12" Macintosh Monochrome CRT monitor
  • Larry Offley
    • Jun 2015
    • 29
    • canada
    no power I get nothing over 3v much past the plug. there was a small white cube that look very melted. no marking on it. seems to have infinite resitance.
    Re: 12" Macintosh Monochrome CRT monitor
    Where is this part located in the monitor?
      • 31020
      that looks like a degausing thermister.
      if it got stuck on, it will take out the fuse.
      is this an all-in-one or just a monitor? what's the exact model?
      • Larry Offley
        • Jun 2015
        • 29
        • canada
        12" macintosh monochrome monitor
        the part is right behind the power plug, the the Hot side of the plug first goes thru a large resistor then to this.
        This is an old monitor the only reason I am trying to fix it is it is parts of a display for a museum and can't easily be replaced
        the fuse is intact
        • Larry Offley
          • Jun 2015
          • 29
          • canada
          I was able to source another 12" Monochrome Macintosh monitor that works. And got the Installation ready for opening. I would still like to fix the other one as a backup though. If anyone has a schematic for it that would be helpful.
            • 31020
            check the circuit boards for any name or model number that could be searched.
            it's very unlikely that it was made by apple - probably made for them buy someone like NEC
            • R_J
              • 9535
              Its most likley a current inrush thermister NTC. Is it in line with the ac circuit, are there any board markings for it (ie ntc1 or th602) it be could be connected between the ac line in and the bridge rectifier ac in.
              If you open the white plastic there should be a disc between two metal contacts, you could try measuring the the disc, it should be around 3-5 ohms cold.
              • Larry Offley
                • Jun 2015
                • 29
                • canada
                numbers on the board
                630-0001-a
                820-0258-e (that looks like the board numbers they still use)
                it says apple computer systems on the board
                • Larry Offley
                  • Jun 2015
                  • 29
                  • canada
                  The ohm measurement is infinite. I popped the top off the component and there is 2 metal pads whatever was between them looks burnt to a crisp. like a lump of carbon
                  all of the resistors and caps have marking next to them but nothing next to this.
                  • R_J
                    • 9535
                    This is a schematic I have of an apple color monitor that shows the th602 thermistor, I suspect the mono monitor has a silmilar ac input circuit.
                    If you ignore the degaussing circuit. you can see where your thermistor would be located, It that is it you could place a short (piece of wire) in its place just to check the monitor, but don't leave it that way as it would eventually blow the fuse
                      The inrush limiter burn up can be due to short circuit, I would check the rectifiers, check the resistance between the +/- legs of the main filter cap at least
                      • Larry Offley
                        • Jun 2015
                        • 29
                        • canada
                        I will check that. The monitor was running inside a plexiglass box and looks like it was overheating.
                          by momaka
                          03-15-2023, 10:17 PM
                        • wattage
                          AOC AG493UCX 49-inch monitor - Firmware request
                          by wattage
                          Hello Badcaps Community,
                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                          07-13-2025, 04:41 PM
                        • ant3202
                          HP 27es - LED monitor - Monitor Flashing On - Off
                          by ant3202
                          Hi Everyone
                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                          https://www.badcaps.net/forum/troubl...lashing-on-off
                          The monitor is HP 27es LED Monitor
                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                          The monitor will randomly blackout and display no signal and will recover again.
                          Sometimes need to power and off again to restore the display but...
                          03-20-2025, 07:30 PM
                        • Rick_1234
                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                          by Rick_1234
                          Good evening, gentlemen.
                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                          Things I tried
                          - Bought a new AC adapter thinking that was the problem but the problem...
                          06-22-2024, 04:44 PM
                          Wise Wing F199 19'' LCD monitor - recapped
                          by momaka
                          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                          When I saw the Craigslist post, I wasn't...
                          08-24-2020, 10:58 AM
