HDMI over CAT5 with a HDMI switcher for more than one computer being monitored proof
    • Jul 2011
    • 6069
    Re: HDMI over CAT5 with a HDMI switcher for more than one computer being monitored pr
    Originally posted by stj
    mass storage needs access rights set up to specific mac or i.p. for security reasons
    if your using open software like OpenWrt you can also configure virtual lans
    Unfortunately I cannot modify these settings on the Comcast modem or at least I have not figured out how to do this on the version modem that I have
      • 31247
      to extract power from the network it has to be there first - i doubt a comcast box has POE
      whats the model number?
        • Jul 2011
        • 6069
        Would this work for my lift master garage door opener and cameras
        Liftmaster 828LM Garage Door Opener Internet Gateway - MyQ
        • CapLeaker
          Leaking Member
          • 8340
          I use a 24 port network switch and only one Ethernet cable going to the router. Everything gets plugged into the switch and let the router do the DHCP.
          Not sure what your NAS problem is, but mine works fine (Synology). What you don't want to do is to cheap out on ports on the switch and have multiple smaller switches on the router itself. That creates a ton of extra data traffic and maybe even loops and slows the network down considerably.
          • CapLeaker
            Leaking Member
            • 8340
            If configured correctly, yes.
              • Jul 2011
              • 6069
              I am buying a used one to try it out and see if this work better than the way I have it now
                • Jul 2011
                • 6069
                My question is should I get a router that has both POE and non POE is there advantages over just getting a POE router
                • 3guk
                  • Feb 2011
                  • 5
                  Depends on how many POE devices you want to use really - there's no difference other than being able to power devices over ethernet. POE switches tend to cost more than the non POE equivalent.
                  https://factory-reset.com - Factory Reset / Service Menu guides.
                  • double_DD
                    Why does my ISP router hate my "homemade" power supply??
                    by double_DD
                    It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                    So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                    For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                    07-12-2025, 03:09 AM
                  • maybepanic
                    HP Probook 450 g5 Liquid damaged USB-C / Display port switcher
                    by maybepanic
                    Hey,
                    I've got a liquid damaged HP Probook 450 g5.
                    There was a lot of corrosion around the Paradetech PS8743B B1 chip, plus what looks like heat damage from a short. There are no schematics available for the board, nor could I find any schematics from paradetech for the USB-C / Display port switcher.
                    Is there anything else I can do to increase my chances of fixing the board apart from checking for shorts around the ic and replacing it?
                    Attached some pics of my liquid damaged board, closeup of the cleaned ic and a pic of a good board I found online.
                    Thanks!...
                    06-07-2023, 04:30 AM
                  • abhishekkumar1902
                    Alternative of TOP244PN switcher IC?
                    by abhishekkumar1902
                    I have an SMPS where the TOP244PN switching IC is used to power the standby section. I am not able to get this IC locally, is there any alternative in the TNY switcher series I can use in its place?
                    Also, can I use the TOP244YN package in place of this TOP244PN package? It seems in the PN package they have combined the X and L pins of the YN package and made single M line....
                    12-31-2022, 01:43 PM
                    GLC65 GLM65 65 Watt Multiple Output Global Performance Switcher Datasheet
                    65 Watt Multiple Output Global Performance Switchers
                    Condor Part Summary
                    • 65 Watt Wide Range Input
                    • High Efficiency (Up to 90%)
                    • Universal input 90-264 Vac
                    • 2-year warranty
                    • Also available in single outputs
                    • Conducted EMI complies with FCC Class B and CISPR 22 Class B (Commercial models) and CISPR 11 Class B (Medical models)
                    • Exempt from line harmonics standard EN61000-3-2
                    • Commercial Approved to UL1950, CSA-C22.2 No. 950,
                    • Medical Approved to UL2601-1, CSA 22.2 No. 601.1, and EN60601-1
                    10-07-2024, 05:46 AM
                  • paparazzo79
                    Can HDMI switcher damage devices?
                    by paparazzo79
                    Hi friends.
                    I purchased HDMI switcher so I could use both PC over one monitor.
                    But I'm anxious to use it.
                    Are these stuff safe to use?
                    I'm affraid of short circuit over to monitor or even graphics card.
                    Could not find who made this one,seems unknown....
                    07-14-2022, 05:10 AM
