Dell 2007WFP Won't Power On
  • chad720
    • Jan 2011
    • 16
    #61
    Re: Dell 2007WFP Won't Power On
    thanks PlainBill!
    I know I haven´t posted pics and datasheet, but the J598 doesn´t have datesheet (or I can´t find it) and I had already isolated the failure, I only ask for someone that has the knowledge or the diagram of the inverter board to tell me with wich voltage is working the zd701, or if someone has a very huge heart an want to isolate the diode and meassure the voltage, it would be very appreciated!! the integrated that controls the board are two TL1451A
    the way to measure this is writen on this forum, quoting is kind of isolating the diode, put a 1kohm resistance in serie and a 24V supply over terminals, so the current would be limited by the resistance and with an voltimeter see the drop over the terminals of the diode, this should be te value I´m needing!
    Thanks to everyone who could iluminate my path to recover my monitor.
    Chad
    • croket
      • Oct 2011
      • 18
      #62
      Hello All,
      I realize this post has been quiet for about 10 months now and I hope some one out there can still help me out.
      I"m having a problem with my monitor, came home from work one day, try to turn the unit on but it didn't, I'm not even getting the pwr button LED light (orange or green)
      I do have some electronics knowledge however not a pro.. I've taken it all apart and took some basic readings with my DMM. I've also posted some detailed pictures with my findings.
      for starters I"m getting continuity across the fuse on the Power Supply board, at the end of the PS (Power Supply) board I'm getting 18V at each side where CN701 and CN702 are.
      This is where I'm confused, the transformer on the PS board doesn't seem like its showing correct reading. look at the close up of the transformer contacts, I've edited it to reflect what my DMM is showing. Other than that I could use any advise or help. Thanks guys!
      • retiredcaps
        • Apr 2010
        • 9271
        #63
        First, those are excellent clear focused pictures. The composition is excellent showing both sides and the relationship between boards. I wish more people would provide such great pics.
        Second, I have this exact same monitor taken apart waiting repairs/parts.
        I found that the logic board (with the Genesis chip) had two bad voltage regulators (right by the connector). U13 and U5 are both shorted.
        On the USB board, I found 2 diodes (FD4) shorted.
        Lack of proper solder equipment has prevented me from repairing this monitor so far.
        PS. I think I got 19V DC if I remember correctly on the power board.
        --- begin sig file ---
        --- end sig file ---
        • Rtech
          • Jul 2010
          • 1095
          #64
          The 160V on both pins of the transformer is probably correct,and one of thos normally goes to the Large Filter cap,and the other to the Mosfet on the Heatsink.Provided the SMPS chip ( the 8 legged one )next to the transformer,is functioning correctly,then this drives the Mosfet to feed the transformer. On the other side then,where you are getting 0 volts,is probably not the best place to check.D701 looks like a Schotky diode,and the rectified voltage from that,feeds C711 and C713..measure the DC voltage across the caps and check the diode by using the diode test funtion on your meter(if you have one)The latter with the power OFF.Also advise the part code of the 8 legged smps chip ?
          • croket
            • Oct 2011
            • 18
            #65
            retiredcaps, Thanks for the compliments on the pictures, I realize how critical it is when working on an item that you don't have in front of you. I"m a big fan of close up detailed pics.
            I've checked the U13 and U5 components on my board and they read ok, not shorted. Also read the the 2 diodes (FD4) on the USB board and they too were not shorted (i also checked every diode of the same Part# number as FD4) .
            And yes you're correct, 19V is what I'm getting.
            Rtech, I removed Schottky diode (D701) to test out of the board and it checks OK. I put it back in and plugged the board in, Both caps C711 and C713 read 19 vdc across.
            I was able to read the part number off the 8 legged chip, it is 200a6, I also hunted down the datasheet for it witch I uploaded. I'm not exactly sure what to look for in that datasheet so your more than welcome to talk a look at it.
            What I did find is a shorted diode on the bottom side of the power board, (D604). its to the left of the 8 leg SMPS chip (if looking at my pic). other than that I can't seem to find anything els.
            Thanks for helping out guys, anything else I should be looking at?
            • retiredcaps
              • Apr 2010
              • 9271
              #66
              If you are getting 19V DC at CN701, that implies your power board/supply is working.
              On the logic board, now measure the DC voltage each pin on both voltage regulators. Even though these regulators are not shorted (like mine), they still could be out of specification.
              • croket
                • Oct 2011
                • 18
                #67
                No I'm not getting any voltage on any of the pins of the regulators (U13 and U5). I've got 19v on the 2 far right wires (brown & Black )at the connector above the regulators.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #68
                  The fact that you are getting 19V DC on the wires shows that voltage is getting to the main board, but the voltage regulators are dead.
