Gateway 900G frustration
+ More Options
Posts
  • PlainBill
    • Feb 2009
    • 7034
    Re: Gateway 900G frustration
    Originally posted by koshposh
    ok so when unplugged from power, both 5V and 12V sit at 4 mV
    when power is plugged in the 12V sits at 4.4 mV and the 5V jumps randomly anywhere between 338 and 78 mV without any particular order...
    I'm getting volatages nowhere near 5 or 12 V
    See suggestion for pulsing 5 Volt supply. While you are at it, you may as well replace the rest of the caps.
    PlainBill
    • arpcentralone
      • Apr 2009
      • 10
      #42
      Hi all, wow, I left for a week and LOTS of stuff was talked about. I got the ccfl mod kit in, tested the lamps in the monitor screen with the mod kit's inverter, and all tested fine. They lit up and stayed on. I will try the mod kit's lamps with the monitors inverter next and see what happens, probably cut back off again. I believe it has something to do with me replacing the cap "in the blue circle" with the wrong mF value. I got the voltage right on it tho.
      • Bobdee
        • Jun 2008
        • 461
        #43
        To be honest this link of your earlier posting on this cap
        https://www.badcaps.net/forum/showpo...5&postcount=16
        never added up to me, you say that a 470uf replaced a 47uf, thats 10 x original value that to my understanding has been a No No in cap replacement, way to high
        then you mention the uf to be lower, I asume that to have been a error
        Having said that I dont know if this cap is the cause of your b/light turning off
        Hope I havent put my foot in my mouth, I am not one of the brighter stars in the sky
        bob
        • PlainBill
          • Feb 2009
          • 7034
          bob
          I'd say you are right twice. Replacing a cap with one 10 X the original value (or .1 X ) is generally a bad idea. However, this cap is part of the power supply. It's value was chosen as a trade off between low cost and a stable voltage for the power supply controller. I have looked at the original data sheet on this IC, it recommended a 22 uF capacitor.
          You are also right, this capacitor would have nothing to do with the 'two seconds to black' problem.
          PlainBill
          • koshposh
            • Apr 2009
            • 5
            #45
            ok thanks, I'll that a try. first gotta find a good place to buy caps
            • PlainBill
              • Feb 2009
              • 7034
              Sometimes it helps to read the FAQ. An amazing amount of information can be found.
              PlainBill
              • IRShifty
                • May 2009
                • 78
                #47
                Just wanted to make a quick post giving thanks to all the info in this thread. I was able to fix a customers 900G in about 20min with all the great info here.
                • Bill Aldridge
                  • May 2009
                  #48
                  This guide helped me repair 700G.After replacement of 470uf caps it was the little guy.Put in a 100uf and it works great.I did not have any ticking,or obvious blown-swollen caps.I did have faint backlight flicker,thought it was my fluorescent lights or eyes, no blue button or anything else.Thanks for all the great info.
                  • tswan
                    • May 2009
                    • 8
                    #49
                    I've got the "ticking" problem coupled with the 5v supply oscillations.
                    I replaced all the electrolytic caps and the also tried the shunt regulator and the problem still exists. It is interesting to note that the period of the ticks was about once/second before I swapped the caps and now it is more like 2 seconds.
                    I'm competent, but not terribly strong with these repairs. Any advice on what components to consider or a schematic would be very helpful.
                    Thank you to all who offer advice.
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      Originally posted by tswan
                      ...I replaced all the electrolytic caps ...
                      Did you replace also the smaller ones? What did you use for replacement?
                      • ASUS ROG Maximus IX Code
                      • Intel Core i5-7600K 3.8GHz
                      • Windows 10 Pro x64
                      • GeForce GT1050
                      • tswan
                        • May 2009
                        • 8
                        #51
                        Hi, I replaced all that I saw. The smallest one (the 47uF cap) was replaced also with a 47uF. When it did not work I tried a 100uF cap as someone else had done.
                        • EGuevarae
                          • Nov 2008
                          • 1336
                          With what brand/series/values?
                          • GeForce GT1050
                          • tswan
                            • May 2009
                            • 8
                            #53
                            I replaced all the 470uF with 470uF 50V, and all the 220uF with 220uF 50V. They are a collection of caps from both NTE and Xicon. I replaced the 680uF with a 680uF 50V. It's physically too big for the board to go back into the monitor, but I thought I would replace it just in case....assuming I can get this working I'll find a smaller 680uF.
                            Things have also changed. The 12V supply is now moving around and the 5V supply that as swinging between 3 and 5V is now swinging around 1-2V. Not sure if I've done more damage or if something is degrading.
                            I did not replace the 100uF 450V cap.
