Mag LT916s Model 900p 19" LCD dropping like flies
  • A Man
    • Jun 2010
    • 39
    • United States of America
    #141
    Re: Mag LT916s Model 900p 19" LCD dropping like flies
    Originally posted by Scenic
    the bridge rectifier is the black "box" below the "Caution" warning.
    Any ideas how to test this?
    • PlainBill
      • Feb 2009
      • 7034
      With an ohmmeter. On the lowest resistance scale, resistance between all pins should read open. You can test it in circuit.
      PlainBill
      • A Man
        • Jun 2010
        • 39
        #143
        PlainBill
        I only have an autoranging Fluke meter. It does have a diode check function. Using the ohm meter, I get 1meg plus (it fluctuates) from the top pin to the other three and continuity between pins 2, 3 and 4. I show 0.564v in the diode check mode from pin 1 to 2, 3 & 4 with the negative lead on pin 1 and nothing when I reverse the leads.
        Can you help me decipher this?
        Thanks!
        • PlainBill
          • Feb 2009
          • 7034
          Thanks!
          No, because I'm not sure what you are saying.
          Make the following tests:
          1 - 2, 1 - 3, 1 - 4
          2 - 3, 2 - 4
          3 - 4
          All should read greater than 1K, possibly greater than 1 Meg (a reading might start low, then rise. That is OK). A steady reading of less than 100 ohms is a sign of trouble. A steady reading of less than 1 ohm is a sign of a short.
          PlainBill
          • Regenpak
            Mr.Power Supply
            • Jun 2010
            • 11
            #145
            Continuity between any pins on a bridge rectifier means it's blown and must be replaced with a possibly beefier one (more current and voltage). The reading of 0.564V is from the only diode that's not blown...
            • A Man
              • Jun 2010
              • 39
              #146
              1 - 2, 1 - 3, 1 - 4
              2 - 3, 2 - 4
              3 - 4
              PlainBill
              Ok, it measured less than one ohm from 2-3, 2-4 and 3-4 so it's shorted. I've had some basic electronics classes ages so long ago I wasn't sure exactly what I was testing so I took four seperate diodes and made a bridge. I used the diode test function and made some tests concluding I should also have twice the voltage that I am showing further proving this rectifier is toast. Hey, it even looks like a little slice of toast now that I think about it lol
              A few more questions... is this a common occurance or did this happen when I shorted the fuse against the heat sink of the transistor? Is there a good way to test the transistor? Is this defective rectifier the reason the replacement fuse blew immediately? My theory is shorting the fuse shorted the rectifier and that causes an immediate fault in a new fuse.
              Again, thanks for your help and how are the eyes?
              • PlainBill
                • Feb 2009
                • 7034
                I would do a similar test on the power FET. Any short indicates it is bad. And yes, shorting the fuse to the heat sink could have damaged the rectifier. A shorted rectifier will blow the fuse immediately.
                I came through the surgery OK. Right now I have a shield over the eye. I'll update the report after seeing the doctor tomorrow.
                PlainBill
                • A Man
                  • Jun 2010
                  • 39
                  #148
                  This rectifier is a KPB206 spec'd out at 2A and 600V. Will a 4A 400V work as a replacement?
                  Thank you for your help!
                  • EGuevarae
                    • Nov 2008
                    • 1336
                    There are 10 kind of people in this world: those that understand binary, and those who don't.
                    • ASUS ROG Maximus IX Code
                    • Intel Core i5-7600K 3.8GHz
                    • 16gb GSKILL TridentZ RGB DDR4-3200
                    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
                    • Windows 10 Pro x64
                    • GeForce GT1050
                      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      PlainBill
                      I was about to ask about the same. I hope all went exactly like the 1st eye, or better ....
                      • GeForce GT1050
                      • PlainBill
                        • Feb 2009
                        • 7034
                        It didn't go as well. There has been more discharge from the eye. Right now it feels like I have about 5 lbs of goop on the eyelashes of my right eye. On the other hand, vision out of that eye is already better than before the surgery. The other problem is I have NO glasses which work at computer distances, so I'm typing at arm's length. (I KNEW I should have learned to touch type).
