Hp L1925 lcd monitor black screen
    Re: Hp L1925 lcd monitor black screen
    Once we get the P/N of those 8-pin MOSFET, then we can tell you where to check the voltages, any P/N for that PWM IC? Is it really OZ960 as shown in the diagram that selldoor posted?
    By the way, that blue wire, it looks like it is connected to pin 8 of the IC, PIN1 of the IC is on the top right with indentation at the corner of the IC.
    Per app notes of the IC, it should be hooked up to PIN 17 through a resistor which determine the running frequency of the circuits.
    The other end of the cable is hooked up to the ground pin of the white connector, if that is the case, the Oscillator will not be running.
    This is all based on the Diagram as posted.
    • selldoor
      Slow Learner
      • 7870
      #42
      It looks like an OZ960G to me
      • turmix
        AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
        by turmix
        Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
        The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
        At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
        During another reassembly, I made a mistake, and...
        01-29-2024, 03:48 AM
      • HTR-Informatique
        by HTR-Informatique
        02-09-2025, 06:51 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • DaniK
        Acer Aspire E5-574-52RH - black screen
        by DaniK
        I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
        Laptop came in for a SSD upgrade, took everything apart to install the SSD.
        Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
        Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
        The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
        Symptoms are:
        - random black screen after displaying Acer logo...
        02-21-2024, 06:27 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
