viewsonic vp201s missing colours
  • boy80
    • Sep 2008
    • 7
    Hello
    I have two viewsonic vp201s 20.1" lcd monitors that work ok, but are missing colors. I know they are missing colours because it is missing the graident transitions between colours. It happens on all modes. I have narrowed it to the monitors alone as I tried other montors and the 32bit even 16bit color looks perfect on my other lcd monitors.
    Kinda looks like im lim running in 64k color instead of in the 16 or 32 bit resolution. Sounds kinda crazy but ill try and take a pix. Seems like one of the viewsonics is missing more color then the other.
    Also one of my monitors also exhibit the messed up picture symptom here as well, when you turn it on all you see is vertica lines.
    btw I didnt see any bad caps on the boards
    any ideas would be appreciated.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: viewsonic vp201s missing colours
    Replace the Elite brand caps if you have any.
    [Viewsonic likes those and they suck.]
    Mann-Made Global Warming.
    - Dr Seuss
    • EGuevarae
      • Nov 2008
      • 1336
      Originally posted by boy80
      Hello
      Did you do as PCBONEZ suggested?
      Have you resolved the VP201s issue?
      There are 10 kind of people in this world: those that understand binary, and those who don't.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • 16gb GSKILL TridentZ RGB DDR4-3200
      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
      • Windows 10 Pro x64
      • GeForce GT1050
        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
      • boy80
        • Sep 2008
        • 7
        havent had time to tear it apart yet, do you think caps will cause missing colours?
        • EGuevarae
          • Nov 2008
          • 1336
          A variating voltage coming from a PSU with bad caps can cause the VBoard to do crazy stuff... yes, it is possible.
          • GeForce GT1050
          • dantm
            • Mar 2009
            • 26
            I've had this problem on a VP201b and now it's just *dead*...for months I had it working almost in less colors than the 16.7M that I was outputting to it.
            Now the light is just amber and won't go to green no matter what signal I send to it...
            Thoughts?
            Thanks!
            • EGuevarae
              • Nov 2008
              • 1336
              Thoughts?
              Thanks!
              Open it, take pics, post them, and post cap info for both the PSU & the VBoard. Maybe it is a cap problem, maybe not, but more info is needed to get to a conclusion.
              • GeForce GT1050
              • dantm
                • Mar 2009
                • 26
                can you guys let me know how to open this thing? There are 4 screws on the back but the stand needs to come out and I can't see how that would work? There are 4 little screws under the plastic cover at the mating between the stand and the panel; took those out to be faced with the larger nuts that pivot the LCD around...
                Do those have to be taken out or is there something else?
                Thanks!
                • dantm
                  • Mar 2009
                  • 26
                  I have a new update of this issue; which is very strange.
                  I took the monitor out and plugged it into my laptop; via the D-SUB I get an image which is very blue-ish (almost like on a normal monitor would be under a warmer color). So for example if I set the color to 9300K on this monitor it's the same as it would be at 6500K on a normal monitor....it's very blue-ish/warmer.
                  There's nothing out of the DVI input?
                  Does this make any sense?
                  Thanks!
                  • EGuevarae
                    • Nov 2008
                    • 1336
                    Thanks!
                    If you put the monitor facing away (screen) from you, so the back is in front of you, you should see a plastic cover (oval like) that can easily be removed pulling it out. Under that oval cover lie 5 screws that keep the stand attached to the monitor. Remove those 4 and the stand comes off. After the 4 screws in the monitor corners are removed, you can easily open it ...
                    And in what thread will you be posting, this one, or the other VP201 one, so I can track the right one? I still have one of those units (about to sell it) and maybe I can help you.
                    • GeForce GT1050
                    • dantm
                      • Mar 2009
                      • 26
                      Ok got it...
                      Removed the cover and I was astounded to find the other covers underneath/etc.
                      Going through the process of removing those now and will take pictures.
                      Everything inside looks pristine; there's a strange looking epoxy (white) which is around some of the cap leads/etc. but I assume that is normal (it's definitely some kind of epoxy shielding?)...
                      I did do one thing before going further - unplugged and re-plugged the connectors on the left side of the panel, which looks like they go to the LCD inverter?
                      Interestingly enough after doing this, I was able to get a very clear image on the D-SUB connector; no more blue-ish tint...
                      The DVI connector is still dead -- how can that be???
                      Thanks!
                      [PS - I'll continue to post in this thread]
                      [PPS - can you PM me about the LCD that you're selling and the condition? Crazy as it might sound after my recent experience - I might be interested in another one ;-)]
                      • EGuevarae
                        • Nov 2008
                        • 1336
                        Ok got it...
                        Thanks!
                        No idea on the DVI input. It would be more logical to me that the blue hue was caused by a bad VGA cable, but it is possible to be caused by the "internal VGA connection", if you can call it that way (I guess LVDS connection would be more correct). As for the LCD, a friend of mine (a very good one) asked for it and I could not say no. They are great units, BTW.
                        • GeForce GT1050
                        • boy80
                          • Sep 2008
                          • 7
                          My lcd is exhibiting the same symptoms as yours, with the missing colours. One use to work, but now all it does is just just flickering like crazy,once it works it works fine until I unplug it. But that one too is missing coloursjust less colours.
                          My other viewsonic works all the time no problems other then the missing colours. I tried the dvi and d sub both are ok. I ripped both apart and was going to swap the power board inside but had problems removing the board from the frame. The caps look ok on both, but dont have the tools to check them nor had the time to buy replacements.
                          I have replaced the fuse on the inverter of one of them previously.
                          • dantm
                            • Mar 2009
                            • 26
                            I just ordered a dead VP201B from eBay to see if I can swap some things and get my colors back. I don't know if it's a mainboard or inverter problem; the DVI issue definitely seems to be related to the mainboard.
                            • EGuevarae
                              • Nov 2008
                              • 1336
                              I guess it is the mainboard.
                              • GeForce GT1050
                              • boy80
                                • Sep 2008
                                • 7
                                the inverter will not cause the display to lose colors, im leaning more towards the mainboard as everything else is fine except for the missing colours. lmk how yours turns out i may do the same if
                                • EGuevarae
                                  • Nov 2008
                                  • 1336
                                  Agree. The main board is almost for sure the culprit.
                                  • GeForce GT1050
                                  • ugamazing
                                    820-02020 PPBUS_AON missing
                                    by ugamazing
                                    Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                    Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                    02-05-2025, 04:21 PM
                                  • jpreza
                                    Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                    by jpreza
                                    I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                    Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                    It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                    Looking at the card, it appears to be missing the following:
                                    1x 1.0uH inductor - orange square
                                    2x...
                                    11-01-2024, 10:54 PM
                                  • gurj1979
                                    Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                                    by gurj1979
                                    Hey guys.
                                    Need help with this one.
                                    Fan not spinning due to missing PWN Fan signal.
                                    Also 5 seconds from powering up it freezes, unless in BIOS.
                                    But as soon as Windows starts to load, it will freeze.
                                    CPU is COLD / Room temp when it freezes.
                                    I've replaced the CPU, same problem.
                                    Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                                    Replaced fan - same problem.
                                    Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                                    Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                                    08-19-2024, 05:22 PM
                                  • salopian
                                    Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                                    by salopian
                                    Hello. I would need some advice please.
                                    My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                                    He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                                    I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                                    I have already replaced the logic board with another...
                                    02-27-2021, 07:30 AM
                                  • ein_individuum
                                    Missing Capacitator Intel I9-12900KF CPU
                                    by ein_individuum
                                    I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
                                    I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
                                    Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
                                    08-06-2025, 01:36 AM