                        PlainBill
                        • A Man
                          • Jun 2010
                          • 39
                          #152
                          Anyone know if this will work properly or not? I went ahead and replaced this after testing the FET (no shorts and 500 ohms). It no longer blows the fuse. I have 160VDC (is this enough/too much for this application?) leaving the rectifier but no outputs on the 5 or 12VDC.
                          Where do I go next from here?
                          • PlainBill
                            • Feb 2009
                            • 7034
                            The rectifier will work fine on 120VAC, but is marginal for 240VAC. It's not the cause of the lack of output voltage.
                            Double check the orientation of the caps, especially the 10uF and 100µf. Then check the voltage across the large capacitor (it should be 1.4 x input voltage), and the voltage on the power input pin of the SMPS controller. If you need help, post a picture of the bottom side of the board and the part number of the SMPS controller.
                            PlainBill
                            • A Man
                              • Jun 2010
                              • 39
                              #154
                              I am powering with 120.
                              I have not replaced either of these caps on the input side as they were not bulging, only the output filters. However, I have 160V which is roughly 1.4x 120VAC on the output of the bridge as well as across the 100uF.
                              PlainBill
                              I'm not sure about this... I posted pics of both side of the board earlier though.
                              The eye any better?
                              • PlainBill
                                • Feb 2009
                                • 7034
                                The eye any better?
                                The eye is fine.
                                This line of monitors is notorious for failing to power up when the two small caps on the primary side of the power supply fail. Caps in the 10 - 100 uF, 50 Volt range won't bulge when they fail. And what is the part number of the SMPS controller - the 8 pin SMT IC on the bottom of the board in the power supply error?
                                PlainBill
                                • A Man
                                  • Jun 2010
                                  • 39
                                  #156
                                  PlainBill
                                  My mistake... I actually did replace the two small 10uF 50V and the two 100uF 25V electrolytics. They are oriented correctly. I did not replace the large 100uF 400V nor the small 47uF 50V caps just to the right of the large one.
                                  The 8 pin IC is a 20306.
                                  • Scenic
                                    o.O
                                    • Sep 2007
                                    • 2640
                                    the large primary cap (100uF 400V) usually doesn't fail, but the 47uF 50V is most likely one of those plainbill was talking about.
                                    when those dry up, the powersupply (usually) just won't start up. even if everything else is OK.
                                    • A Man
                                      • Jun 2010
                                      • 39
                                      #158
                                      My mistake... AGAIN!
                                      Upon a closer inspection, it is a 203D6 PQGE
                                      I just replaced the 47μF 50V cap and it's still dead.
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        That would appear to be a NCP1203D60R2. Points to check. Pin 4 should go the the - lead of the large cap. Pin 8 should go to the + lead of the large cap - possibly through a resistor. Pin 8 should go to the gate of the power FET. Verify those, please.
                                        PlainBill
                                        • A Man
                                          • Jun 2010
                                          • 39
                                          #160
                                          PlainBill
                                          Yes, pin 4 is on the ground side of the cap and shows continuity. Pin 8 does go to + of the cap through two 23K SMT resistors. When I connect power, I have 16V at this pin. However, I believe pin 5 (not 8) is the driver output for the FET according to the datasheet schematic I attached. But hey, I''ve never done any of this kind of troubleshooting! ... I work on natural gas compressors lol. Anyway, looking at the datasheet for the 7N60B FET, I believe the gate is the pin I circled in blue. I'm having a hard time physically seeing a connection to pin 5 through all of the SMDs but ohming to pin 5 of the SMT IC, I get 10.2 ohms.
                                          We are making progress, right?
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • lostone
                                            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                            by lostone
                                            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                            05-19-2024, 11:40 AM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • eccerr0r
                                            A modified sine wave inverter + a grid tie inverter?
                                            by eccerr0r
                                            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                            Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                            08-31-2023, 09:14 PM
