Viewsonic vx2235wm colors washed out after power board recapping
    Re: Viewsonic vx2235wm colors washed out after power board recapping
    I am glad you got it figure out, some how it got corrupted.
      master hoarder
      • May 2008
      • 12170
      • Bulgaria
      #42
      Yay, another monitor saved! Good job, rddube! This repair is all on you and don't let anyone tell you otherwise.
      Indeed there must have been some corruption going on as budm suggested - perhaps the bad caps caused the monitor to corrupt the factory settings saved in BIOS. I think I do recall seeing a thread in badcaps.net here a very long time ago where someone had a similar issue after a recap.
      Regarding the menu options, I think ADC OFFSET is to set the correct for any offset in the midpoint of all the colors (RGB). Meanwhile, ADC GAIN is likely something to do with the contrast / color curves / gamma. I'm not 100% sure to be honest, but it does look a bit similar to some of the colors settings I've fiddled with on my high-end CRT monitors. The rest should be self-explanatory, more or less. The "9300K", "7500K", and other numbers are probably factory-preset color temperatures (with the "9300K being the most "blue" and the "5400K" the most yellow/red, or sepia-like). As for the settings on the second page - I'm not quite sure about those.
      Anyways, congrats on the repair again and cheers!
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        #43
        Was the monitor also flickering before you adjusted the Vcom value?
        Read here for some details on what it adjusts:
        • rddube
          Aspiring Expert
          • Jun 2013
          • 914
          Hello Per Hanson,
          How interesting - actually, the monitor was not flickering before I adjusted Vcom value, but since adjusting (the value goes from 0 to 255) I have found that the optimal value is 122, not 128 for image quality.
          But, I did notice that when it comes out of sleep mode, it does flicker for approx. 30 seconds right in the middle of the screen (about 2" X 4") and stabilizes after that or it will also stabilize if I display a page with white in the middle of the screen (pure white). Not sure what is causing this, but it wasn't doing that before the recap and corruption.
          I'm not sure I understood all the parts of the article you sent, but I think it might be related. The interesting thing is that when I initialize the EEprom in the menu, the Vcom value doesn't change. I also tried auto color and auto config but it doesn't change anything.
          Additionnally, when I have that flicker from waking up, I also have a vertical band as you can see in the picture attached that also disappears within the same time frame as the flicker.
          Not sure what I should try, but if you have any ideas, I am prepared to test and post.
          Thanks again for your intervention!
          • rddube
            Aspiring Expert
            • Jun 2013
            • 914
            Ok fixed the flickering problem by adjusting another setting on page 2 of the factory menu called digital bri. which probably means digital brightness. It was at 128 and by lowering down to 102, this fixed the flickering in the middle of the screen when coming out of sleep mode, without much impact on image quality.
            Hope this might help someone else with same issue.
            • rddube
              Aspiring Expert
              • Jun 2013
              • 914
              Nope, still doing that flickering in the middle of the screen (approx 2" X 4") when monitor comes back on - for about 30 seconds, as if something needed to heat up before it stops. Any ideas anyone?
                master hoarder
                • May 2008
                • 12170
                • Bulgaria
                #47
                Hmmm. Maybe the CCFL tubes are getting a bit old at this point? Do you know how many hours the monitor has been running for so far (there may be an option in the service menu to tell you that). From what I've seen, it's mostly old monitors with lots of use that start to flicker. But it could be something else too. To be honest, I'm not too sure at this point. Hopefully we can get more input from other members.
                • rddube
                  Aspiring Expert
                  • Jun 2013
                  • 914
                  Hey Momaka,
                  Well it is an older monitor (2005), so that may be it. I wasn't able to find any data in the service menu that would indicate number of hours powered on.
                  Well I guess I'll just have to live with it unless someone else has any ideas? Tks!
                  • seanc
                    • Nov 2008
                    • 1319
                    #49
                    Hey Momaka,
                    I have one of these at work, I think I recapped it around 2011 or 2012, still going strong on a colleagues desk.
                    Do you want to know its values?
                    From your description it sounds like you press up, down, 1 and 2 all at the same time for factory mode??
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 914
                      Hi Sean,
                      Yes if you could take a photo of page 1 and page 2 of the factory menu that would certainly help. To get to the factory menu, the monitor has to be hooked up to a DVI or VGA signal. Then you press "power key" to turn off the monitor. While it is off, you press" [▼] +[▲] + "power Key" "at the same time so as to enter factory mode. After power on, press ''Menu[1]'' key, you can see the Factory menu.
                      • rddube
                        Aspiring Expert
                        • Jun 2013
                        • 914
                        Hi again, any chance you could get those photos of the factory menu?
                        Many thanks!
                          by momaka
                          03-15-2023, 10:17 PM
                        • wattage
                          AOC AG493UCX 49-inch monitor - Firmware request
                          by wattage
                          Hello Badcaps Community,
                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                          07-13-2025, 04:41 PM
                        • ant3202
                          HP 27es - LED monitor - Monitor Flashing On - Off
                          by ant3202
                          Hi Everyone
                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                          https://www.badcaps.net/forum/troubl...lashing-on-off
                          The monitor is HP 27es LED Monitor
                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                          The monitor will randomly blackout and display no signal and will recover again.
                          Sometimes need to power and off again to restore the display but...
                          03-20-2025, 07:30 PM
                        • Rick_1234
                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                          by Rick_1234
                          Good evening, gentlemen.
                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                          Things I tried
                          - Bought a new AC adapter thinking that was the problem but the problem...
                          06-22-2024, 04:44 PM
                          Wise Wing F199 19'' LCD monitor - recapped
                          by momaka
                          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                          When I saw the Craigslist post, I wasn't...
                          08-24-2020, 10:58 AM
