Gateway 24" LCD Model LP2407
  • fadec
    • Jan 2010
    • 10
    I have a Gateway 24" LCD that is showing many of the normal problems I've seen described on the forum. The LCD comes on for about 1-2 seconds and powers off. I indicator light changes from blue (on) to purple (?), then after a couple minutes orange (no signal/standby). After trying to use a bright light to see if the backlight was turned off, I found the LCD was in fact not working.
    After searching the net for monitor repairs I found a couple that said to check the power supply. After pulling the power supply I found several bulged caps. Though there can be more going on, the caps appear to be an fast and easy fix to start with. On top of that there are 5 bad caps that need replacing no matter what the problem may be in the end. All the caps are Su'scon. Since I have to replace 5 already, I decided to replace all 13 caps on the PCB with better known good caps.
    Since I have not had to repair a circuit board since I was in airframe & powerplant school 16 years ago. I'm not sure about how each manufacture marks their caps. I would like to make sure I order the correct replacement caps.
    The volt's and uF's are easy enough. It is the cap type and case size that I'm having trouble with. I am thinking of going with Rubycon caps and something in the ZLG series. Though I'm not sure that would correct.
    Her is a list of the Su'scon caps I plan on replacing: (info from what is written on the cap)
    C854 450v 150uF 0710 (m)
    C864 35v 470uF 0707 (m) bulged
    C863 35v 470uF 0701 (m)
    C862 35v 470uF 0701 (m)
    C867 10v 1000uF 0705 (m)
    C868 10v 1000uF 0705 (m)
    C869 10v 1000uF 0641 (m) bulged
    C870 10v 1000uF 0701 (m) bulged
    C865 25v 1000uF 0701 (m) bulged
    C884 25v 680uF 0703 (m) bulged
    C866 25v 470uF 0705 (m)
    C857 50v 47uF 0701 (m)
    C876 50v 10uF 0701 (m)
    Hopefully I have everything in the right places. Once last thing I have to consider is height of the caps. As I'm limited to the top of the heat sinks. The cover rest's on the top of the heat sinks.
    Can someone provide info as to the best Rubycon cap types and sizes to use?
    Thanks guys.
  • endevite
    • 48
    Re: Gateway 24" LCD Model LP2407
    Which series are those su'scons?
    MG? H5? SK? LX? LZ? SB?
    Knowing the series we can look up the ripple ratings, lifespan, and impedance which lets us better know what would work as a replacement.
    Datasheets can be found, possibly identify by picture.
    http://www.su-scon.com.tw/products_li.html
    • fadec
      • Jan 2010
      • 10
      It looks like they are SG series (105deg). That is if I'm reading the marking right.
      • endevite
        • 48
        All of them are SG? SG are all very low impedance long life caps with very very high ripple support, so make sure what is what.
        • fadec
          • Jan 2010
          • 10
          Good call, After looking again all but one have SG on them. The 150uF 450v says "SV105deg". I was not able to find an SV series on the Su'scon site, so I hope that is the actual series.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            I don't think you need to worry about replacing the 450v cap as those rarely fail.
            • azack
              • Jan 2010
              • 15
              any luck man im going through the same issues did you get those exact caps you listed in the 1rst posting or did anything change, thanks hope you got it going
              • fadec
                • Jan 2010
                • 10
                I just received my new caps today. It might be a week or so before I get the chance to install them. By following PlainBill's suggestion (see below) that I found in another thread, I was easily able to find what I needed. All caps that came will fit dimensionally, though a couple are slightly different from the OEM caps. I went with Nichicon and Panasonic.
                I'll let you know if this works once I have a chance to install them.
                ps. PlainBill forgive me if you mind me quoting you here, but the info was just too good not to share.
                ___________
                Go to www.digikey.com. Near the top right corner of the page is a box with Part Number / Keyword. Enter capacitor and click Go.
                Click on Aluminum.
                Under Series select the series of caps you believe are acceptable. I usually limit myself to Panasonic FC and FM, but don't hesitate to select more.
                Under Capacitance select the value you need.
                Under Voltage select the voltage
                Under Package/Case select Radial
                Place a check mark by In Stock, then click Apply Filters
                Now I just did this for 680 uF 10 V and got exactly 4 hits. Looking over the specs, I see Panasonic FC and FM in two case sizes. I also note that FM series is rated for a longer life, and costs less. So I click on the Stock Number for the proper case size. On this page I enter the Quantity and click on Add to Order.
                Alternatively I can copy the Digi-Key Part Number and Manufacturer Part Number to a list and someone else can use these to place an order. Then I repeat the process.
                I prefer Digi-Key because they have good prices, a good inventory, and offer a First Class Mail shipping option. This will get your order to you in two days for about $2.00 in shipping.
                Note that in some cases dimensions are critical. Make sure the parts you select are not too tall or to wide to fit!!
                PlainBill ___________
                • azack
                  • Jan 2010
                  • 15
                  Thanks for the reply I'll get mine ordered today or tomorrow and let you know when I'm done. I'm going to replace the same ones you did.
                  • azack
                    • Jan 2010
                    • 15
                    I didnt mine ordered yet. How do your caps look as far as height goes? I'm worried about getting ones that wont fit. If yours all fit can you post what Digi-Key Part Numbers and Manufacturer Part Numbers you ordered.
                    • kingofcoins
                      SaveOnGreen-Cap
                      • Jan 2010
                      • 162
                      Remember if you find the replacement caps may be a bit too long you can always install them at an angle, as you usually will have the wiggle room. Just be sure not to cut the leads until you've tested the insert. I always insert such ones and then view across the top of all the high components on my board to be sure that my new replacement is no taller than the highest component on the board.
