ViewSonic VP201b
  • olenac
    • Apr 2009
    Re: ViewSonic VP201b
    Hi guys,
    I have one of that LCD VP201 that has the inverter fuses open. I replaced both with a 2A picofuse as explained in this post. Now the monitor powers and when it scans through the DVI-A, DVI-D, D-SUB it tells the message “No signal” and goes to sleep mode (amber light). It won't recognize any input into it. The amber light stays on and the monitor can be cycled on/off but I cannot get it to display anything in any of the inputs. I have verified in the controller board all the capacitors and they look ok and have good readings with a cap meter; also I have verified all the transistors and diodes for open or shorts and nothing bad.
    Thanks all for any help or suggestion on this one,
    mas
    • EGuevarae
      • Nov 2008
      • 1336
      Originally posted by olenac
      Hi guys,
      mas
      Welcome to the forums
      Post a picture (clear one) of the signal/main/video board to see if I can get my hands on an exact one to try to help you.
      There are 10 kind of people in this world: those that understand binary, and those who don't.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • 16gb GSKILL TridentZ RGB DDR4-3200
      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
      • Windows 10 Pro x64
      • GeForce GT1050
        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
      • PlainBill
        • Feb 2009
        • 7034
        Hi guys,
        mas
        I had this happen on a close relative of that monitor TWICE. Once was user error - I didn't seat the DVI cable FIRMLY into the socket. The other case appeared to be the main logic board - it didn't like 1600 x 1200, but would work at lower resolutions.
        PlainBill
        • olenac
          • Apr 2009
          Hi Guys:
          Thanks for the feedback. I test the board again and found that diode in position D602 in the bottom of the video board was shorted. I replaced that with a spare board I have but still the same problem. I have a voltage in this diode of 2.43 which is the input for IC601 and IC603. There is some output voltage from this 2 Ic`s but I don't know if they are ok. If any one knows the value of this diode in order to buy a replacement please advice. I notice that this board is making some noise near to IC401 but is very difficult to find from were exactly. Attached some pictures of this video board.
          I will appreciate all the help you can bring in order to fix this LCD.
          • Thornapple
            • May 2009
            • 9
            I was almost ready to give up on my VP201b, but then I found Badcaps and this thread!
            The display on my VP201b blanked suddenly leaving just the green LED lit. Following this thread, I have found that one of the tiny fuses on the inverter has blown. Other diagnostics:
            i) the power supply board is outputting 18V so I think the PSU is OK.
            ii) I have tested the two electrolytics on the inverter ('Rubycon', 220uF 35V). One is OK, the other is over 10 times the expected value (2.6mF). That's tested in-circuit though.
            So it might just be a question of changing the blown fuse. The one mentioned in the thread (576-0429002.wrm) is only available from USA (Mouser) and I will have to pay £12 postage (UK pounds). That's OK, but I'd like to be as sure as possible I won't need any other parts; if I have to go back to Mouser a second time that's another £12 (plus what Customs & Excise slaps on). So are there any other basic tests I can do? In particular, could someone explain Eguevarae's test in non-technical terms; I mean 'Check also if voltage is reaching the inverter (from ground to a fuse you should get a V reading)'. I'm not sure what is 'ground' and which side of the fuse he means.
            A few more questions:
            a) Do these tiny fuses snap out like domestic fuses or are they soldered in?
            b) If the latter, can I just solder the new one on top of the old one (unsoldering things is horrible)
            c) One of the posts mentions 'picofuses'. Are these the same as 'Pico Fuses' available over here, i.e. fuses with axial leads? Would these need to be soldered in? Would I have to drill holes through the PCB??
            d) I think I might have some 2A 20mm glass fuses, maybe even quick blow. To test if the fuse is the only problem I might be able to connect one of these across the blown fuse using small croc clips and switch on...or would this be suicidal?
            TC
            • PlainBill
              • Feb 2009
              • 7034
              TC
              In less technical terms, measure the voltage from the negative output of the power supply or any of the screws used to hold a board in place to each side of the fuse (or fuses) in question. If you read the same voltage as the power supply output (18 Volts in this case) to each side of the fuse, the fuse is good. If you don't read 18 volts to either side, the problem is elsewhere. If you read it to only one side, the fuse is bad. I STRONGLY urge you to replace both capacitors on the inverter board. One is certainly bad, the other may follow.
              Answers to other questions:
              a. Soldered in
              b. Yes. But at some time check out a product called Chip-Quik. It makes desoldering easier.
              c. They are the same. I would form the leads so you can solder the Picofuse to the ends of the original fuse. It doesn't meet Mil-Spec, so you'll never be able to use the monitor on a warship, but I doubt you will lose any sleep over that.
              d. That is a valid way of testing.
