Gateway 24" LCD Model LP2407
+ More Options
Posts
  • USchabon
    • Jun 2016
    • 116
    Re: Gateway 24" LCD Model LP2407
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    20 Desk Top Switching Power Supply
    10 Desk Top Power Supply
    10 Battery Charger Switching Power Supply for Power Tool
    1 Battery Charger Power Tool Power Supply
    6 18v Lithium Battery Power Boards for Tool Battery Packs
    1 XBox 360 Switching Power Supply and M Board
    6 Servo Drives 220/460 3 Phase
    1 De-soldering Station Switching Power Supply 1 Power Supply
    1 Dell Mother Board
    10 Computer Power Supply
    1 HP Printer Supply & Control Board
    These two repairs where found with a ESR meter...> Temp at 50*F then at 90*F the ESR reading more than 10%
    1 Over Head Crane Current Sensing Board
    2 Hem Saw Computer Stack Board
    All of these had [bad] CAPs POOF
    All of the mosfet that are taken out by bad caps [also bad ones]
    Could it be a bad mosfet or two that need to be replaced somewhere? I guess we confirmed the power supply is ok with all the readings we gathered, so not there...
    But are power supplies the only place where there are mosfets?
      master hoarder
      • May 2008
      • 12170
      #102
      Originally posted by USchabon
      I "fixed" the cable with a lot of silicone applied in batches, little by little adding all the cables and making sure they weren't going anywhere. I plugged it in and applied a little more silicone to the cable since this will be is resting position. Once it dried up a bit I tested for continuity and I got a solid beep on each cable, between the connector on the power supply and the male connector that is soldered into the LCD inverter.
      Sounds more than good enough for testing.
      Everything checked out so I went for it and tested with the component out of the TV receiver...
      ...the menu lights up, but the screen stays full black all the time, through power up and no matter what I do.
      What gives now?
      Could it be that all along it was the backlight that died?
      Do you mean that you can see the monitor's menu/OSD controls on the screen? Can you see it well lit? (As if you would on a normally working monitor too?)
      If YES, then this is not a backlight issue.
      Another way to see if the backlight is working is to go in a dark room and turn on the monitor with a signal. If the monitor LED indicates that the screen is ON, then you should see the backlights in the screen turn ON as well. Even with a black image signal, you can still tell when the backlights are ON, because you should be able to see them "bleed" through the screen.
      (If you are not sure what I mean, try putting a black image on a working monitor. Again, do this while in a dark room. Even though the screen is displaying all black, you will see a backlight and/or slight glow from the screen - this is the backlight.)
      Feel free to post pictures of what you see as well.
      • USchabon
        • Jun 2016
        • 116
        No, the menu buttons are on the bezel. The screen didn't light up at all. I can tell when the backlight is on on this monitor, and it is not on at all. The backlight is not turning on for sure. Don't know if it is because it is dead or because something isn't telling it to turn on, but it is not coming on, with or without signal. Even without signal this monitor would display the logo for a few seconds, and the menu buttons would open the GUI menu which appears on the screen, and neither show up.
        • USchabon
          • Jun 2016
          • 116
          Where/how could I get a backlight? I guess I need to open it all the way and test the backlight somehow?
          • USchabon
            • Jun 2016
            • 116
            I can't seem to find one, or a used monitor for parts that can be confirmed to have a working backlight... do you guys have any links to sites that might have the part? And does it seem that it must be the backlight or am I wrong to assume that?
              Even if you have one or more bad lamps, the inverter circuit should fire up the lamps then the protection circuit will monitor to see if ALL the lamps start conducting (lamps flash on) and stay conducting, but if the one or more lamps do not stay on within 3seconds then the inverter protection will shutdown the circuit.
              So you at least see the lamps flash on for seconds if the inverter board is active.
              So what DCV do you have now on the inverter connector? At least one pin should have the 24V, then at least two more pins should have <5VDC (one for bl-on (>2.5V), one for DIM (between 1V or so ~4.5vdc)).