                            • EGuevarae
                              • Nov 2008
                              • 1336
                              It rarely fails.
                              • GeForce GT1050
                              • tswan
                                • May 2009
                                • 8
                                #55
                                I got it fixed. In fact, it was probably fixed yesterday and I did not realize it.
                                After I replaced all the caps I checked the 5 and 12 volt signals with the board out of the monitor (no load). When I saw the 5V output oscillating I thought that was wrong and kept goofing around. It looks like I ended up blowing a fuse in the process of poking around so much. Once I replaced the fuse and tested the 5 and 12 volts signals under a load they were fine. I'm sure it was the capacitors all along.
                                Thanks.
                                • EGuevarae
                                  • Nov 2008
                                  • 1336
                                  Thanks.
                                  So it is now just a matter of finding the smaller 680 replacements?
                                  Good to ear that.
                                  • GeForce GT1050
                                  • capamatic
                                    • Apr 2006
                                    • 33
                                    #57
                                    Just picked up one of these 900W`s and tested the offending caps.
                                    All Samxon caps, none visibly failing/failed.
                                    The 47uF read as 48uF and 0.15 esr (good, hhmmm)
                                    The 470uF`s read 0.05 esr (good) but all 4 were within a uF of 423uF.
                                    That`s exactly 10% reduced capacitance, so probably the fault cause.
                                    Has anyone subbed anything other than 470`s back in?
                                    Looking at the board, it`s easy to replace at least 2 of them with a 1000uF cap.
                                    • EGuevarae
                                      • Nov 2008
                                      • 1336
                                      If in parallel, you can, but why not stick to original specs?
                                      • GeForce GT1050
                                      • capamatic
                                        • Apr 2006
                                        • 33
                                        #59
                                        I`ve got a stash of quality 1000`s , and better esr specs at that rating should prolong it`s life. C205 / C206 are in parallel and are under the most stress.
                                        Just wondered if anyone has done it.
                                        • EGuevarae
                                          • Nov 2008
                                          • 1336
                                          I've done it two or three times. Units are stable as of today (two or three months ago, on units that work 24/7).
                                          • GeForce GT1050
                                          • mikey5791
                                            Tiny Tech ATX480W output power ticking
                                            by mikey5791
                                            Hi to all forum members,
                                            ​​​​​​This psu (Tiny Tech model ATX 480W) had been installed in a very old Windows XP PC but recently i pulled it out as the pc cannot start. To test it, i jumped the green wire and black wire on the 24 pin connector. The psu fan jerk a bit but not spinning. I used my dmm to check dc voltage on output connector wire, the 5v red wire keeps ticking a bit at around dc1v....then drops and ticking again around 1v. It is the same situation with the 12v yellow wire.
                                            Fyi, i desoldered the secondary side electrolytic cap those over 1000uf...
                                            02-20-2025, 01:11 AM
                                          • bjhnsonjr2734
                                            Gateway laptop model GWTN-156-7BL Needing Schematics
                                            by bjhnsonjr2734
                                            I am really needing Schematics for the motherboard on my Gateway laptop model GWTN-156-7BL
                                            I attached a pic of motherboard info
                                            04-25-2025, 07:01 AM
                                          • Dan John
                                            Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0) - (Possible) Multiple Issues
                                            by Dan John
                                            Greetings everyone,
                                            I have a Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0). The client said the battery was not charging. Upon checking the laptop,
                                            1) On pressing the power button, the (power button) light turns on and stays on.
                                            2) There is no boot, or anything on the screen.
                                            3) The fan starts and stops a few times, then it stops completely.
                                            4) The light on the power button remains on.
                                            5) Battery not charging (original issue).
                                            The original problem was that the battery was not charging, but the laptop still worked. My belief
                                            04-23-2025, 08:12 AM
                                          • Solvik
                                            XFX XPS 650w 3XS PSU making Ticking/clicking sound
                                            by Solvik
                                            Hello
                                            i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
                                            All voltages are normal....
                                            02-13-2025, 02:43 PM
                                          • ntoskrnl
                                            [FIXED] XFX Core Edition Pro 450W ticking noise
                                            by ntoskrnl
                                            My XFX Core Edition Pro 450W power supply started making a weird ticking noise some time ago. Eventually, I figured out what the issue was, and managed to fix it. I purchased this unit back in 2012, so it's an old model, but I'm still posting this in case someone finds it helpful or interesting.
                                            THE PROBLEM
                                            The power supply started making an irregular ticking noise when running, but would otherwise work perfectly fine. The issue would sometimes come and go. A Google search for "xfx core ticking" found multiple other people reporting the same issue, so I assume this...
                                            04-19-2022, 10:36 AM
