Gateway 24" LCD Model LP2407
  • hectorbass
    • May 2010
    #41
    Re: Gateway 24" LCD Model LP2407
    Originally posted by Wrog
    Many posts here in this forum talk about the "two seconds to black" problem, and there are a few different solutions. The only way to become more knowledgeable is to read, read, read and then read some more. You'll need some basic test equipment (DMM or VOM) along with some basic electronic component knowledge to start. Once you're familiar with the nomenclature, ask questions on what you should do next and there are plenty of people here to assist. It would be incredibly frustrating to ask you to do something, only to have you say "How do I do that?" when it's been documented many times in other places.
    yeah i kind of figured that out. well thanks man.
    • norlando319
      • Jun 2010
      • 5
      #42
      Folks, first let me say "Thanks" to all who post questions and answers here. They have been very helpful!!
      Now, I am ashamed to admit, I made a mistake. Normally, when I don't have schematics or other indicators, I am very careful in removing caps, etc. to only remove one kind at a time. In this case, I screwed up a little, and of the five caps I took from the processor board, FOUR are 47uF 16V, and ONE is 100uF 16V. I feel like such an idiot, as I can't recall where the 100uF came from.
      C605, C334, C619, C223, and C 227 - of those five, one is a 100uF. Can anyone tell me which one?
      I've looked at the pictures in various places in the forum, but none of them have the lucky orientation to tell me which one is not like the others... *grin*
      Thanks, in advance!
      • norlando319
        • Jun 2010
        • 5
        #43
        Oh, even better, why don't I tell you WHICH monitor I am asking about! *lol*
        I am working on my Gateway FPD2485W.
        • tedj
          • Jun 2010
          #44
          c605 100mf 16v
          • sectoroverload2k
            • Jan 2011
            #45
            i ordered my parts on friday and got them in the mail monday afternoon! i only needed to replace a few, but i replaced all the capacitors anyway. Thanks to you guys i'm back up and running using my monitor in less than an hour! you guys are awsome!
            • xen-uno
              • Feb 2011
              • 3
              #46
              I too, have a Gateway FPD2485 (LP2407) 24'er (blt Nov 2006). Mine was working fine with no indication of problems when the screen went black, never to come back on again. Monitor startup with nothing connected has the normal Gateway sound, and the panel lights on right behave normally, just no picture. No burnt electronic smell either when it failed, btw. Per previous posts, I checked PS and Inverter. The Inverter's electrolytics were bulged (C1 & C3), and 3 of the PS's were too (C869, C870, and C865). Fuses fine on both boards.
              Local supply had enuff stock to replace the obviously bad ones, and about half the visually OK ones. I used higher voltage ones with same farad rating when exact match was not available. I've only replaced the bad ones so far. Still not working. Checked voltages to inverter ... nothing. Primary side of PS is alive tho ... as is secondary side after the 1st transformer. I'll do more voltage tests. One note tho ... my PS board has (5) of the 125degC caps (Su'scon @ C862, C863, C864, C867, and C868), which from DigiKey are sold in lots of 200 and are physically alot larger.
              I'm rather amazed (and skeptical) that ALL of fadec's caps were bad. Odd's of failing all at same time would be like me winning the lottery ... and I know thats not happening.
              • pedro
                • 199
                • AUSTRALIA
                #47
                Every time I see "local supply" or similar, I cringe. Most such sources do NOT stock suitable low ESR 105C caps. I trust that you didn't go that route, like RatShack or similar.
                Once ALL the electros (bar the large one) have been replaced with suitable caps - including the small ones that are often overlooked - it is then time to investigate the PSU outputs.
                Friends don't let friends buy Samsung ....
                • xen-uno
                  • Feb 2011
                  • 3
                  #48
                  Got them thru Warren Electronics (vs RadioShack) ... seem to be good ones (well ... Xicon, KME, San Ching, Jamicon and I heard San Ching makes nice Rolexes). My cap part numbers are in the 600's(M) vs fadec's 700's(M). I found radial 125degC's (Vishay's) in the capacitance and voltage I need, but they are not is stock from DigiKey (the 105degC Panasonics are in stock). Anyone know typical lead time when ordering non-stock items from them?
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    #49
                    None of those are suitable caps for power supplies.
                    You don't need 125C rated caps, just proper low ESR caps from either Panasonic, Rubycon, United Chemicon, Nichicon, Sanyo, or Samxon.
                    The KME's you mentioned above are likely United Chemicon - however that particular series (KME) is general purpose, not low ESR.
