Acer AL2416 AL2416W 24" 1920x1280 LCD Monitor
  • singion
    • May 2011
    • 4
    #201
    Re: Acer AL2416 AL2416W 24" 1920x1280 LCD Monitor
    http://i185.photobucket.com/albums/x...n/inverter.jpg
    re soldered all my caps and mosfets and the buzz seemed to move
    linked a pick the what i now think is buzzing(what is it)
    • jetadm123
      • 2169
      #202
      If you get it working, please post a photo.
      • singion
        • May 2011
        • 4
        #203
        made it worse what ever that is i think i now need to replace it no more buzzing no more picture looks like inverter does not power up anymore due to me messing with that part
        • jetadm123
          • 2169
          #204
          Try checking the 3 fuses on the inverter.
          • rafamart
            • Jul 2011
            #205
            This thread is awesome! My situation is exactly the same as someone else described: found the monitor on the street, it turns on with the Acer logo and goes blank.
            I was first suspecting the power supply because the 24 V rail turns off after about 4 seconds, even when neither the inverter nor the LCD controller board is plugged in. Is this also the case in your power supplies?
            But then when I desoldered one leg off of each of the infamous 10 cap on the inverter board, it turns out that 5 of them show less than 1uF, 2 of them show about 20uF and only 3 show something close to the default 100uF. Bingo.
            So, of course I have an issue with the inverter, but can someone confirm that in your operational/repaired unit the power supply also shuts down the 24v rail after about 4 seconds without the inverter & control board connected?
            • PlainBill
              • Feb 2009
              • 7034
              Good job of troubleshooting.
              Designs can vary, but usually the power supply consists of a standby supply which is always on, and a main supply which is controlled by the signal board. It would not be unusual for it to shut down without the 'on' signal present.
              PlainBill
              • folinsbee
                • Aug 2011
                • 5
                #207
                Hj folks
                I have the common problem with a acer monitor i was given. Acer logo for 2 secs.The screen was replaced and worked for 1 day so i opened it up and looked at the inverter caps.
                There was a rusty substance on four of them .Could this be the problem ??
                BTW i.m a novice on these things.
                • PlainBill
                  • Feb 2009
                  • 7034
                  Originally posted by folinsbee
                  Hj folks
                  Maybe. There are two substances that could be called a 'rusty substance'. One is normal, one isn't.
                  It REALLY helps if you provide a picture using 'Manage Attachments' - below the test entry area.
                  PlainBill
                  • folinsbee
                    • Aug 2011
                    • 5
                    #209
                    There seems a brown powder on the bottom of the cap.
                    Maplins in the uk has the caps only in 25V or 50v.
                    Are these any good?
                    • jetadm123
                      • 2169
                      #210
                      Are these any good?
                      Yes, those caps are leaking. As a matter of fact, there are 10 of those caps on the inverter board and they should all be replaced. The input to the inverter is an unregulated 24V, therefore, a 25V cap won't suffice. The original caps are rated at 35V. Recommended brand/series replacement caps are below:
                      https://www.badcaps.net/forum/showthread.php?t=2280
                      • folinsbee
                        • Aug 2011
                        • 5
                        #211
                        Cant seem to find them on the badcaps link.
                        What about these Hitano brand??
                        http://www.ebay.co.uk/itm/20-Electro...item1c17b0e1fb
                        • pedro
                          • 199
                          • AUSTRALIA
                          #212
                          I don't know the EHR series, but I'm sure it appears on the Hitano website.
                          I have used , and continue to use, Hitano EXR 105C low-ESR caps in monitor repairs. Haven't had an issue or come-back yet. I suggest going to their website and comparing series.
                          Friends don't let friends buy Samsung ....
                          • kasp1js
                            • Nov 2011
                            #213
                            I read all the thread and tried to understand it all, but it was very confusing.
                            So
                            I got my hands on an broken Acer al2416w,
                            Symptoms are:
                            When I turn it on the acer logo shows for a second, then everything is black,
                            but if I use a flashlight I can see that the monitor is showing the picture, just the backlight isn't working.
                            I opened it and all the capacitors and mosfets seemed fine, no burnt smell or anything.
                            What should be my first step?
                            If I understand correctly, it should be an inverter or ccfl problem,
                            should I replace the 10 35v 100uf capacitors on the inverter board?
                            • alexanna
                              • Mar 2010
                              • 1346
                              #214
                              I think that would be a very good place to start
                              • kasp1js
                                • Nov 2011
                                #215
                                And Rubycon ZLH should be a good replacement?
                                Found these in a local store https://www.elfa.se/elfa3~lv_lv/elfa...2-69&toc=19089
                                • jetadm123
                                  • 2169
                                  #216
                                  Rubycon ZLH is a very good choice. They will be physically larger than the original caps, but if you're careful, you should be able to get them to fit.
                                  Also, check the 3 fuses on the board to verify they are good.
                                  • evilhero
                                    • May 2011
                                    • 17
                                    #217
                                    help plz. I have this acer al2416w the problem is turn on but only yellow amber on. I tested the psu missing 24v and 12v. Only voltage show is 5v. The caps seem okie no blown up.
                                    • Delmonte
                                      • Jan 2012
                                      #218
                                      I'd just like to say thank you for providing all the information in this thread.
                                      I had the acer logo problem and bought the bits from Mouser.
                                      Changed all the caps 1st then got a different problem.
                                      Replaced the mosfets and the fuses with 1.5a and everything is running perfect again.
                                      Thanks again.
                                      • turtleking
                                        • Mar 2012
                                        could someone help a poor soul and give a direct digikey or mouser part number for the 100uF capacitors.
                                        I am having a terrible time finding the low esr capacitors in anything less than 1000 pieces
                                        Thanks Chris
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #220
                                          If you mean 100uF 35V, Panasonic FC is in stock at digikey
                                          http://search.digikey.com/us/en/prod...0294-ND/266303
                                          --- begin sig file ---
                                          --- end sig file ---
                                          • black6host
                                            Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                            by black6host
                                            Good day!
                                            I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                            I'm going to replace the caps and I'll be the first...
                                            02-06-2024, 08:22 PM
                                            by momaka
                                            03-15-2023, 10:17 PM
                                            by momaka
                                            03-12-2025, 03:42 PM
                                            Westinghouse L2210NW LCD monitor - bad caps repair
                                            by momaka
                                            Here's another LCD monitor repair: Westinghouse L2210NW.
                                            Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
                                            I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
                                            Pictures of the monitor outside/case after a brief...
                                            01-11-2021, 01:14 AM
                                          • eryjus
                                            by eryjus
                                            05-10-2023, 11:21 AM
