vp2130b cap help
  • endevite
    • 48
    vp2130b cap help
    This is to solve the monitor slow start 1.5minute problem on vp2130b, cracked open and a heap of bad caps were found.
    Ok here goes, on the inverter board are 3 CapXon GF 35v 180uf 8x16.5 caps, the CapXon datasheet for GF series does not show ripple max or anything for the 35v 180uf caps as if they never existed.
    I was looking at chemi-con LXY series 50v 180uf caps, as it has higher ripple support for the 220uf vs 220uf on GF vs LXY (compared the 220's because I cannot find data on the 180's), anyone else have any input?
    Also there is a Taicon (PW)P cap (not bad but don't trust) on the powersupply that I cannot identify due to glue which took the label with it, the top of the cap I can see what looks to be the tail end of *5v 220uf, it measures 8x12mm and bright green. Could it be 25v? Nichicon PW series 25v 220uf 8x11.5 @ 555 ripple seems closest?
    Also for anyone who runs into this monitor (same guts as 2030b from what I understand), on the mainboard, all green Teapo caps are blown, 6x 25v 100uf Teapo SC 6.3x11mm and 2x 6.3 1000uf Teapo SM 8x15mm. USB board had no blown caps but I've read all six 25v 100uf 6.3x11mm Teapo SC series go on the usb board, so I'll be replacing those as well.
    List as follows,
    12x Teapo SC 25v 100uf 6.3x11mm 250 Ripple 0.220 ESR
    2x Teapo SM 6.3v 1000uf 8x15mm 850 Ripple 0.053 ESR
    3x CapXon GF 35v 180uf 8x16.5 ???? ????
    1x Taicon (PW)P *5v 220uf 8x12mm ???? ????
    Pictures included, and any cap replacement advice would be appreciated.
    (psu1 and psu2 images show the green cap, inverter shows the 180uf 35v, and the mainboard images show the 6 bad 25v 100uf's and 2 bad 6.3v 1000uf's)
  • endevite
    • 48
    Re: vp2130b cap help
    Wont let me edit again, can someone update the title to "Viewsonic vp2130b cap help", thank you.
    • endevite
      • 48
      Update found the capxon 35v 180uf info, 810ripple low impedance. the chemi-con lxy 35v 180 has only 550 ripple and the 50v is to large, kze is no go aswell.
      Any suggestions on a 180uf low imp cap with 810 or better ripple that fits in the department of 8x16? Perhaps a LXZ 50v 180uf 10x16 ELXZ500ESS181MJ16S?
      • endevite
        • 48
        Even though it has a higher rated impedance. 0.13 /0.26 vs the capxon 0.098/0.28.
        • endevite
          • 48
          Anyone have any input at all? Should I just go with that cap?
          • Tiger5007
            • Jan 2010
            • 4
            i have the same monitor. it was okay until last summer. once it's on for awhile it just turns off and the seconds later back on. so i was assuming the inverter had problems. i was poking around to find the 3 replacement caps 180uf 35v capxon, that's how i ended up on this site. did you find an answer yet? i could use some help with fixing my monitor too. thanks.
            • endevite
              • 48
              I believe I have come up with an answer, should be a simple enough fix, I will have pictures and part numbers posted once the parts show up, ordered them sunday, so they should be here soon.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Not sure what advice to give you about the CapXon GF caps. In some circuits, ESR and Ripple ratings might be more important than the uF rating, in others it might be the other way around. Do you know how the caps are connected on the board? If those CapXon GF caps are just part of the filter for the main power supply, it probably will be better to stick to similar ESR and Ripple ratings. In that case, going up a notch on the capacitance *might* not hurt the circuit (the next value up is 220uF which is just slightly over 20% of the original 180uF value).
                I looked up some 220uF 35v caps, and the closest I could find that would meet the specs of those CapXon GF (assuming their ratings are not bogus - and they could as well be) was Chemicon KZE 220uF 35v in a 8x15 size. Ripple and ESR for those are 0.056/0.17 mOhms and 995mA respectively.
                • endevite
                  • 48
                  Jist of it is a close match to the ratings of 3x CapXon GF Caps in parallel (as the inverter circuit runs them in parallel) @ 32.667mohms total, 180uf ea @ 540 total, 35v and 810 @ 2430 total ripple max. The fix rates at 50v KY 2x120uf/2x150uf caps, with clearance @ 540uf total and 30mohm total , 2980 total ripple. The new caps are also 7k hour rated vs the 3k hour rated originals. The fix? using 4 caps instead of 3, I'll test it before giving part numbers and pictures but all and all should be very easy for anyone to do.
                  There is no clean fix drop in for the 35v 180uf capxon GF series caps, their designed ratings are pretty unheard of, most options involve caps that wont fit physically or are way way off in ratings. I've gone over every datasheet for just about every reliable low impedance low esr cap from the moderate to the high end of what you can buy.
