Chinese made LCD Microscope
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    Need help. my chinese made LCD microscope broke.. leaving me a broken lcd screen. Model number is JST4300-e3v05
    any idea guys where can i get a replacement, i already google it with no avail.
    it is a 40pins 4.3 Inch 3.3V 480x272 Resolution. any lcd model compatible with this lcd. thanks in advance...
    Never stop LEARNING because life never stops TEACHING!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Chinese made LCD Microscope
    https://www.aliexpress.com/item/4000283839451.htm
    • R_J
      • 9561
      Maybe one of these? https://shop9165960972.panelook.cn/?...uct&catid=3175
        • Jul 2011
        • 6046
        Nothing opens with this website link that you posted
        • diif
          • Feb 2014
          • 6978
          • England
          You're right, it's missing the l off the end.
          https://www.aliexpress.com/item/4000283839451.html
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            Originally posted by R_J
            Thanks for the reply.. https://www.panelook.cn/TL043WV01-00..._cn_97127.html i found it.. thanks...
            • diif
              • Feb 2014
              • 6978
              • England
              You can measure for the 3.3v and backlight on your board. Pinout in the link i posted. I would think a Chinese microscope would use a cheap generic screen.
              • dalek1967
                Chinese made 12v 6 amp lead acid battery charger info
                by dalek1967
                I posted another thread like this for a TV power supply. This is for information purposes for anyone who has a bad one and wants to repair instead of replace. There is no model number on these but internally they appear to be the same, fan being the only difference I can find. If a component is damaged and can't be identified, this may help. One I have has the brand name XinJieBao on the front above the display. The other isn't marked.
                My impressions. I can't say for sure on the chips and such but the HV capacitor is a very low quality one if I think. I tried to google it and also...
                05-10-2023, 12:42 AM
              • chegueva
                My Andonstar ADSM201 Microscope Review
                by chegueva
                Hi everyone. i'v started learning electronics before the corona hit so that's not very long time ago. but anyways i started with only a multi-meter then i started getting into micro-soldering and soldering in general, got myself hot air station a bench Power-supply and last but not least a microscope.
                About the microscope at first i just wanted to get those 15 usd USB digital microscopes to try but some people talked me outta of it and i decided to go for something better but not professional as i'm just starting out.
                So i had a choice between a binocular & camera , i wanted...
                08-14-2020, 11:08 AM
              • lcdcaps1
                INSKAM Microscope USB port issue
                by lcdcaps1
                Hi
                All
                Does anyone have a INSKAM 7 inch LCD digital microscope
                I have a weird issue on the one I have where the USB port does not output enough power because when I connect a USB light or the ring light the light output is always really dim
                The ring light when connected to the microscope USB port is at the lowest brightness and turning the brightness knob makes no difference
                I have tried different cables and different USB power adapters
                I have confirmed there is nothing wrong with the ring light and the other USB light by plugging them into another...
                04-18-2025, 04:16 AM
              • caspian
                Weak Vision due to Eye Strain when using Microscope
                by caspian
                Dear Forum Members,
                Microscope is required for micro-soldering and for measuring tiny components on a mainboard. I have to use microscope because my eyes are not that strong to see tiny IC pins.
                My microscope has light to improve vision. I have attached a photo of my microscope.
                Looking through a microscope gives us eye strain. After using microscope for 5 to 10 minues, my eyes get a bit weak in recognizing close objects. that means close objects look a bit blur. Then, I have to wait for 5 to 10 hours til my eyes get back to normal.
                1. Do you experience...
                08-14-2019, 02:28 AM
              • valente222
                help SG2701B01-7 panel chinese, would this integrated circuit be equivalent? Chinese IC CS601C regulator.
                by valente222
                Hi, I'm repairing this Chinese SG2701B01-7 panel. There isn't much information about it. The original part for the panel is a CSOT CS601C regulator. I can't find anything commercial on Aliexpress; there's only the CS601 without the final 'C'. They claim it's a variant. But will it be compatible? Well, my diagnosis on this screen is a video problem; the image is practically black, although there is HDMI communication. The LED light is on (backlight), but there is no VGL, no 3.3V, and no VSS. It seems that this IC is the one controlling these voltages. The monitor worked correctly for a moment and...
                05-12-2025, 03:42 PM
