HDMI over CAT5 with a HDMI switcher for more than one computer being monitored proof
    • Jul 2011
    • 6047
    I recently got a new shed that it my battery testing work bench beside this it also be electronic work bench as well and general work bench area as well
    I want to have a way to monitor more than one computer that is doing battery testing on the fly so I can switch between monitors and be able to see the results in real time
    I a chief engineer where I work gave me the information and idea to use a CAT5 repeater which would be the simplest way to do this
    They use a different method to transmit the data to tv monitors around the facility but that system requires some programming that apparently is somewhat difficult to setup
    I did some research and testing the system concept that I had in mind and the testing revealed that yes it is doable and the results are very good for what I am trying to do
    As you can see in the pictures below
    If I do not have this post in the right place please feel free to move it to the right place
    I have one question about putting 4 CAT5 cables in a out door conduit is there going to be any issues if I do this
    • Jul 2011
    • 6047
    Re: HDMI over CAT5 with a HDMI switcher for more than one computer being monitored pr
    Yes the CAT5 cable is rated for outside use that I going to be using
      • 31099
      why not just run VNC and check it over your existing network?
        • Jul 2011
        • 6047
        Because I have no internet service at the new shed and I might add later but I need to able to monitor the battery testing machine which is more important right now
        Another issue I have is every time I add a router my internet speed goes down some right now
        two and a switch on the modem
        Plus I want my battery testing machine off the internet network anyway
        Because the computers are not hooked up to the internet
        • diif
          • Feb 2014
          • 6978
          • England
          You should only have one router on your network.
          I'd run one cable and put a mini switch on the end and use VNC as stj suggests. This will give you control over them rather than just an image.
          How do you remotely change which monitor you see ?
            • 31099
            how are your routers wired?
            i cant see how they would slow anything unless you have an accidental loopback.
              • Jul 2011
              • 6047
              I would be interested in hearing about this if this is possible to have control of each computer with out having internet connection access
              I do not want any connection to the outside world this is a MUST
              I am using a HDMI switcher which has 5 input to one output for one monitor
              Please keep in mind that these situations are in two different locations
              The reason I have two router is because I have a small camera ( and adding a second camera) that requires a internet connection that is wire less because it lets you see it remotely
              I also use several different printers that use a WiFi connection or I have install the printer drivers and I do not want to have this hassle
              The switcher it is an eight port device
              Two computers are used by my son to play games on the internet with his friends
              One is used to have internet access in the garage for the camera and the second one that I will be adding very soon
              One two a new desktop computer
              One will back up and running if my external hard drive is reconnected and still working properly or not I was having issues with it connecting so I temporarily disconnected it from the router
              Now if there is a solution to this issue I all hears and you would have my undivided attention to this issue and how to solve it
              • diif
                • Feb 2014
                • 6978
                • England
                Create an intranet. A device doing DHCP usually a router connected to a switch in the battery hut that connects to the four PCs running VNC and a PC in the house connected to it for viewing.
                Your current network should only have one router doing DHCP on it. You can add as many switches and APs as you like to it.
                  • Jul 2011
                  • 6047
                  Can this be setup with out being hooked up to the internet
                  How easy is it to be set up because I have never set one up
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    No, it doesn't need an external connection.
                    Set the PCs to have a static IP and install uVNC on them. https://uvnc.com/
                      • Jul 2011
                      • 6047
                      I was reading about this software and it mentions that you need to have a sever what are my options server software and what type of computer do I need to use for a server for the type of setup that I want to use it for
                      Remember I am very new to this type of setup
                      I have installed Windows 3.1 to Windows 11 I understand this very well
                      When I went the community college for very simple computer courses I played with Windows sever I do not remember what version it was but I had some issues getting it to work properly so I only the very very basic of this type of setup
                      I will be using Windows 7 on the battery testing machine computers
                      Thank you for all your help and your information that you have given me so far
                        • Jul 2011
                        • 6047
                        Can you please explain this in more detail I think you touched on in a earlier post
                        I am all for doing this the right way but my knowledge is limited on this particular network setup
                        So any help would be greatly appreciated
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          uVNC server goes on the battery PCc and uVNC viewer goes on the PC in the house.
                          • CapLeaker
                            Leaking Member
                            • 8236
                            Yep I agree. I would use one LAN probably even make a VLAN and use VNC to look at all the stuff in the shed.
                              • Jul 2011
                              • 6047
                              Is this what I am looking for to use on my switch
                              Wireless Desktop Access Point (WAC104) - Wifi 5 Dual-Band AC1200 Speed | 3 X 1G
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                No, you need something that does DHCP.
