HP L1955 no display following wake from sleep
  • dimsim
    • Nov 2009
    • 9
    One of my L1955 monitors has just started to not wake up from power save or sleep. I have been able until now to simply either switch off or remove the power cable then re-power which will make it work again until the next power save or sleep time. The green power led lights all the time (dims slightly when the display appears) then the backlight appear to turn off and the power led stay on. It now also just perodically dies, still with the green led lit with text visible by torch.
    I had another one which totally burnt something out on the power board (see attached P107490) and i swapped the power board out of a working display into that and it worked perfectly. I've since swapped the power board from this one into that and get the same problem so assume it is something wrong with that board and not anything else.
    Does anyone have any ideas where i should start? The CAPS as far as I can see are ok.
    Photos of boards attached.
  • leekh
    • Jan 2007
    • 24
    Re: HP L1955 no display following wake from sleep
    replace all the brown and green caps on the power board. both of these brands are known to give problems.
    • dondrusco
      • Apr 2009
      • 89
      Burned c5707 is common problem of Benq power boards due to cold joint
      https://www.badcaps.net/forum/showthread.php?t=6692
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        looks like the 5707's burned or the cap in between them.
        some of those plastic box caps were trouble too.
        but most blowups in these is brought on by bad solder joints on the ccfl transformers and the 5707's
        • dimsim
          • Nov 2009
          • 9
          Wow! Thanks for everyones input, these boards really have issues then huh.
          Last nite following another switch on/off I got the burning smell and a puff of smoke, I quickly removed the power, disassembled and found the C5707s on Q808 & Q809, the R75 MKP on C824 and the D10pf on Q805 all with some kind of heat damage. The D10pf on Q812 also looks like its had some heat so I guess its just a matter of time until that goes along with the 5707's on Q815 & Q816 & the R75 MKP on C825
          On the previous board that had failed and had a major burn out right through the PCB it was Q808/9, Q805 & C824, so same fault, but others have mentioned that Q815/6 have failed on them.
          So to sum up, it would appear that I should
          Replace the 2x D10pf at Q805/Q812
          Replace the 4X C5707 at Q808/9 & Q815/6
          Replace the 2X R75 MKP at C824/5
          Resolder the 9 joints on T801/2/3/4
          and
          Replace all the brown and green caps?
          Sounds like a lot of work huh? Especially for a newb like me.
          If I do all this does anyone know if anything else is likely fail?
          Also any recommendations for the replacement components?
          • Bobdee
            • Jun 2008
            • 461
            Possibly Inverter transformer damage after that burn up
            I would add to your list C801+c802, also a few PF701 fuses as the one on your board is no doubt open
            Resolder all four of the Inverter transformers, and check the whole board for bad solder cracks etc
            • dondrusco
              • Apr 2009
              • 89
              Q805, Q812 - be careful, they are MOSFETs - sensitive to static electricity.
              I damaged them during resoldering
              • nickBcap
                • Jan 2012
                • 114
                • New Zealand
                Hi, dimsim - have you an idea as to what the burning smell may have been. I found no evidence of burning anywhere and guessed it would be a capacitor from my short experience. But no capacitors are bulging and no burn marks anywhere. Maybe there is slight browning somewhere.
                I bought an HP L1955 for NZ$44 and it worked ok for about one week and turned it on one day and smelled an unusual burning smell. Turned the monitor off very quickly and now wondering would replacing the 13 capacitors on the power board get it working again?
                I can remove all those capacitors and identify them and buy replacements but will it work? Maybe I got to turn it off before any major damage occurred.
                • Rtech
                  • Jul 2010
                  • 1095
                  There used to be a tongue in cheek method of fault finding which was 'Tune for maximum smoke',and although I am not a supporter of doing that,the information you give does not help to pinpoint the problem.You need to connect Computer and Monitor as normal, apply power, advise how the Power Led reacts,ie comes on,changes colour. stays steady etc etc, what is going on with the screen, if anything ?
                  • nickBcap
                    • Jan 2012
                    • 114
                    • New Zealand
                    When I plug the monitor in and power it on the power LED on the front panel lights and does not change until I press the AUTO button and then it lights brighter, perhaps it lights green, but brighter, and nothing changes on the screen, the screen remains black.
                    When I was first using the monitor it worked very well and I played first person shooter online games with the monitor.
                    • Rtech
                      • Jul 2010
                      • 1095
                      If you have a PC connected to it,why press auto??the Monitor should pick up the PC signal and the Led should change colour to confirm the Monitor has recognised it.As far as I am aware.all of the Monitors/TVs etc Have dealt with have had this facility.The performance of the Led is the first step in trying to find a place to start fault finding.
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • GLISIT
                        by GLISIT
                        01-16-2025, 02:29 PM
                      • Bonaventure Vigil
                        ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                        by Bonaventure Vigil
                        Dear All,
                        Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                        At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                        12-12-2024, 10:22 AM
                        DELL XPS 9560 Notebook 15 Specification for Upgrade or Repair
                        This specification for the DELL XPS 9560 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9560 boardview and 9560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9560 Notebook...
                        09-06-2024, 05:46 AM