              DCV between the two legs of each of the two filter caps that you replaced on the inverter board? 24VDC?
              • USchabon
                • Jun 2016
                • 116
                I am having a hard time following your post, but please take a look at these measurements. Maybe the information you are asking me to gather is already here?
                Here are the readings for the cable going to what I've been calling the LCD board (the one with the Frankenstein soldering job )
                From left to right (moving up towards the LCD board):
                1. 0V
                2. 0V
                3. 0V
                4. 5.43V
                5. 0V
                6. 0V
                7. 23.3V
                8. 23.3V
                Here are the readings for the cable going to what I've been calling the logic board (the one with all the processors and the I/O inputs)
                1. 5.43V
                2. 5.43V
                3. 5.43V
                4. 5.43V
                5. 0V
                6. 0V
                7. 0V
                8. 0V
                9. 0V
                10. 0V
                Ok, I completely removed the LCD Inverter and the little USB board, I plugged in the logic board to the power board (flipped and on the back of my mouse pad) then I plugged in the power board and took all the same measurements as before:
                LCD INVERTER CN ON THE POWER BOARD (left to right towards LCD Inverter):
                1. 0V
                2. 3.28V
                3. 0V
                4. 5.18V
                5. 0V
                6. 0V
                7. 25.9V
                8. 25.9V
                LOGIC BOARD CN ON THE POWER BOARD (starting from the red cable)
                1. 5.18V
                2. 5.18V
                3. 5.18V
                4. 5.18V (also red)
                5. 0V
                6. 0V
                7. 0V
                8. 0V
                9. 3.28V
                10. 0V
                  1. 0V
                  2. 3.28V
                  3. 0V
                  4. 5.18V
                  5. 0V
                  6. 0V
                  7. 25.9V
                  8. 25.9V
                  So how about at the inverter board connector?
                  Also what DCV do you have between the two legs of the caps you replaced on the inverter board?
                  • USchabon
                    • Jun 2016
                    • 116
                    With all the boards plugged in and the cable plugged into the wall, I set the multi to 200 VDC and this is what I get on the connector on the LCD Inverter (starting with the red cable):
                    1. 29.9V
                    2. 29.9V
                    3. 0V
                    4. 0V
                    5. 4.7V
                    6. 0V
                    7. 3.2V
                    8. 3.2V
                    Between the legs of the caps I replaced (multi set to 200m VDC) I get 0.02V on both. This is with all boards plugged in and cable plugged into the wall.
                    I then unplugged the monitor and tested those caps again. The first one started at about 130 (multi set to 200m VCD) and it slowly went down to 0, then I tested the other cap and it said 0.
                      Your meter batteries must be low since you are getting 29.9Vdc feeding the inverter board, it should be around 24VDC.
                      The inverter fuse has to be bad, open circuit, because you are not getting the 24VDC on the two filter caps on the inverter board.
                      • USchabon
                        • Jun 2016
                        • 116
                        I'll go pick up a new 9V and post the readings again, but it was a new battery when I bought it around 1 month ago or less. Could be a bad one, could have left it on... we'll find out.
                        What does the inverter's fuse look like? Can it be swapped? Would make sense since the spark that jumped out of the socket when I messed up was about 3 inches long HAHAA
                          Fuse (White body with gold ends) designator is F1 as printed on the board right next to the inverter connector.
                          • USchabon
                            • Jun 2016
                            • 116
                            Cool. How can I make sure I order the right one? And can it be soldered in place?
                              Does it show very high resistance? If it does,then you may have done bad power MOSFETs the 8-pin SMD devices, that are shorted out. You will need to get the P/N so you can test the resistance between Source and Drain pins for low resistance readings.