              PlainBill
              • Thornapple
                • May 2009
                • 9
                #27
                Thanks Plainbill, I will certainly change the capacitors. Unfortunately I don't think Chip Quik is available over here so I'll have to do without it.
                TC
                • EGuevarae
                  • Nov 2008
                  • 1336
                  • GeForce GT1050
                  • Thornapple
                    • May 2009
                    • 9
                    #29
                    Thought I'd come back to post my VP201b success story.
                    I got some solderable fuses and replacement caps. I chickened out of replacing the caps as the new ones were quite a bit bigger than the existing caps. I soldered the one fuse that was definitely faulty. It's the thing weirdly suspended on red wires. I never said it was pretty...
                    https://www.badcaps.net/forum/attach...id=10099&stc=1
                    ...but it works!
                    https://www.badcaps.net/forum/attach...id=10100&stc=1
                    This LCD screen cost me about £550 three and a bit years ago, whatever that is or was in US Dollars. I'm not sure what is most gratifying, the £550 or the raspberry to Viewsonic who have failed to coerce me into buying another screen.
                    Thanks everyone for this moral victory!
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      suspended on red wires. I never said it was pretty...but it works!
                      • GeForce GT1050
                      • dantm
                        • Mar 2009
                        • 26
                        #31
                        Now that you guys have had great success with these fixes, can you advise a poor man (me! :-) at:
                        https://www.badcaps.net/forum/showthread.php?t=7038
                        Thank you!
                        • PolishPaul
                          • May 2009
                          • 6
                          #32
                          Excellent thread!
                          My Viewsonic vp201b went dark one night. I love this monitor, its very nice so i had to save it. What was rough is taking it apart - besides the screws, all you need to do is pry the edge with your (long) nails.
                          Long story short, my left fuse on the inverter was bad. I just unsoldered/popped it off and jumped it with a sliver of 'soldering wick'. Which BTW you can use to unsolder things - get it at your local Radioshack.
                          Anyhow, put it together and bam it works. This thread showed me the fuses and it was right on. Thanks so much! I'll probably do the 'external' fuse solution some how. Important thing is that it works!
                          QUESTION however... How do you know the component number? Where can one get schematics for these things? I'm not expert, but I'm sure i can follow a schematic...
                          Oh and any advice on a surface solder? The used wick sliver grabbed the surface really nice.. how would you do a good surface connection?
                          • EGuevarae
                            • Nov 2008
                            • 1336
                            Originally posted by PolishPaul
                            Excellent thread!
                            See post #16 for part number. And normally you can't get schematics (for most of the units). Oh, and welcome to the forums.
                            • GeForce GT1050
                            • PolishPaul
                              • May 2009
                              • 6
                              #34
                              i saw the part #, but how did you decipher what it is? I'm trying to figure out how to obtain such info when fixing consumer electronics.
                              • PolishPaul
                                • May 2009
                                • 6
                                #35
                                can't seem to edit my post.. but, i was able to buy a mini ceramic 2A fuse at Radioshack part # 270-0005.
                                I used the wick as a wire (don't have any braided wire) wrapped around the fuse ends, the other end grabbed the board surface really nicely, isolated with electric tape and off i go!
                                • EGuevarae
                                  • Nov 2008
                                  • 1336
                                  Pics?
                                  • GeForce GT1050
                                  • dcast11
                                    • Jun 2009
                                    #37
                                    I Also Repaired Inverter Replacing A Fuse, But I Must Press Button 2 Down On The Screen So That It Gets The D-sub Signal. Everytime I Turn It Off It Starts Checking For Dvi-d, Like It Doesn´t Detects Signal, It Goes To Standby Or Orange Led State(it Goes To Sleep). So I Press The 2 Button And It Detects The Vga Signal And The Image Appears. Does Someone Knows How To Solve This Issue?
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Go into the menu and select D-Sub as your default input?
                                      PlainBill
                                      • EGuevarae
                                        • Nov 2008
                                        • 1336
                                        PlainBill
                                        You read my mind ...
                                        • GeForce GT1050
                                        • PlainBill
                                          • Feb 2009
                                          • 7034
                                          Exactly!!
                                          PlainBill
                                          • lostone
                                            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                            by lostone
                                            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                            05-19-2024, 11:40 AM
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • eccerr0r
                                            A modified sine wave inverter + a grid tie inverter?
                                            by eccerr0r
                                            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                            Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                            08-31-2023, 09:14 PM
