Motorbike PCB - burned Diodes ( PJ78) - help to identify identical or equivalent
  • magneh
    • Apr 2014
    • 626
    • Portugal
    Hello everyone
    Got a motorbike PCB that had 3 burned diodes.
    The smaller ones have the marking PJ78 GS1M
    And one larger one PJ78 GEX
    Can someone help me identify them so I can be able to replace with same or equivalent?
    Photos attached
    Apreciate !
    Thank you
  • lotas
    • Jan 2016
    • 4861
    • Russia
    Manufacturer PANJIT Semiconductor
    GEX is 1.5SMCJ22A
    GS1M is GS1M-AU.​
    • magneh
      • Apr 2014
      • 626
      • Portugal
      GEX is 1.5SMCJ22A
      GS1M is GS1M-AU.​
      Thank you lotas!
      Ordered replacement ones
      • magneh
        • Apr 2014
        • 626
        • Portugal
        GEX is 1.5SMCJ22A
        GS1M is GS1M-AU.​
        Replaced and working again
        • Dvsr
          On M-Audio AV40 active studio speaker's two zener diodes get really hot.
          by Dvsr
          Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
          I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
          After replacing the caps I started testing out the speaker. It seemed...
          09-10-2025, 10:20 AM
        • corrize
          Identify a burned component in Gimbal Zhiyun smooth-q3
          by corrize
          Hello, in this device, there is a chip (managing battery I guess) burned.
          I can’t read the full marking code because it is really damaged/burned.
          With a best pictures, I deduced that :
          8HA (or 5HA ?) and probably not 2HA or EHA or BHA
          K20
          296
          But I can’t find a component on the web with these marking code. Do you know what it is please ?...
          11-12-2025, 02:57 AM
        • deep000
          Burned Voltage Regulator in Monitor – How to Identify and Repair?
          by deep000
          My computer monitor ASUS VP249H stopped working, and smoke came out of it.
          I opened it and found that a voltage regulator had burned out.
          The problem is that I can't identify its reference.
          I searched online for schematics or photos of similar boards that people are selling, but without success (no schematics, bad quality of the board or lack of the reference when it's a good quality 😅).
          How can I find its reference, and do you think it's repairable?
          Monitor: Asus VP249H
          Board reference: 0171 - 2271 - 6083
          09-08-2024, 01:13 PM
        • cinkoxid
          Atorch UD18 DC adapter Burned smd component. I can't identify it
          by cinkoxid
          Hi guys,
          I wanted to test a DC adapter and I plugged it into my device and then I immediately smelled the cooked component. I cheked the adapter again and I discovered that it's not a DC but a 24V AC adapter
          I took apart my tester and I think I found which component burned but I can't identify it for sure and I'm not sure where could i buy a replacement part which is the same or has similar features.
          I attached a few pictures of the component. I think it's a voltage regulator but some of the markings on the component are burned.
          Name of the...
          01-30-2023, 09:43 AM
        • smic717394
          MSI Optix MPG27CQ half screen working. Identify burned component
          by smic717394
          I have a MSI Optix MPG27CQ screen to fix, only half screen is working, I found a burned chip on the right buffer board (S270DP01V00_HF_SR) but I can't read the model. Can anybody help?...
          04-08-2025, 05:53 AM
