LG FLATRON W2240T-PN Backlight works only for 1 sec.
  • BeginnerLVL1
    • Apr 2015
    • 58
    • Czech Republic
    i have lcd monitor LGFlatron W2240T - PN, on this LCD backlight light-up only for 1 sec.
    Please help me.
    I tested capacitors - OK
    Voltages is OK
    Mosfets - OK
    CCFL Tubes - OK
    HV Transformerc - i cant test it
    Invertor power on signal is ok, when i disconnect inv. ON signal an connect it back it lights up for another second.
    Thanks for any help
    Re: LG FLATRON W2240T-PN Backlight works only for 1 sec.
    How did you test the CCFL tubes?
    Did you use test tubes to verify the board function?
    https://www.badcaps.net/forum/showthread.php?t=19987
    • BeginnerLVL1
      • Apr 2015
      • 58
      • Czech Republic
      Yes i tried to connect another new tubes.
      • BeginnerLVL1
        • Apr 2015
        • 58
        • Czech Republic
        No way. I cant find whats wrong. Have someone service manual?
        • BeginnerLVL1
          • Apr 2015
          • 58
          • Czech Republic
          Hello, i have now two pcs of these monitors with the same failure.
          I think its bad transformer for ccfl tubes.
          When i cut-off inverter protection it works, but the transformer heats up rapidly.
          I leave for test one monitor running for 30mins, transformer gonna melted.
          May i buy 2pcs of this? http://www.ebay.com/itm/IT-011-EBJ42...-/151287502952
            • 31102
            check any high-voltage ceramic caps around the transformer & tube connectors.
            • BeginnerLVL1
              • Apr 2015
              • 58
              • Czech Republic
              Thanks, I try it here is 4x 3kV 10J, all of them is OK, tested with capacity tester.
              I tested windings on the transormer, primary has 0,3Ohm and secondary1 has 1kOhm, secondary 2 is probably bad... It has infinity resistance.
              Look at pictures, secondary2 looks burned.
              • BeginnerLVL1
                • Apr 2015
                • 58
                • Czech Republic
                But why is the transformer gone?
                • canadaboy25
                  LG Flatron 24EN33TA No Backlight When Cold
                  by canadaboy25
                  I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                  I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                  03-07-2023, 12:23 AM
                • Stephen
                  A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
                  by Stephen
                  Hello, got a weird MacBook Air here
                  board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works...
                  08-23-2023, 09:12 AM
                • zaurus81
                  Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                  by zaurus81
                  This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                  The board is equipped...
                  01-16-2025, 03:54 AM
                • vf fa
                  EIZO CX270 - No signal but Backlight and Panel works, logo works, admin menu works. OSD doesn't. What?!
                  by vf fa
                  Hi, so i guess I´ll have to make a new topic here, as i browsed through hundreds of other threads but couldn't find a solution to my problem yet.
                  I got a EIZO CX270 from a friend. He said it doesn't work anymore and wont display any signal or take any OSD inputs. Well, as an aspiring photographer I couldn't say no, could I? Thought it was an easy game, replace a bad cap and have a working monitor. But nooope, it wasn't supposed to be this easy.
                  So let me start with the problem description. I'll try my best not to skip anything so this might get rather long.
                  01-31-2024, 01:40 PM
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