                  If you are not getting any DC voltage on U13 and U5, that would explain the lack of the power led going green. That means U13 and/or U5 are both bad. If you have junk boards laying around, you may be able to desolder an old one and use it. Or just order them from digikey or mouser.
                  On mine, U13 is 952T43 (a 1.8V 1A)
                  http://www.alldatasheet.com/view.jsp?Searchword=952T43
                  U5 is 950T65 (2.5V 1A)
                  http://www.alldatasheet.com/view.jsp?Searchword=950T65
                  1.8V and 2.5V DC is what you should get if the regulators are working properly.
                  • croket
                    • Oct 2011
                    • 18
                    #69
                    Shouldn't I get some kind of voltage on the "in" pin on either regulator even if they are bad?
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #70
                      Hmm, good point.
                      What are you using for ground when measuring U13 and U5?
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        #71
                        On my board, all pins on both regulators are shorted to ground.
                        • croket
                          • Oct 2011
                          • 18
                          #72
                          I re-tested U13 and U5. This time I placed the red probe from the DMM on the black wire coming into the board showing 19v, With the black probe I touched every leg on both chips and I get 19v on my DMM indicating all the legs are grounded.
                          The weird thing is when I try to tone it out (continuity beep) they don't all ring out. On U13 only the left legs rings out and on U5 the middle leg rings out. I"m using one of the screw holes rings on the board for ground.
                          Any thoughts?
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #73
                            Here is how I test voltage regulators. Put your black probe on the ground screw (this is your ground) on the logic board. Put your red probe on each pin of the 3 legged voltage regulator.
                            Now what do you read?
                            • croket
                              • Oct 2011
                              • 18
                              #74
                              Just did it, I got 0v on all legs both chips
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #75
                                Other than replacing the voltage regulators, I can only think of the caps on the logic board being user replaceable. Everything else is too small or too complicated or proprietary to replace.
                                Maybe a cap is bad on the logic board?
                                • croket
                                  • Oct 2011
                                  • 18
                                  #76
                                  I just traced the circuit on the board for those 2 wires (brown and Black) coming into the logic board that read 19v. They go directly to the connector that connect to the USB board.
                                  they don't energize the logic board at all. I've tested several other components on the logic board they they all read 0v, the entire board has no voltage. The usb board however is a hole slew of components reading 19v.
                                  This leads me to believe that there has to be another wire that energizes the logic board, however there isn't. take a look at the USB board. its hot. the logic is dead.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #77
                                    On one yet to be solved monitor, whenever I hooked up the logic card, my power supply went from 12V DC to 0V DC.
                                    I wonder if the USB board is shorting out the logic board? Try removing the USB board and re-measuring the logic board for DC voltages?
                                    Of course, my monitor is dead so I can't even measure voltages. Looking at the power board, there is only one 470uF 35V cap which leads me to think that 19V DC is the only secondary voltage provided?
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #78
                                      Hmm. Something is nagging me about this USB board. I seem to recall PlainBill saying something about being a DC-DC converter. Let me search around to see if I can find it.
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        I've been pouring over the pictures for the last 15 minutes, getting more frustrated by the minute. First of all, if you have 19 volts on the USB card, the power supply is working.
                                        Next, what are the voltages on each of the 12 pins connecting the signal card to the USB card?
                                        There are 4 regulators you have indicated have 19V on two pins. What are the part numbers of those 4 ICs?
                                        Last, what is the part number of U2 on the USB card. What is the voltage on the three pins?
                                        PlainBill
                                        • pedro
                                          • 199
                                          • AUSTRALIA
                                          #80
                                          The USB board obviously produces a regulated +5V from the 19V supply. Is it a possibility that THAT is the supply for the logic board, and NOT the 19V? If they are going to use 3-terminal linear regs for 3.3v etc on the logic board, that would make sense.
                                          Friends don't let friends buy Samsung ....
                                          • keepread
                                            Dell monitor PSU vs Dell laptop PSU
                                            by keepread
                                            Hi there!
                                            Someone gave me their old monitor, it's Dell S2715ht.
                                            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                            10-30-2025, 04:45 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • Borse2008
                                            Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                            by Borse2008
                                            Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                            I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                            • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                            • There’s
                                            07-15-2025, 04:55 AM
                                          • Mark01
                                            Dell Optiplex 7490 AIO - red power led after flash
                                            by Mark01
                                            Hi guys,
                                            This is my first post! 🚀
                                            I have no idea what I’m doing, but I’m learning by trial and error.
                                            I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
                                            07-04-2025, 12:54 PM