                    I recommend the following replacement caps for LCD monitors:
                    Panasonic: FM, FR, FC, and HFQ
                    Rubycon: ZL, ZLH, YXG, and possibly MBZ
                    United Chemicon: KZE, KY, LXY, LXZ
                    Nichicon: PW, PM, HE, HD
                    Sanyo: WX
                    As for Samxon, not sure which series are suitable. Check their datasheets. GC and GD might just work fine, though.
                    • xen-uno
                      • Feb 2011
                      • 3
                      #50
                      Thanks mom ... ordered Panasonic FM's and Nichi PW's. Replacing all the Su'scons on the processor/input board too. I'll lay the upper caps over (above uppermost heat sink where they were 125degC's originally), get them out of the main stream of hot air. I'm a little skeptical that this is going to fix it but it does eliminate a variable ... and it has worked for others. I see those 06xx(M) numbers are date stamps apparently.
                      • signcarver
                        • Feb 2011
                        • 4
                        #51
                        Thanks guys, I was experiencing 2 seconds to black and just finished replacing all the capacitors on the power (nearly all bulging) and inverter boards(both bulging)... all with panasonic FM's except the two 50V (47uF and 10uF for C876 and C857 in prior pictures) where my choices were FC's, or use the ones posted previously... digikey 493-3288-ND (Nichicon TS) and 565-1598-ND (United Chemi-Con KY). I had a harder time removing the caps from the inverter since the caps there lie flat with bent leads and had no rocking leverage (is there a trick/tip to this?). I didn't do processor/logic board or USB (hub) board. I also did not replace the large cap on the power board.
                        For the 50V's I ended up ordering both the FCs and the ones mentioned above but decided to use what someone already had luck with for that reason as well as it stated 5000 hours vs 1000 for the FC but I just noticed that the Nichicon listed was a TS series which I didn't see mentioned as "good caps" in the FAQ... would I have been better off using the FC's? I'm not sure I want to tear it all apart again while it is working better than ever.
                        I also wanted to mention that I made another silly mistake and put one cap in backwards but caught it when I double checked values and polarity prior to reassembling. I swear I put it in right the first time.
                        Now off to start a new thread to ask about a dell monitor that I temporarily used while waiting for parts.
                        • jetadm123
                          • 2169
                          #52
                          The TS series are not considered low-esr caps. You would have better off looking at the esr and ripple current ratings, which would have led you to the FC series.
                          As for the inverter caps, you can cut the leads and remove the cap. You can then pull the remaining lead off the board by heating the solder with your iron and pulling the lead out with a pair of pliers.
                          • alexanna
                            • Mar 2010
                            • 1346
                            #53
                            This is from a Gateway fpd2485/lp2407
                            This is the cable that connects the front panel switch to the logic board, I need a replacement.
                            Any ides where I could find one?
                            What would I call it when searching for it?
                            • Wrog
                              • Oct 2009
                              • 472
                              #54
                              It's called an FFC (Flexible Flat Cable), but they are pretty uncommon to find separately from the pcb. I'd suggest checking with ebay seller "bammbammfran", he seems to do a lot of work with these models and may have a spare. Good luck.
                              • drdenner
                                • Nov 2011
                                • 8
                                #55
                                I've had the exact same issue as everyone here, glad I found this forum! I'm ordering caps for all 3 boards, as I noticed bulging on not only the power supply but the mainboard and the left board that controls the backlights (2 caps).
                                I'll post again when I get some results.
                                Notes:
                                - Its VERY tricky to get the LCD's plastic housing off. I got it off but with many scratches and frustration. as the plastic clips holding it together are very tight.
                                - The cable to the front power button can rip out easily when you pull the casing off. Slowly remove casing and unplug power button cable before casing is completely off.
                                • philpalm
                                  • Mar 2012
                                  Someone's Gateway lp2407 went bad and I replaced the capacitors, and it worked for a while and went out again. One more capacitor 10V went in and now it is working.
                                  How do you get the computer monitor to be full screen? Is there a remote in order to change the settings?
                                  • jetadm123
                                    • 2169
                                    #57
                                    1) If there's an auto-adjust feature on the Gateway, give it a try.
                                    2) If the above doesn't work, try using the Windows software to increase the screen resolution.
                                    • USchabon
                                      • Jun 2016
                                      • 116
                                      I've had a lot of the symptoms described here and maybe a few more. I have two of these monitors and they behave slightly different, but at some point in time both had the logo that doesn't fade away for a long time, slow menu, slow switching sources... one of them also seems to need to warm up before A LOT of vertical lines of different colors disappear, but once it warms up it is the one that looks best of the two I have.
