920NW 2 seconds backlight then off
+ More Options
Posts
  • paulstef
    • Dec 2013
    • 724
    Power supply is good. voltages stable. The CCFL chip turns off because when TIMER (pin3) ramps up to 3V VSENS is lower than 3V. As described on page 6 of the datasheet of the chip: http://monitor.espec.ws/files/oz9938_140.pdf
    VSENS goes up to 1V max, therefore I assume the high voltage is about 1.5kV (?)
    Question : Can this be caused by a defective CCFL and if so did anyone disable this protection or modify the circuit to use it anyway? I mean I do have backlight for 2 seconds...
    manual: http://galaxybrain.ru/files/Samsung_...ster_920NW.pdf
    Frankly I do not know how CCFLs usually behave when they are damaged.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: 920NW 2 seconds backlight then off
    Do you have any spare bulbs -another monitor- even a dead laptop.
    Can you make a or a couple of test bulbs from cfl - see in Budms signature
    EDIT have you done other tests in the 2 seconds to black guide at the top of this forum
    • paulstef
      • Dec 2013
      • 724
      I may try that... Not really keen to replace bulbs though. :-/
      • paulstef
        • Dec 2013
        • 724
        @selldoor, you mentioned the Budm signature link but as far as I can see he used CFLs? Since here it seems I have about 1.5kV does that mean I have CCFLs? Or how could I be sure?
        I'm assuming a CFL would have a low resistance due to the filament, is that right?
        What do they use in LCD TVs? I have several lying around with cracked screens... But what about their wattage?
          The filament of the CFL is not being used to heat up the CFL, it is used to supply the connection only, the high voltage from the inverter is high enough to excite the CFL.
          • paulstef
            • Dec 2013
            • 724
            Do CFL and CCFL work with different voltages? I read the filament in the CFL heats up to 900F, and to 200F in the CCFL.
            If I take any other bulb as suggested by selldoor and take a CCFL instead of a CFL by mistake will I blow up anything else?
            I thought TVs use CCFL not CFL as backlight...
              CFL needs to have the filament heat up to start the conduction, the CCFL use really the high Voltage to start the conduction.
              LCD TV and monitor use CCFL, CFL is only used home lights.
              Like I said we are not using the filament in the CFL, the filament is being as an electrode for the high voltage for the test lamp.
              https://www.badcaps.net/forum/showth...er+testing+cfl
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                Monitor has ccfl if you can find a broken tv with 18-20 inch screen or less
                you could try the tubes. Bigger will probably be too big and damage the
                inverter transformers.
                Sometimes EEFL bulbs are used.
                The CFL is only a temporary test bulb you do not need to think about it, just make one and try it.
                It does not work the same as when it is a cfl bulb the filaments do not need to heat. Really you are just using the actual fluorescent tube bit- when you connect the inverter transformer it just causes the bulb to fluoresce.
                • paulstef
                  • Dec 2013
                  • 724
                  Hum, I only have +42" LCDs.
                  I assume this test is to determine if CCFL or inverter is the culprit?
                    The use of the two test lamps is to find out if you have inverter problem or the lamps problem, it saves me lots of troubleshooting times.
                    • DanPoka
                      by DanPoka
                      02-15-2025, 05:05 AM
                      Design of CCFL Backlight Inverters with Frame & Bar Cores
                      Summary
                      Portable devices, such as notebook computers and personal digital assistants are developed rapidly nowadays, which places an increasing demand on display technology. The LCD with cold cathode fluorescent back lighting satisfies the requirements on display performance, size and efficiency.
                      The backlight inverter plays a crucial role in supplying the power to the lamps of these flat-panel displays.
                      The frame and bar ferrite cores, described in this brochure, are especially designed...
                      10-07-2024, 04:26 AM
                    • triplefour
                      by triplefour
                      09-13-2023, 10:43 PM
                    • Pygo86
                      Liyama G-Master GB3466WQSU-B1 - Backlight on - Shutdown after a few Seconds
                      by Pygo86
                      Hey Folks,
                      i'm not far into Monitor troubleshooting. It's my first time. Normaly i try to repair Laptops.
                      The Monitor is powering up. And the Backlight turns on. After a few Seconds the Backlight shuts off and the Power LED turns form Blue to Red.
                      I can power it up again, but it's always the same Result.
                      No Matter which Connection is used.
                      I can't see anything obvius after disassembling. No Heatspots with the Thermalcam visible.
                      The Powerboard is looking great. There is 12V and 5V everywhere on the Logicboard.
                      So, i decided to swap that Logicboard....
                      03-04-2024, 11:38 AM
                    • ttmi100x
                      HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                      by ttmi100x
                      Greetings everyone,
                      I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                      The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                      Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                      Upon closer inspection...
                      07-31-2024, 06:36 PM
