DHCP from the router.
          I second resetting the router, just to rule anything weird out.
          • weirdlookinguy
            • Sep 2007
            • 1638
            Whoops, misunderstood the problem. I thought he meant the router wasn't getting an IP from the modem.
            • Krankshaft
              • Jan 2007
              • 2328
              Make sure the cable modem is running and connected.
              Go into the router control panel and find the status page click DHCP release wait then click DHCP renew. The IP and DNS address of your modem should now be displayed and it should work.
              If it's the PC is not receiving an IP try a manual reset. Type cmd in the run menu. Type ipconfig /release hit and wait when the command is done type ipconfig /renew. This will make it dump the current IP address and query the DHCP server for a new one.
              • retiredcaps
                • Apr 2010
                • 9271
                Another possibility is the router is only configured to hand out so many DHCP addresses (say 5). If your router is unsecured, you could have people leeching off your router and taking up all the DHCP addresses.
                --- begin sig file ---
                --- end sig file ---
                • ant3202
                  • Jun 2006
                  • 275
                  • Singapore
                  try this
                  off the motorola modem and the router.
                  on the motorola modem first and let it load. once loaded, on the dlink router.
                  • NxB
                    • Feb 2009
                    • 1595
                    Some cable companies CPE lock their subscribers. This means that you have to connect whatever mac address first used the account. That or you can have it reset by the co.
                    If your computer can get on, try cloning its mac address to the router. If that fails, try running a different ip range on the router vs the cable modem. The modem hands out 192.168.1.xxx (when there is no signal) ips and so does your router, change it to 192.168.2.xxx.
                    Let the modem sync while unplugged from the router. Get your computer to connect to the router so that you can connect to the administration page.
                    I don't know what you can monitor while on dlink's page but try to keep an eye on wan IP. This is what the modem is assigning to the router.
                    Plug the modem into the router while you are in the admin page. See what happens to wan ip, if nothing, try to release and renew the wan ip.
                    If all goes well you get a public ip on the router.
                    • japlytic
                      • Oct 2005
                      • 2086
                      Some wireless routers can clone (or change) the MAC address for the WAN port.
                      Hopefully, that would be supported. You may need a firmware upgrade for that.
                      • eradz
                        • May 2010
                        • 20
                        If i think i got the problem right:
                        Your comp works fine connected to your eth port on your modem. Your router isnt getting an IP from your modem tho.
                        Alot depends on your ISP. I have a surfboard and i have Atlantic Broadband as my isp. If I change my router, which i have many times in the past, I have to reset my modem. Theres a reset button(use a paper clip) in the back of your modem and hold it down for about 10 secs. Make sure you have your modem plugged into your router before you reset.
                        Option 2 is to call your ISP and they can send the reset signal down to your modem.
                        Hope this helps.
                        • double_DD
                          Why does my ISP router hate my "homemade" power supply??
                          by double_DD
                          It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                          So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                          For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                          07-12-2025, 03:09 AM
                        • Hondaman
                          Hardware firewall to block ad servers?
                          by Hondaman
                          I found an interesting summary on a wiki that Youtube "right to repair" enthusiast Louis Rossman put up. He suggested I could use a hardware firewall and pfSense as a firewall, and use pfSenseNG as an ad blocker. Or use OPNSense as a similar alternative. Seems like it would be easy to set up, but it only runs on the hardware supported by BSD. (I'm sure the developers and maintainers of BSD are super-busy and cannot support every single piece of hardware out there, so I can't fault them.)
                          The trick, apparently, is to "assign IP address lists from sites like I-blocklist...
                          02-05-2025, 05:04 AM
                        • gtsamour
                          tplink vr600 modem router - Capacitor
                          by gtsamour
                          Anyone know what brand this is? Its inside a tplink vr600 modem router. Should I replace it?
                          https://imgur.com/XT0F70S...
                          11-22-2020, 03:59 PM
                        • harp
                          simple win network with optimization issue
                          by harp
                          simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                          06-23-2025, 11:01 AM
                        • shadow666
                          Router Xiaomi M4A Gigabit
                          by shadow666
                          hello
                          i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                          Mi Router 4A Gigabit Edition
                          ROM CHIP is 16 MB
                          i attached picture of motherboard​...
                          11-30-2024, 03:49 PM
