LG W1942S won't backlight, but LCD is OK
  • amach
    • Dec 2012
    • 25
    • Greece
    After few years of calm, another LCD screen failed on me. An LG W1942S monitor needs my attention and repair. But I need your help, once more.
    I hope the photo are acceptable.
    SUMMARY
    This is a LG W1942S made probably in 2008. The backlight won't power on, at all. The LCD matrix shows the (faint) computer vga signal alright. When I press the power button the power LED turns blue, as normal. The rest of the buttons and menus seem to work.
    THINGS TESTED
    1) Measured steady 164V DC across main filter capacitor.
    2) With the power & logic board connected, the secondary voltages 5V, ON (3.3V) and M/S (3.3V) DC are present at connector location P201.
    3) Fuse FB101 & F101 on power board reads 0.1 ohms.
    4) All capacitors seem fine, apparently no bulge, cracks or fluid.
    5) Transistor U201 pins:1,2,3 measure 1-3 kOhm between them, seems OK
    6) High voltage transformer T301: primary winding gives 0.3 ohm, secondary1 1020 kOhm, secondary2 1020 kOhm, considered OK
    7) On the back of the power board, MOSFET U303 (type AP4525GEH) measures:
    S1-G1 OL
    S1-D1 2.5 MOhm falling
    G1-D1 3.5 MOhm falling
    S2-G2 32 ohm
    S2-D2 2.5 0.1 ohm
    G1-D1 32 ohm
    This doesn't seem normal to me.
    PROBLEM
    1) The backlight won't turn on, at all.
    2) The high voltage transformer buzzes like crazy when powered on.
    QUESTION
    Is MOSFET the primary suspect? Is there any conclusive test I should try?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG W1942S won't backlight, but LCD is OK
    Ahh its either a failed transformer which is very common or failed CCFL lamp. Unplug the lams does the buzz continue then go away ? Also check mosfet out of circuit.
    • retiredcaps
      • Apr 2010
      • 9271
      S2-G2 32 ohm
      S2-D2 2.5 0.1 ohm
      G1-D1 32 ohm
      QUESTION
      Yes. Desolder and measure the mosfet again to ensure it is shorted.
      --- begin sig file ---
      --- end sig file ---
      • amach
        • Dec 2012
        • 25
        • Greece
        Just tried this. With CCFL lamps unpluged one at a time the buzz won't go away. I have noticed, it starts for a second, mutes for one more, and then restarts buzzing without end.
        I need some time to desolder the mosfet to check it out of circuit.
        Thanks for directing me on this.
        • retiredcaps
          • Apr 2010
          • 9271
          BTW, there is some solder splash by Q302 (backside) that you should remove. It if comes free, it can cause a short.
          • fzabkar
            • Mar 2009
            • 772
            Just in case you need service info ...
            http://www.jordansmanuals.com/Defaul...r&Model=W1942S
            • amach
              • Dec 2012
              • 25
              • Greece
              Sorry for the delay, I had been away for the weekend.
              @retiredcaps I cleared the the backsides' solder splash by Q302. See photo.
              @fzabkar thanks for the links.
              I 've just desolder mosfet U303 (4525GEH), with some difficulty, i.e. little burned finger while touching the neiboghring large ground pad! Not really skilled on this task.
              Off-circuit dmm measurements:
              S1-G1 OL
              S1-D1/2 OL
              G1-D1/2 OL
              S2-G2 31 ohms
              S2-D1/2 0.3 ohms
              G2-D1/2 31 ohms
              Does it mean it is dead?
              I 've also tried following this guide http://itrepairguide.com/how-to-test...th-multimeter/ however I cannot conclude which part of the chip pins is the N-Channel and which the P-Channel.
              How can I definitely test the functioning of the this fet?
              • fzabkar
                • Mar 2009
                • 772
                MOSFET #2 in the package is shorted.
                AP4525GEH, Advanced Power Electronics Corp, N AND P-CHANNEL ENHANCEMENT MODE POWER MOSFET, 40V, 15A and -40V, -12A:
                • amach
                  • Dec 2012
                  • 25
                  • Greece
                  Unfortunately I can't source this smd mosfet, locally. Greek suppliers have a policy of minimum order of 10 pieces at 6 euros each!
                  On the other hand, ordering from abroad is blocked due to current capitol control on Greek banks. Buying on Ebay (& paypal) is impossible, as money cannot be transferred abroad, even involving few euros.
                  I've hit a wall here.
                  Is it possible to use common through-hole transistors/diodes combination to replace this item?
                  • selldoor
                    Slow Learner
                    • 7870
                    Will these people only sell 10? I can put 1 in my basket and they are in athens
                    http://www.markidis.gr/product_info....ducts_id=45425
                    • amach
                      • Dec 2012
                      • 25
                      • Greece
                      You are right, I have already tried that. But talking to him on the phone reveals that, actually, there is no stocked item. Minimum order from abroad applies here, too, similar to any other (inland) supplier I have come to contact with.
                      Thanks for your interest, though.
                        • 31248
                        you people need to organise a revolution or an OPEN election.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          Get a friend outside Greece to buy and pay for it and then mail it to you. You can then send them paper money in the mail.
                          Alternatively, if someone has an Amazon account, they can buy it and send it to you as a gift. I know I can buy something on amazon.com (USA) and have it shipped to friends in the USA even though I live in Canada. As long as I pay for it, amazon will ship it.
                          • amach
                            • Dec 2012
                            • 25
                            • Greece
                            I finally managed to secure an AP4525GEH from spain on ebay. I'll post when I receive, test and solder it.
                            A friend working in a bank tipped me that some categories of electronic parts are exempted from capital controls. There is no consistency though, and in my experience on ebay, it is a matter of trial-and-error.
                            The revolution will have to wait.
                            • amach
                              • Dec 2012
                              • 25
                              • Greece
                              Finally, I replaced the faulty mosfet with a new one bought on ebay. The P-channel tests fine now.
                              Not being skilled on soldering, I post a few close-ups for you to comment on.
                              The backlight now comes on and the screens works as seen on the last photo. No buzzing transformer as well.
                              Congratulations!
                              Thanks to all the forumers who contributed to this thread, especially selldoor who offered to help sourcing the mosfet.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                It isn't the greatest, but as long as it works, it is not a big deal.
                                There are lots of soldering tutorials online (including eevblog 3 part one) and with more practice you will get better.
                                https://www.youtube.com/watch?v=J5Sb21qbpEQ
                                • triplefour
                                  by triplefour
                                  09-13-2023, 10:43 PM
                                • DanPoka
                                  Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                  by DanPoka
                                  I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                  Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                  This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                  02-15-2025, 05:05 AM
                                • Comp_Pro
                                  No Backlight Macbook A1990 820-01041
                                  by Comp_Pro
                                  Hello all,
                                  Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                  Tests performed:
                                  There is no backlight even with a good screen.
                                  Backlight IC is receiving the correct support voltages.
                                  Fuse F8400 ok
                                  Current sense resistor R8400 ok
                                  Backlight IC is receiving 3.3V on enable pin.
                                  Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                  Backlight IC receiving 5V from PP5V_G3S
                                  Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                  I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                  05-06-2024, 10:23 PM
                                • cheebster
                                  iPad Pro 12.9 5th Gen Backlight Issue
                                  by cheebster
                                  Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                  Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                  Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                  The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                  Anyone...
                                  05-20-2025, 09:17 AM
                                • canadaboy25
                                  LG Flatron 24EN33TA No Backlight When Cold
                                  by canadaboy25
                                  I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                                  I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                                  03-07-2023, 12:23 AM