                  You could go with a 220 and a 330 and end up with a 550uf rating but impedance way way lower than spec, or you could go with a 120/150/270 combo but then space becomes an issue. The only thing that really fits is a 120/150 - 120/150 setup with a bridge on the second 120/150 set to makeshift a center position mounting point 270.
                  Space wise 8x15,10x12.5,8x15,10x12.5 setup works best. Again I'll have photos posted once I have the replacement caps.
                  Here is a picture of the proposed augment in mind, back of the board of course, red is existing cap positions, blue lines are bridges on the top of the board, green is the augment cap location, pink is the jumper setting the 7.5 rating for the ccfls.
                  • tj2
                    • Oct 2009
                    • 85
                    That CapXon GF has an 0.098 Ohm ESR.
                    Nichicon HE 50 V 180 uF 8x15 has 910 mA ripple and 0.091 Ohm ESR. It looks very close to what you want.
                    You could also go with Panasonic FMs, 35 V 220 uF or 150 uF, both 8 mm diameter. Their ripples are 1240 and 950 mA respectively and their ESRs are 0.041 and 0.056 Ohm. The only trouble here is that you are changing the capacitance a little bit.
                    Both the Nichicon HE and Panasonic FM series have relatively large endurances, too.
                    • endevite
                      • 48
                      My planned fix maintains the correct capacitance, keeps the impedance near stock, and has a higher ripple rating, and uses KY's for the 7k hour rating.
                      • endevite
                        • 48
                        My notes on cap compares and what fits and what wont.
                        32.667 Milliohms old 180uf 35v GF capxon x3 2430ripple 540uf total
                        12.692 Milliohms with FM 50v 220 + 330 3800ripple 550uf total
                        or 120+150+270 = 540
                        KY = 30.248 Milliohms, 2750 ripple
                        8x15,10x12.5,10x20
                        ZL = 15.124 Milliohms, 3509 ripple
                        8x16,10x12.5,10x20
                        YXG = 30.248 Milliohms, 2750 ripple
                        8x16,10x12.5,12.5x16 or 10x20 -20 ripple
                        35v FC = 31.447 Milliohms, 2160 ripple low ripple
                        theory two
                        4x caps, 120x150x120x150
                        50v YXG = 30 Milliohms, 2980 ripple 4/5k hours
                        8x16,10x12.5,8x16,10x12.5
                        50v KY = 30mohm, 2980 ripple (7k hours)
                        50v FM = 10.862 Milliohms, 4848 ripple
                        (3k,4k hours)
                        35v FC = 29.25 Milliohms,2220 ripple to low ripple
                        8x11.5,8x11.5,8x11.5,8x11.5
                        50v FC = 33.659 Milliohms, 2970 ripple ohm to high
                        50v ZL = 15.25 Milliohms, 2908 ripple 3/4khours
                        50v HE = 30 Milliohms, 2250 ripple ripple to low
                        concept 3 (must be 0.08 or lower on the 150)
                        mix 2 cap types of 150 vs 390
                        KY 150@0.12 + LXZ 390@0.054 = 37.241 Milliohms, 2260ripple
                        10x12.5,10x30 = dont work
                        FM 150@0.042&1170rip + LXZ 390@0.054+1500rip = 23.625 Milliohms,2670rip
                        4k/7k hours
                        10x12.5,10x30
                        or 270+270 12.5x15
                        HE or KY 50v = 30.5 Milliohms, 2520ripple @7k hours, wont fit
                        • endevite
                          • 48
                          For the record, the caps I evaluated for probable fix, are,
                          HE,KY,ZL,YXG,FM,PA,LXV,PW,FC,KZE,LXY
                          favoring ruby, pan or chemi-con of course.
                          • endevite
                            • 48
                            Little bit of a research update, samxon 180uf 35v/50v GF series caps would work as a direct drop in, but they are only 3k hour lifespan, hard to find, and I'm unaware of reliability with this series.
                            • endevite
                              • 48
                              Rubycon ZLJ 180uf 35v 8x11.5 has better ratings almost all the way around, slightly lower impedance, and are 9k hour rated. But hard to find.
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                The endurance/lifespan rating is only important if you're going to run the cap at the maximum rated voltage, ripple current, and temperature. Lower any of these a little bit and the cap might last much longer than that (if you think about it, 9000 hours is just slightly more than a year - and we know that even caps with lower endurance/lifespan almost always last much longer than that).
                                • endevite
                                  • 48
                                  Long life rated caps are always good for inverters, they are given that life rating based on max stress, lower stress just means more life span, it's just more or less a rating on the fluids durability, but it's not just that for those ZLJ's, they are also 1200 ripple rated per 35v 180uf cap, low frequency ripple curve, and they are decent on impedance (lower than capxon gf's but not to far from spec).