                                • CapLeaker
                                  Leaking Member
                                  • 8236
                                  Your house got already a router. If you put a switch on it the router does your dhcp. Don’t go down the rabbit hole of double or triple ‘netting’ having like 3 routers in one network. Same as having 4x 5 port switches hooked to a router. Put one 24 port switch and let the switch do its job and decide what traffic goes where.
                                  You also could save yourself the wiring and put a wifi bridge and set it to bridge mode.
                                  I am on a security camera project, where I have to remote 4 extra POE cameras into an existing NVR about 1500 feet away. I can’t lay any wire between the 2 buildings, so I just bridge the network from over here to there.
                                    • Jul 2011
                                    • 6047
                                    One note the modern has at least 4 Ethernet ports on it
                                    One other note I can hook up the mass storage to the modem it does not allow me access to do this because I tried this before I could not get it to work correctly I can only get it to work with the router setup
                                    One more thing I have tried and extender and was not impressed with the results that I got
                                    I have not tried “bridge the network” I have researched this topic
                                    I have a situation where I need WiFi in the house and I need WiFi in a metal garage the signal from the WiFi in the house is not strong enough to reach the the metal garage so how do I resolve this issue and remove the other router in the garage and still have the WiFi signal in the garage
                                    I do have an Ethernet cable ran from the house to the garage that is already wired
                                    The switch is in between modern and the router
                                      • 31099
                                      mass storage needs access rights set up to specific mac or i.p. for security reasons
                                      if your using open software like OpenWrt you can also configure virtual lans
                                        • Jul 2011
                                        • 6047
                                        Can I use this for myQ cameras in my garage
                                        ANVISION 5V Gigabit PoE Splitter, 48V to 5V 2.4A Adapter, Plug 3.5mm
                                        Because this camera is WiFi enabled only the power supply for the camera is a USB power supply
                                        • double_DD
                                          Why does my ISP router hate my "homemade" power supply??
                                          by double_DD
                                          It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                                          So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                                          For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                                          07-12-2025, 03:09 AM
                                        • maybepanic
                                          HP Probook 450 g5 Liquid damaged USB-C / Display port switcher
                                          by maybepanic
                                          Hey,
                                          I've got a liquid damaged HP Probook 450 g5.
                                          There was a lot of corrosion around the Paradetech PS8743B B1 chip, plus what looks like heat damage from a short. There are no schematics available for the board, nor could I find any schematics from paradetech for the USB-C / Display port switcher.
                                          Is there anything else I can do to increase my chances of fixing the board apart from checking for shorts around the ic and replacing it?
                                          Attached some pics of my liquid damaged board, closeup of the cleaned ic and a pic of a good board I found online.
                                          Thanks!...
                                          06-07-2023, 04:30 AM
                                        • abhishekkumar1902
                                          Alternative of TOP244PN switcher IC?
                                          by abhishekkumar1902
                                          I have an SMPS where the TOP244PN switching IC is used to power the standby section. I am not able to get this IC locally, is there any alternative in the TNY switcher series I can use in its place?
                                          Also, can I use the TOP244YN package in place of this TOP244PN package? It seems in the PN package they have combined the X and L pins of the YN package and made single M line....
                                          12-31-2022, 01:43 PM
                                          GLC65 GLM65 65 Watt Multiple Output Global Performance Switcher Datasheet
                                          65 Watt Multiple Output Global Performance Switchers
                                          Condor Part Summary
                                          • 65 Watt Wide Range Input
                                          • High Efficiency (Up to 90%)
                                          • Universal input 90-264 Vac
                                          • 2-year warranty
                                          • Also available in single outputs
                                          • Conducted EMI complies with FCC Class B and CISPR 22 Class B (Commercial models) and CISPR 11 Class B (Medical models)
                                          • Exempt from line harmonics standard EN61000-3-2
                                          • Commercial Approved to UL1950, CSA-C22.2 No. 950,
                                          • Medical Approved to UL2601-1, CSA 22.2 No. 601.1, and EN60601-1
                                          10-07-2024, 05:46 AM
                                        • paparazzo79
                                          Can HDMI switcher damage devices?
                                          by paparazzo79
                                          Hi friends.
                                          I purchased HDMI switcher so I could use both PC over one monitor.
                                          But I'm anxious to use it.
                                          Are these stuff safe to use?
                                          I'm affraid of short circuit over to monitor or even graphics card.
                                          Could not find who made this one,seems unknown....
                                          07-14-2022, 05:10 AM
