Dell P2214H monitor is dead, not turning on.. Caps look good
  • Goforth
    • Jul 2017
    • 10
    Hi guys! Title says it all. My Dell monitor will not turn on. No LED lights, no nothin. All of the caps look good, no bulging at all. No cracks in the solder joints, although one joint looks a little rough. Any ideas? I don't know much about this stuff (obviously), however, I am fairly good at soldering. Figured I'll give it a shot fixing it. After all, it's not like I can break it I am limited to a multimeter when it comes to testing. Also, I can get better pictures upon request. Thanks, fellas!
    Monitor is a Dell P2214H
    Photos:
    https://ibb.co/eBVqh5
    https://ibb.co/n4Z5FQ
  • Goforth
    • Jul 2017
    • 10
    What should the DC voltage be on this cap?
    This board came out of a monitor that won't turn on. The large cap in the picture says 450v, but when I check it with a multimeter while the board is plugged in I'm getting 160ish volts DC. Could this be the issue?
    I'm no guru with this stuff, I just figured if the cap says 450v, then it's strange I'm reading 160v. But maybe I'm wrong. Teach me something
    https://ibb.co/hwnzc5
    • mariushm
      • May 2011
      • 3799
      Re: What should the DC voltage be on this cap?
      Modern switching power supply use Active Power Factor Correction circuits which boost 90v..250v AC to 400..420v DC for better operation.
      In this case either the APFC circuit isn't working or it doesn't exist. You have 110v AC coming in, going in the bridge rectifier resulting in DC voltage with a peak of sqrt(2) x 110v = ~ 155v
      If your PSU has no pfc, then probably they kept the capacitor with such high rating in case the monitor was going to be sold in countries with 230v AC at the socket (those would have ~ 330v DC max... so any cap rated for more than 330v+~10% would do... and 420 or 450v rated capacitors are common and suitable for this.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Depends on the PSU. This one looks like it's a non-PFC autodetect PSU, maybe a 384x design. The input needs to be able to deal with 120V and 220VAC mains, so the capacitor voltage needs to be able to handle both. While 120VAC is 160-170V, the 220V input would produce 320-340V which the 450V cap will handle.
        • redwire
          • 3912
          OP please post the make/model of what you working on, or start a thread on it.
          It appears to be 4H.0EH02.A04
          170VDC is what I would expect on the cap, there is no active-PFC.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            And PLEASE stop hotlinking an image host that does not allow it!
            Here is a FAQ on how to upload the images here:
            https://www.badcaps.net/forum/showthread.php?t=1868
            • PeteS in CA
              • Aug 2005
              • 3581
              • USA, Unsure of Planet
              This power supply doesn't have PFC - no PFC inductor, only one transistor/MOSFET on the primary side. Going a step farther, it looks like a flyback design, since there is no output inductor. Finally, unless there's a SMT PWM IC on the underside of the PCB, I'd guess this is a self-oscillating flyback design.
              Since the OP is from the US, the ~160V across the input cap is correct, and means the input fuse is OK. That means the switch transistor/MOSFET is not shorted. If there's no output (especially if there is a clicking sound when it's powered on?), I'd look for shorts on the output side.
              PeteS in CA
              • Goforth
                • Jul 2017
                • 10
                The monitor is a Dell P2214H. Having trouble finding the issue. I was hoping a cap would visually be bad, but it's never that simple (not for me at least).
                • Goforth
                  • Jul 2017
                  • 10
                  My apologies Hansson, won't happen again. Thanks for the instructions.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5027
                    • New Zealand
                    If it does nothing at all, you may have an open-circuit startup resistor
                    -David VanHorn
                    • PeteS in CA
                      • Aug 2005
                      • 3581
                      A picture of the underside of the power supply, if there are SMT components there might be helpful.
                      PeteS in CA
                        • 31170
                        change c606
                          So are you getting any DC outputs on the connector at all (you did not indicate what DCV you are getting on those two output connectors)? It is just simple always on power supply (no PFC) with two outputs (one rectifier on the heatsink, and one axial-lead rectifier).
                          https://cdn.badcaps-static.com/pdfs/...ea2905eb95.pdf
                          It will work with incoming Voltage range from 100VAC ~ 240VAC, thus the 450VDC cap is being used.
                          Page 12:
                          AC input voltage/frequency/current: 100 VAC to 240 VAC / 50 Hz or 60 Hz + 3 Hz / 1.2 A (typical).
                          You should stick to this thread: https://www.badcaps.net/forum/showthread.php?t=63524
                          • PeteS in CA
                            • Aug 2005
                            • 3581
                            Originally posted by stj
                            change c606
                            Whether self-oscillating or in the start-up circuit for a 384x PWM IC that would be a suspect.
                            PeteS in CA
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              Originally posted by budm
                              I have merged the two threads.
                              • Goforth
                                • Jul 2017
                                • 10
                                I tried checking the DCV on the two white output connectors in the right side of the picture, I can't seem to get any readings.
                                • Goforth
                                  • Jul 2017
                                  • 10
                                  Here you go
                                    Re: Dell P2214H monitor is dead, not turning on.. Caps look good
                                    So 0VDC on the connectors.
                                    Try heating up C606 (or just replace it as suggested by STJ) with hair dryer for a minute and then power up the board to see if you will get any DCV on those two connectors.
                                    • Borse2008
                                      Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                      by Borse2008
                                      Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                      I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                      • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                      • There’s
                                      07-15-2025, 04:55 AM
                                    • DanPoka
                                      Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                      by DanPoka
                                      I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                      Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                      This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                      02-15-2025, 05:05 AM
                                    • Jesus Coder
                                      Issues Reviving Old Dell 2408WFPb Monitor
                                      by Jesus Coder
                                      I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                                      06-25-2023, 02:33 PM
                                      What is a good brand of a HDMI monitor that is 10” inch or smaller I am interested in purchasing one
                                      by sam_sam_sam
                                      I was looking for one on EBay but I am not sure what is considered a good brand and what is good price to consider when buying one
                                      Feed back wanted and website links are welcome ( I would refer a new one )
                                      I have a HP elite 8200/8300 computer that has a separate table top switching power supply ( that I planning on converting into a battery powered computer instead and I would refer a monitor that has an external switching power supply to power it )
                                      I plan on making a battery powered battery testing machine on a computer rack system
                                      I am not sure if...
                                      09-07-2024, 06:51 AM
                                    • ChristianBr01
                                      Dell 34 inch U3419W Monitor with thin stripes on partial screen
                                      by ChristianBr01
                                      I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
                                      This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
                                      This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
                                      Does someone have seen this before?...
                                      05-23-2025, 06:06 AM