                              • USchabon
                                • Jun 2016
                                • 116
                                How do I test the resistance for the fuse? If I set the multi to continuity and connect the gold sides and I get nothing
                                • USchabon
                                  • Jun 2016
                                  • 116
                                  I did the same at all Ohms ranges of the multimeter and got nothing on the fuse when touching both gold ends
                                    So you have blown fuse, so next thing you need to do is to check resistance between the two legs of those two filter caps to find out if it is showing >10 Ohms, if it does, then it can be solder bridge dues poor soldering works, shorted out power MOSFETs, you need to get the P/N of those MOSFETs.
                                    If they are shown as shorted circuit, then you need to get then new inverter board because I do not believe you can do surface mounted repair.
                                    • USchabon
                                      • Jun 2016
                                      • 116
                                      I set the multi to 20k and I get 2.63 and 2.64 on the caps. Does that mean the MOSFETs are fine because it is less than 10?
                                        We are looking for low resistance, so use 200 Ohms RANGE, so 2.63K Ohms mean you do not have shortes between the two legs of the caps.
                                        Right now it does not mean the MOSFETs are not shorted out until you check the resistance between the Source pin and the Drain pins of the MOSFET.
                                        • USchabon
                                          • Jun 2016
                                          • 116
                                          If I check the caps at 200 Ohms I get a 1 (to the left) on both caps.
                                          Which are the MOSFETs, and which are the source and the drain pins? I don't see anything like this on the LCD inverter board. Do you mean on the power supply unit?
                                          • triplefour
                                            JVC LT-55UE76 has bulged cap on power supply, spilled electrolyte.
                                            by triplefour
                                            got this tv from a friend who got a new one and didnt want to bother repairing this one.
                                            he said it sometimes would just flash color patterns.
                                            and sometimes it would just work
                                            i figured it had some intermittent mainboard issue.
                                            i stored it at home for a while before looking at it
                                            when i plugged it in for the first time, i heard some popping noises
                                            and then a big cloud of white smoke came out of the back of the tv!
                                            i noticed the smoke didnt actually smell like anything. not like when an IC blows.
                                            i unplugged it and took the back off and discovered...
                                            12-18-2022, 12:38 AM
                                          • Kingpin!
                                            3COM OfficeConnect Gigabit Switch 16
                                            by Kingpin!
                                            3COM OfficeConnect Gigabit Switch 16 (3C1671600)
                                            The switch has served me for 10+ years (was new when I bought it). It's a nice switch with connections on the back which makes for quite a clean desk. Reason for taking it apart was that the cooling fan was noisy so I expected it to be dirty/dusty inside and the need to order a new fan. What I found was that it was very dirty/dusty and some electrolytic capacitors which needs attention. There are 3 capacitors which needs to be replaced but the ESR on some of the other ones might be bad as well so I think I'll replace them all. Original...
                                            09-17-2023, 04:58 AM
                                          • bjhnsonjr2734
                                            Gateway laptop model GWTN-156-7BL Needing Schematics
                                            by bjhnsonjr2734
                                            I am really needing Schematics for the motherboard on my Gateway laptop model GWTN-156-7BL
                                            I attached a pic of motherboard info
                                            04-25-2025, 07:01 AM
                                          • Dan John
                                            Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0) - (Possible) Multiple Issues
                                            by Dan John
                                            Greetings everyone,
                                            I have a Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0). The client said the battery was not charging. Upon checking the laptop,
                                            1) On pressing the power button, the (power button) light turns on and stays on.
                                            2) There is no boot, or anything on the screen.
                                            3) The fan starts and stops a few times, then it stops completely.
                                            4) The light on the power button remains on.
                                            5) Battery not charging (original issue).
                                            The original problem was that the battery was not charging, but the laptop still worked. My belief
                                            04-23-2025, 08:12 AM
                                          • aes1111
                                            need bios for gateway GWTN156-12BL
                                            by aes1111
                                            Hello everyone, I have a laptop Gateway GWTN156-12BL, (XA133P rev 2.0) There was a crashed BIOS, I was able to find one for the GWTN156-12BK, and it rebooted. Can anyone share a BIOS dump for this model?
                                            S/N 2GWTN15612BL2J21J008090...
                                            01-02-2025, 07:23 AM