                                      This morning, the one without the colored lines, decided not to turn on. The menu lights lit up, and if I switched sources cheating off the other monitor the lights seemed to respond normally, but the LCD remained black no matter what.
                                      I found this forum (thank you for all your posts!) and cracked the f'ker open (somewhat carefully) without much trouble. I found three bulging caps in the Power Control board, and two on the LCD board. I may be getting the names wrong, but I'll attach photos.
                                      I bought a cheap multimeter recently, and though I am not sure how to test the caps I am game if someone would help me figure that out.
                                      I plan to buy a soldering kit, and could use help picking one out. I am not looking for a pro setup, and hoping to spend around $20 or so, but I do need something that will make the job relatively easy. I am meticulous and good with my hands. I have watched people solder before, but this will be my first time soldering a board. I have to admit I am having fun with this, sans the freaggin' thing not working...
                                      Could someone please help me:
                                      1. Make sure I order the right caps per the photos attached (I guess I should replace ALL power control caps, but if it makes sense I would like to just do the bulged caps and see if I can use it for a couple more years)
                                      2. Teach me how to test caps, hopefully before removal
                                      3. Pick the right starter but decent soldering kit
                                      • USchabon
                                        • Jun 2016
                                        • 116
                                        Oops, I forgot to add the photos.
                                        Here they are:
                                        • USchabon
                                          • Jun 2016
                                          • 116
                                          I still feel a little lost but I went ahead and placed this order based on what other's ordered. I don't think the big cap is included so I hope that mine isn't damaged. I also doubled the order to be prepared for when the other monitor takes a crap. I am tempted to do both but don't want to mess with it unless it dies since the colored vertical lines always go away once it warms up and it has less menu issues that always go away with a quick unplug.
                                          Here is my order:
                                          • triplefour
                                            JVC LT-55UE76 has bulged cap on power supply, spilled electrolyte.
                                            by triplefour
                                            got this tv from a friend who got a new one and didnt want to bother repairing this one.
                                            he said it sometimes would just flash color patterns.
                                            and sometimes it would just work
                                            i figured it had some intermittent mainboard issue.
                                            i stored it at home for a while before looking at it
                                            when i plugged it in for the first time, i heard some popping noises
                                            and then a big cloud of white smoke came out of the back of the tv!
                                            i noticed the smoke didnt actually smell like anything. not like when an IC blows.
                                            i unplugged it and took the back off and discovered...
                                            12-18-2022, 12:38 AM
                                          • Kingpin!
                                            3COM OfficeConnect Gigabit Switch 16
                                            by Kingpin!
                                            3COM OfficeConnect Gigabit Switch 16 (3C1671600)
                                            The switch has served me for 10+ years (was new when I bought it). It's a nice switch with connections on the back which makes for quite a clean desk. Reason for taking it apart was that the cooling fan was noisy so I expected it to be dirty/dusty inside and the need to order a new fan. What I found was that it was very dirty/dusty and some electrolytic capacitors which needs attention. There are 3 capacitors which needs to be replaced but the ESR on some of the other ones might be bad as well so I think I'll replace them all. Original...
                                            09-17-2023, 04:58 AM
                                          • bjhnsonjr2734
                                            Gateway laptop model GWTN-156-7BL Needing Schematics
                                            by bjhnsonjr2734
                                            I am really needing Schematics for the motherboard on my Gateway laptop model GWTN-156-7BL
                                            I attached a pic of motherboard info
                                            04-25-2025, 07:01 AM
                                          • Dan John
                                            Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0) - (Possible) Multiple Issues
                                            by Dan John
                                            Greetings everyone,
                                            I have a Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0). The client said the battery was not charging. Upon checking the laptop,
                                            1) On pressing the power button, the (power button) light turns on and stays on.
                                            2) There is no boot, or anything on the screen.
                                            3) The fan starts and stops a few times, then it stops completely.
                                            4) The light on the power button remains on.
                                            5) Battery not charging (original issue).
                                            The original problem was that the battery was not charging, but the laptop still worked. My belief
                                            04-23-2025, 08:12 AM
                                          • aes1111
                                            need bios for gateway GWTN156-12BL
                                            by aes1111
                                            Hello everyone, I have a laptop Gateway GWTN156-12BL, (XA133P rev 2.0) There was a crashed BIOS, I was able to find one for the GWTN156-12BK, and it rebooted. Can anyone share a BIOS dump for this model?
                                            S/N 2GWTN15612BL2J21J008090...
                                            01-02-2025, 07:23 AM
