Issue with Westinghouse 19" LCD Monitor (large pics)
  • EGuevarae
    • Nov 2008
    • 1336
    Re: Issue with Westinghouse 19" LCD Monitor (large pics)
    Originally posted by aoggameover
    My screen is a westinghouse 19" TV here are the problems with it it does work some what no sound screen takes 30min to power on click PC white screens and freezes click HDMI white screen and freezes now when i try to boot it back on blue LED flashes and wont power on til i pull the plug and plug it back in and wait another 30 min i pulled it apart thinking it was a loose wire inside it every thing is clean but 1 cap on the psu was bubbles but if you look at all the pix most of them are like that so i put it all back together i been reading forums and contacting people for the past few days now talking about the problems i own a westinghouse 32" tv nothing wrong with it its an old TV now never had a problem this lil 19" is a pain any ideas on what i should do with this screen
    This thread is of a specific model.If it's your unit, post a pic set of the boards and cap info and we'll go from there.
    There are 10 kind of people in this world: those that understand binary, and those who don't.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • 16gb GSKILL TridentZ RGB DDR4-3200
    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
    • Windows 10 Pro x64
    • GeForce GT1050
      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
    • PlainBill
      • Feb 2009
      • 7034
      What EGuevarae said. And for Faraday's sake, use some punctuation. Unreadable posts often aren't read.
      PlainBill
      • EGuevarae
        • Nov 2008
        • 1336
        PlainBill
        Read?
        As a matter of fact, I tend to read posts aloud to practice my English (2nd language) and see where punctuation can be inserted and such,so I can both try to help, learn and also improve my language.... you should try to read it....
        • GeForce GT1050
        • blackrider1
          • May 2011
          • 28
          #344
          Hello,although this post was started several years ago, it still keeps alive, so, after reading the whole tread, I think I can help a little.
          When trying to fix an ACER 2017, I used this dac-19m005 datasheet I found on the web.
          http://www.megaupload.com/?d=YJWEDABQ
          Here you can see schematics and components. Although it is a different LCD model, is has the same power board: DAC-19M005 CF REV: 00A, (plus it has just DUB conector, no DVI, but still the same board too), so: same problems and same fixes, I guest.
          After recapping all (same 2 bulged caps as every faulty board), I can see images on the screen but no backlight. You only can see it taking a light close to the screen ( I didn´t read anybody in this situation, everybody has no light but nobody has mentioned about dark images with no backlight)
          All the fuses on the backside are OK but I can see a damage transistor: Q204, on the backside, right close to the F200 4A fuse, so probably this is what I need to fix.
          According to Kahless (on post #299 and # 301) and billy 66 ( #320) I can see Q2004 burnt ( probably that´s because F200 fuse didn´t blew up), but I checked R210 and I got about 11 Ohm, so I think it´s Ok. Anyway, I ordered replacements for the whole components:Q204,Q208 and R210.
          I´ll post the results when I get it working here or in a new thread refering ACER 2017 (only DUB, no DVI conector)
          • Cuboy
            HP probook 4510s mosfet issue
            by Cuboy
            I am currently trying to help a ONG by volunteering to help repair laptops, it's something that i have been into since 2017, always watching videos, on discords, forums etc...
            I have an HP ProBook 4510s laptop that does not power on and has no indicator lights, which suggests an issue with the power supply or the motherboard.
            I started by verifying that there is voltage at the input of the motherboard, confirming that the power adapter is working correctly. However, when I checked the voltage at the output of the first MOSFET (Q1032), I found 19V at...
            03-16-2024, 10:29 AM
          • ebyte64
            Lenovo IdeaPad 330 laptop mosfet issue
            by ebyte64
            Good day everyone.
            I have been scratching my head with a Lenovo laptop I got in today.
            The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
            Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
            Would anyone...
            06-27-2023, 10:19 AM
          • Jane
            How do you test MOSFET in laptops ?
            by Jane
            I tried to use this method:
            Testing an N-channel MOSFET:
            Step 1: Discharge the Gate (turn off the MOSFET)
            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
            Step 2: Charge the Gate (turn on the MOSFET)
            Now, place the red probe on the Gate (G) and the black probe on the
            09-27-2024, 03:31 AM
          • DqMagetz
            Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
            by DqMagetz
            Good day!
            I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
            Here are the voltage readings:
            • Input – 19V (stable)
            • +LCDVDD – 3.3V briefly, then drops to 0V
            • EDP_HPD – 3.3V briefly, then drops to 0V
            • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
            • EC BKOFF# – 1.8V briefly, then drops to 0V
            • PANEL_OD_EN – 0.3V
            Is it possible that the EC chip is corrupted or damag...
            07-12-2025, 09:37 PM
          • wattage
            by wattage
            Hello Badcaps Community,
            07-13-2025, 04:41 PM
