Backlight Rapidly Flashing - 23" Cinema Display
  • koerneka
    • 33
    Hi All,
    Haven't posted in years, but happy to see these forums are still active! Anyway, I have a 23" Apple Cinema Display which is exhibiting a weird issue. When connected to a known-good power supply and video source (as tested with its sister display), the unit powers up and displays video, however, the backlight flashes/strobes on and off approximately twice per second. There is a small, audible noise which accompanies this activity.
    I consider myself to be competent with displays and TVs, having successfully repaired many of each, this issue is something I've had a harder time tracking down. I'm thinking this sounds like an inverter issue of some sort - like something is shorting or pulling down the voltage.
    I know this is an older display, but I'd love to be able to get it running again. Thanks in advance!
    Re: Backlight Rapidly Flashing - 23" Cinema Display
    Please upload good clear pictures of the boards and how all the boards are connected together, that will be a start.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      https://www.badcaps.net/forum/showth...t=Apple+Cinema
      • koerneka
        • 33
        Thank you for your responses.
        Budm - I will get pictures uploaded as soon as I can.
        Vinceroger69 - I've seen that thread, which is about troubleshooting the power supply, not the actual display. The power supply I have works just fine on another unit.
        • learnmore
          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
          by learnmore
          Hello Community!
          CASE DETAILS
          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
          Tried inserting firmware on USB and left it in for a few hours, but no change
          03-03-2024, 09:49 AM
        • HTR-Informatique
          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
          by HTR-Informatique
          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
          I also changed the screen because the PC fell and the screen was broken.
          I changed the battery with a new and original battery.
          I also had corrosion/oxidation on the...
          02-09-2025, 06:51 AM
        • signal.quest
          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
          by signal.quest
          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
          03-17-2024, 10:14 AM
        • ikelectro
          After bios recovery by pen drive HP15s eq0007AU display flashing a light for short time.
          by ikelectro
          Schematic : DAOP5EMB6E0 REV:E​
          I have tried manually flashed the bios, also tried hp bios recovery tools to recover the bios. But no luck. Display is not coming, 3 to 4 times recovery display is coming if I tried to recover by pen drive[win+ B]. But after restarts it goes to dark screen and a light is flashing after a certain time in the display + fan speeds increasing and decreasing. I have tried almost every bios for this motherboard avaiable in the internet.
          Any help or guide to proceed?...
          03-19-2025, 08:17 PM
        • lanovey
          SF314-41 BIOS without internal display
          by lanovey
          Hello there,
          I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
          I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
          06-13-2025, 02:38 AM