                                  • endevite
                                    • 48
                                    Monitor all fixed and works like a champ kicking on nearly instantly without any oddities.
                                    Here is "a" fix using cap's that you can actually buy in the states.
                                    Alternatively if you can get them, Rubycon ZLJ's work as perfect replacements with much better ratings for the inverter.
                                    I will cover the powersupply, usb, and mainboard recap info on following posts. The job in total involves 21 caps to be replaced that's including the 4 on the inverter.
                                    This fix is specifically for inverter board INV20-6009 found in the Viewsonic vp2130b and vp2030b monitors.
                                    It involves using 4 caps in place of the original 3x CapXon 35v 180uf caps with a rating of 810ripple support and 91miliohm, all 3 caps are run in parallel.
                                    The CapXon stock ratings for these particular GF caps is as follows,
                                    3k hour rated
                                    810 ripple ea, 2430 ripple total
                                    98 miliohm ea, 32.667 Milliohms total
                                    Freq Ripple
                                    0.72@120hz, 0.90@1k, 0.98@10k and 1.0@50to100k
                                    Cap's used in fix, NCC (Chemi-Con) KY series
                                    2x 120uf 50v and 2x 150uf 50v
                                    2x EKY-500ELL121MH15D 50v 120uf KY
                                    2x EKY-500ELL151MJC5S 50v 150uf KY
                                    digikey part#'s
                                    565-1602-ND
                                    565-1603-ND
                                    120uf Stats
                                    7k hour rated
                                    730 ripple ea, 1460 total
                                    150uf Stats
                                    7k hour rated
                                    760 ripple ea, 1520 total
                                    2980 ripple total from all 4 caps
                                    All 4 caps have are 120 miliohm
                                    But total at 30 Milliohms being in parallel @ x4 instead of x3
                                    Freq Ripple
                                    0.40@120hz, 0.75@1k, 0.90@10k, 1.0@100k
                                    All in all you get 30miliohm instead of 32.667 and slightly higher Ripple support, lower ripple frequency multiplier and a longer life span while maintaining the same capacitance.
                                    Now for the pictures, Original has the crappy green GF CapXons, following will be board with 3 new KY caps (150,120,empty spot,150), then a picture of a single cap with bent legs and lastly a couple images showing the finished bridge to make it a 4 cap repair job. The back of the board shot is also included so you can see the parallel circuit.
                                    When you put the 8x15 cap on the 10x12.5 cap on the right side to make the bridge, bend the legs just right so you get as much contact as possible for a good joint, also wire wrapping with some 30awg silver kynar wouldn't hurt.
                                    • endevite
                                      • 48
                                      Ok for the Powersupply, all my caps were good, however A Taicon existed that I did not trust, so I replaced it. Other powersupplies have been known to have bad caps however mine did not, but you can find those searching these forums.
                                      This is for powersupply EADP-64BF on the Viewsonic vp2130b, may also be the same powerboard in the 2030b.
                                      Cap replaced
                                      Taicon PW(P) 25v 220uf (Best info I could find anyway)
                                      8x11.5 234miliohm 555 ripple 3k hr rated
                                      Ripple Freq
                                      0.65@120hz, 0.85@1k, 1.0@10k+
                                      Replaced with
                                      1x EKZE250ELL221MHB5D 25v 220uf KZE
                                      Digikey part#
                                      565-1674-ND
                                      8x11.5 72miliohm 760 ripple 3k hr rating
                                      Ripple Freq
                                      0.50@120hz, 0.73@1k, 0.92@10k 1.0@100k
                                      Removing the old cap will require using a dental pick or something of the sort to pick off the white nasty glue and scrap it off for clearance for new cap.
                                      • endevite
                                        • 48
                                        Correction on the cap on powersupply fix,
                                        ripple freq table I believe is
                                        Ripple Freq
                                        0.50@120hz, 0.75@1k, 0.90@10k 1.0@100k
                                        • chth96
                                          Is it no harm to replace with capacitor without ripple current rating?
                                          by chth96
                                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                          Rubycon YK DataSheet (b...
                                          04-19-2024, 05:19 AM
                                        • iMic
                                          IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
                                          by iMic
                                          Hi folks,
                                          I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
                                          The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
                                          11-29-2023, 06:44 AM
                                        • bauto601
                                          KDM 480W PSU upgrade succes! (opinions?)
                                          by bauto601
                                          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                          A "nice" YoungYear unit? - Badcaps
                                          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                          12-26-2023, 03:05 PM
                                        • Antonynl
                                          What are typical ripple voltages on a laptop motherboard?
                                          by Antonynl
                                          I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                                          So I have two questions:
                                          1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                                          2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                                          Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                                          12-09-2022, 06:51 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
