Need to identify transistor on Chimei M220Z1-L03
  • seascoot
    • Oct 2010
    • 5
    Hi all.
    I have a burned out transistor on the integral t-com board of a Chimei TFT panel. The panel is a M220Z1-L03 and the board is labelled M$35-D024790. Since the component is burned out I can't read any ID on it. It is marked Q4 on the board.
    Any chance someone can ID this or direct me to a schematic? I googled all over the place, but could find nothing.
    Would also appreciate any views on the likelihood of having success by just replacing this transistor.
    Thanks!
    Re: Need to identify transistor on Chimei M220Z1-L03
    FP5139 is a boost converter, so that burnt out is the power MOSFET.
    https://cdn.badcaps-static.com/pdfs/...40c89c0962.pdf
    Do the serch for application circuits to see if some of them will give the spec for the MOSFET.
    • seascoot
      • Oct 2010
      • 5
      @budm. Thanks very much for pointing me in the direction of the FP5139.
      I ran Google searches for boost control and totem-pole/push-pull gate driver circuits using similar components, but came up with nothing that had MOSFET specs in that range. My electronics skills are too limited to be able to extrapolate from what I found and come up with appropriate specs.
      • CapLeaker
        Leaking Member
        • 8221
        probably nothing too fancy, n channel Mosfet 30v or 40v, 2-3 or so amps rated. just make sure the gate drive circuit isn't damaged. check source and drain to gate. if its shorted, check the whole gate drive.
        • seascoot
          • Oct 2010
          • 5
          Thanks @CapLeaker.
          I managed to find the attached schematic that seems to apply, but many of the labels are illegible. Posting here in case it helps others.
          Could be that the MOSFET is AP2306AGN-HF which is no longer produced. I just ordered some others having similar specs to try - PMV37EN2R, PMV28ENEAR, A03424.
          • R_J
            • 9558
            any N-channel 3~5 amp mosfet should work, AP2304GN-HF, AO3404
            I found this...
            • CapLeaker
              Leaking Member
              • 8221
              yeah, as rj and i said before... its nothing fancy at all. you shouldn't have any problem finding a substitute and get that to work again.
              • R_J
                • 9558
                I just checked a panel I have and it has a sot23-3 marked NAT3 for that transistor, and another panel with it marked 106W
                There are similar circuits that use a SOT-89-3L (CJA9452) mosfet
                • CapLeaker
                  Leaking Member
                  • 8221
                  geez RJ... you got spares for everything!
