Issue with Westinghouse 19" LCD Monitor (large pics)
  • kahless
    • Sep 2010
    #301
    Re: Issue with Westinghouse 19" LCD Monitor (large pics)
    W2X
    Q208 is W2T.
    • jetadm123
      • 2169
      #302
      Originally posted by kahless
      W2X
      Q208 is W2T.
      Thanks for the info!
      • eiznekcm
        • Oct 2010
        #303
        I am working on a Westinghouse TV with board DAC-19m015. It has a nice little burn spot where L105 used to be. Can anyone tell me what is supposed to be there? Thanks in advance. :-)
        Craig
        • retiredcaps
          • Apr 2010
          • 9271
          #304
          L105 => L => inductor.
          --- begin sig file ---
          --- end sig file ---
          • EGuevarae
            • Nov 2008
            • 1336
            Agree. L is for an inductor. You can see one in one of your pics ...
            There are 10 kind of people in this world: those that understand binary, and those who don't.
            • ASUS ROG Maximus IX Code
            • Intel Core i5-7600K 3.8GHz
            • 16gb GSKILL TridentZ RGB DDR4-3200
            • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
            • Windows 10 Pro x64
            • GeForce GT1050
              2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
            • eiznekcm
              • Oct 2010
              #306
              That's what I thought, but I wanted to make sure. :-)
              Since L105 is gone is there any way to find the correct inductor to replace it? Any ideas are welcome.
              Thanks again,
              Craig
              • PlainBill
                • Feb 2009
                • 7034
                Thanks again,
                Craig
                I had thought of searching for the service manual for the monitor and other monitors that use the same power supply. The I realized that a considerable amount of current passed through that inductor to destroy it AND damage the circuit trace next to it. There is certain to be additional damage.
                PlainBill
                • eiznekcm
                  • Oct 2010
                  #308
                  Good Point. Thank you. I will probably look for another board.
                  Craig
                  • mldenison
                    • Oct 2010
                    • 6
                    #309
                    I may have missed it, but is there another MOSFET than can be used? Both Mouser and DigiKey show the 863-NTP45N06LG part as no longer available.
                    • jetadm123
                      • 2169
                      #310
                      Hello! I believe the original mosfet was a 40T03GP. These are readily available on Ebay.
                      • mldenison
                        • Oct 2010
                        • 6
                        #311
                        I appreciate it! 6 on the way.
                        • EGuevarae
                          • Nov 2008
                          • 1336
                          • GeForce GT1050
                          • mldenison
                            • Oct 2010
                            • 6
                            #313
                            Another question about my DAC-19M015 power board.
                            On the solder side, to the right of the CE103 cap (1000uf, 25 vdc) (with the cap positioned to the top), there's a small black square labeled ZD100. It appears to be cracked.
                            Can anyone tell me what kind of component it might be, and the value?
                            • alexanna
                              • Mar 2010
                              • 1346
                              #314
                              If the dac-19m005 is similar to your dac-19m015
                              The markings on the 005 board of zd100 read.The diode is closer to CE104 CAP.
                              PJ69
                              HU
                              • ykilde
                                • Nov 2010
                                • 17
                                #315
                                Could someone help me identify this diode? I have a couple of these that are shorted. I've replaced all the capacitors, 40T03GP MOSFET and checked all fuses. I found several SMD resistors that had very high resistance (0.2 ohms -> 1.9 megaohms) along with these shorted diodes.
                                I believe these are LL4148 diodes, but I would like someone who is familiar with these to verify. Thanks
                                • mldenison
                                  • Oct 2010
                                  • 6
                                  #316
                                  PJ69
                                  HU
                                  After some discussions on another board, it appears that the prefix 'zd' stands for zener diode. We're guessing a 12 volt, 1 watt zener should do the trick.
                                  I had emailed Delta Products about this board in hopes of getting a schematic and/or a parts list. I got back a fairly curt (snotty) reply basically telling me to take it up with Westinghouse. And we all know how they are.
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    It should be pointed out that this power supply - indeed, the entire monitor, is sold under a number of different labels.
                                    Two sites that can be helpful are www.elektrotanya.com, which has a number of service manuals. Their 2 downloads a day limit will be lifted if you register.
                                    Also, http://www.4shared.com/dir/7126951/4..._INVERTER.html has a number of original and third-party schematics for power supply / inverters.
                                    PlainBill
                                    • mldenison
                                      • Oct 2010
                                      • 6
                                      #318
                                      Thanks for the links, Bill. I think I can get the power board schematic if I can ever come up with another model number. I thought I had it with a Viewsonic monitor, but it turned out to be a Delta DAC-19M010 unfortunately.
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        This is a constant problem. Quite often we will find several different power supply / inverter boards and even logic cards used in a given model of monitor.
                                        PlainBill
                                        • billy66
                                          • Mar 2010
                                          • 124
                                          #320
                                          I have this same monitor: Westinghouse L2046NV. Same issue... but once I replaced all the caps and the mosfets, it still didn't work. The backlights would flicker for a second, and then go out... over and over. I finally found R210 (on the backside of the board) was bad. Ohm'd out it read 900K ohms... and it should be 10 ohms. Reads: 10R0. I replaced it and it fixed the issue. Just wanted to throw my two cents in to help others if they have the same issue. This one was killing me for a while.
                                          Thanks to all those on this, very long, thread that have helped... the info was a great help to me.
                                          • Cuboy
                                            HP probook 4510s mosfet issue
                                            by Cuboy
                                            I am currently trying to help a ONG by volunteering to help repair laptops, it's something that i have been into since 2017, always watching videos, on discords, forums etc...
                                            I have an HP ProBook 4510s laptop that does not power on and has no indicator lights, which suggests an issue with the power supply or the motherboard.
                                            I started by verifying that there is voltage at the input of the motherboard, confirming that the power adapter is working correctly. However, when I checked the voltage at the output of the first MOSFET (Q1032), I found 19V at...
                                            03-16-2024, 10:29 AM
                                          • ebyte64
                                            Lenovo IdeaPad 330 laptop mosfet issue
                                            by ebyte64
                                            Good day everyone.
                                            I have been scratching my head with a Lenovo laptop I got in today.
                                            The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
                                            Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
                                            Would anyone...
                                            06-27-2023, 10:19 AM
                                          • Jane
                                            How do you test MOSFET in laptops ?
                                            by Jane
                                            I tried to use this method:
                                            Testing an N-channel MOSFET:
                                            Step 1: Discharge the Gate (turn off the MOSFET)
                                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                            Step 2: Charge the Gate (turn on the MOSFET)
                                            Now, place the red probe on the Gate (G) and the black probe on the
                                            09-27-2024, 03:31 AM
                                          • DqMagetz
                                            Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                                            by DqMagetz
                                            Good day!
                                            I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                                            Here are the voltage readings:
                                            • Input – 19V (stable)
                                            • +LCDVDD – 3.3V briefly, then drops to 0V
                                            • EDP_HPD – 3.3V briefly, then drops to 0V
                                            • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                                            • EC BKOFF# – 1.8V briefly, then drops to 0V
                                            • PANEL_OD_EN – 0.3V
                                            Is it possible that the EC chip is corrupted or damag...
                                            07-12-2025, 09:37 PM
                                          • wattage
                                            by wattage
                                            Hello Badcaps Community,
                                            Yesterday, 04:41 PM