                      • fadec
                        • Jan 2010
                        • 10
                        All the caps I ordered where not too long. Only a couple where slightly larger in diameter. Everything fits.
                        So, far we tested all the caps removed and EVERY SINGLE ONE is bad. Even those that didn't show any signs of bulging. Though I didn't plan on replacing the large 150uF 450v cap, I now plan on ordering one anyway. Considering all the others turned out bad.
                        Here is the DigiKey list I ordered:
                        1ea. - P13478-ND CAP 10UF 50V ELECT EB RADIAL
                        3ea. - 493-1868-ND CAP 470UF 35V ELECT PW RADIAL
                        4ea. - 493-1746-ND CAP 1000UF 10V ELECT PW RADIAL
                        1ea. - P10278-ND CAP 1000UF 25V ELECT FC RADIAL
                        1ea. - 493-1829-ND CAP 680UF 25V ELECT PW RADIAL
                        1ea. - 493-1826-ND CAP 470UF 25V ELECT PW RADIAL
                        1ea. - 493-3288-ND CAP ELECT 47UF 50V HIREL RADIAL
                        • azack
                          • Jan 2010
                          • 15
                          Nice great guys thanks a lot.
                          • azack
                            • Jan 2010
                            • 15
                            just tried to find the 150uF 450v cap to get it ordered and no luck on digi-key at least im not seeing it.
                            • fadec
                              • Jan 2010
                              • 10
                              It would appear DigiKey does not carry that cap in a "radial". They only have snap-in type mounts. Just a quick search brought me to ICSupply. This is the only one they had that was not only "radial" and "wire terminated", but also in stock. Though be it slightly more expensive. You might want to do some measuring on that one to make sure it is close to the same size.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                The TSED Series P11674-ND will work, but there are several to choose from. When you are searching specify through hole, but nothing under package / case. All I see are radial snap-in, but it would be easy to run a pair of wires down to the board.
                                Or try Mouser.
                                PlainBill
                                • azack
                                  • Jan 2010
                                  • 15
                                  Thanks PlainBill running some small wires would work perfect!
                                  I think im going to replace the smaller ones and fire it up if that fails ill replace that big guy too.
                                  • fadec
                                    • Jan 2010
                                    • 10
                                    We have success! After reinstalling the PCB into the monitor, it started up normally. In the end I did not replace the 150uF 450v cap as it was the only cap that did not test bad.
                                    My only mistake... I think I broke a wire going the power button control on the front. As it does not work properly. I think it got broken when I pulled the screen out of the case to check the back lights. If you removed the back panel only, this should not be an issue.
                                    • azack
                                      • Jan 2010
                                      • 15
                                      Hey thats great news I guess a few of my parts are on back order. Sorry to hear about the power button thanks for the heads up.
                                      • azack
                                        • Jan 2010
                                        • 15
                                        Well I my parts got in and I had time today to put the new caps in. Well SUCCESS!!! everything works great. Thanks for all the help.
                                        • Viroslash
                                          Gateway gwnc31514 N14TB REV 1.2 KBC/EC Firmware request
                                          by Viroslash
                                          Hello everybody. I need EC/KBC firmware for Gateway gwnc31514. IT5570E-128 its shorted-ground.
                                          Board N14TB REV 1.2
                                          Intel i5-1035G1 (Ice Lake, 10th Gen).
                                          Thank you!
                                          Today, 07:25 AM
                                        • triplefour
                                          JVC LT-55UE76 has bulged cap on power supply, spilled electrolyte.
                                          by triplefour
                                          got this tv from a friend who got a new one and didnt want to bother repairing this one.
                                          he said it sometimes would just flash color patterns.
                                          and sometimes it would just work
                                          i figured it had some intermittent mainboard issue.
                                          i stored it at home for a while before looking at it
                                          when i plugged it in for the first time, i heard some popping noises
                                          and then a big cloud of white smoke came out of the back of the tv!
                                          i noticed the smoke didnt actually smell like anything. not like when an IC blows.
                                          i unplugged it and took the back off and discovered...
                                          12-18-2022, 12:38 AM
                                        • Kingpin!
                                          3COM OfficeConnect Gigabit Switch 16
                                          by Kingpin!
                                          3COM OfficeConnect Gigabit Switch 16 (3C1671600)
                                          The switch has served me for 10+ years (was new when I bought it). It's a nice switch with connections on the back which makes for quite a clean desk. Reason for taking it apart was that the cooling fan was noisy so I expected it to be dirty/dusty inside and the need to order a new fan. What I found was that it was very dirty/dusty and some electrolytic capacitors which needs attention. There are 3 capacitors which needs to be replaced but the ESR on some of the other ones might be bad as well so I think I'll replace them all. Original...
                                          09-17-2023, 04:58 AM
                                        • bjhnsonjr2734
                                          Gateway laptop model GWTN-156-7BL Needing Schematics
                                          by bjhnsonjr2734
                                          I am really needing Schematics for the motherboard on my Gateway laptop model GWTN-156-7BL
                                          I attached a pic of motherboard info
                                          04-25-2025, 07:01 AM
                                        • Dan John
                                          Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0) - (Possible) Multiple Issues
                                          by Dan John
                                          Greetings everyone,
                                          I have a Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0). The client said the battery was not charging. Upon checking the laptop,
                                          1) On pressing the power button, the (power button) light turns on and stays on.
                                          2) There is no boot, or anything on the screen.
                                          3) The fan starts and stops a few times, then it stops completely.
                                          4) The light on the power button remains on.
                                          5) Battery not charging (original issue).
                                          The original problem was that the battery was not charging, but the laptop still worked. My belief
                                          04-23-2025, 08:12 AM
