Another Dell 2005 FPW
  • Nightwolf
    • Mar 2015
    • 52
    I have another Dell 2005 FPW monitor with this problem. It has vertical lines thru out the screen. It not that the pic is blurry, but I took a small movie of the screen then took a screen shot of it. At least the screen comes on on this one. Maybe between the 2 I can make at least one of them work. Have not taken this one apart yet. Wanted to get some ideas first.
  • jasonbay13
    • Jul 2014
    • 185
    • usa
    Re: Another Dell 2005 FPW
    that sounds like it could be the ribbon cable or logic board.
    you said you had two of the same monitor, but the other one does not turn on?
    you could, if they use the same internals swap the power board with the one that doesn't turn on, and might have yourself one of them working.
    • Nightwolf
      • Mar 2015
      • 52
      The other monitor can be found here.
      https://www.badcaps.net/forum/showthread.php?t=44876
      • selldoor
        Slow Learner
        • 7870
        I would do it the other way round= as this screen is sort of working then the boards must be sort of working- so try the screen off the other monitor on these boards.
        Did you have a known working source connected to the monitor
        • Nightwolf
          • Mar 2015
          • 52
          Yes tried on 2 different systems
          • Nightwolf
            • Mar 2015
            • 52
            OK I used the invertor board from this monitor and the main board from the other monitor and this is what I get now.
            View My Video
            Any thoughts?
            • TechGeek
              Computer Geek
              • Jan 2015
              • 2254
              I'd swap the PSU's from both of these monitors.
              Permanently Retired Systems:
              Kooky and Kool Systems
              sigpic
              • Nightwolf
                • Mar 2015
                • 52
                The one is bad, see first post. Inverter is bad on the other one.
                • Nightwolf
                  • Mar 2015
                  • 52
                  Well I started trying to adjust brightness and contras and it has stopped making the arcing sound in the lower left hand corner and the screen is solid! Put it all back together and turned it back on and it was flicking just a little but went away in just a couple min. I'm thinking bad solder joint maybe?
                  • Nightwolf
                    • Mar 2015
                    • 52
                    Now on to the 1905 and 1907 monitors!
                    Thank you all for your help!
                    • TechGeek
                      Computer Geek
                      • Jan 2015
                      • 2254
                      Maybe get the arcing noise back again and then check where it's coming from, and then reflow the solder joint.
                      sigpic
                      • Nightwolf
                        • Mar 2015
                        • 52
                        It does it when it comes out of screen saver when its been off for more than 1 hour but stops after a few min.
                        • TechGeek
                          Computer Geek
                          • Jan 2015
                          • 2254
                          It's still a good idea to pinpoint the joint and reflow. Could you trace it?
                          sigpic
                          • Nightwolf
                            • Mar 2015
                            • 52
                            Have to take it apart again to do it.
                              Do you smell OZONE! it sounds like bad solder joint at the end of the lamp.
                              AM radio is good for listening for arcs.
                              • Nightwolf
                                • Mar 2015
                                • 52
                                I don't smell anything and it flickers about 1 to 2 min then screen is great! It sounds like it's coming from the lower left hand corner of the screen.
                                  I would say you do have bad connection at the end of the lamp.
                                  • Nightwolf
                                    • Mar 2015
                                    • 52
                                    Those are inside the display panel correct?
                                      Yes.
                                      Typical bad wiring:
                                      http://s807.photobucket.com/user/bud...?sort=3&page=1
                                      is this same one you have?
                                      It uses six lamps!
                                      Look at the corner back side of the screen to see if there is any signs of problem in that corner of the screen.
                                      20" monitor may not be worth fixing, but you do have one bad screen that you can take apart, right? The one with bad lines does not make arcing noise, correct? otherwise you can swap the LCD glass panel to the with good lamps.
                                      • Nightwolf
                                        • Mar 2015
                                        • 52
                                        This is the one that had the lines through it. I put the other main board in it. Your second link is the one that was in the other display, both displays have 6 lamps, transformers has 6 leads on one side and 2 for the output side. This one, the transformers have 4 leads on one side 2 on the output side. I'm thinking I tried both screen and the other one flickers then goes out. Hope you followed all that. LOL
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • Swedishpower
                                          Dell G3 15 3500 black screen
                                          by Swedishpower
                                          Hello
                                          I have search everywhere for a solution for my problem, but cant find it anywhere.
                                          When I was away to trow some garbage i always look in the electronic bin.
                                          and this time i find a laptop.
                                          Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
                                          the lamp for charmig is white.
                                          Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
                                          but no Dell logo.
                                          I tryed with a hdmi cable to another screen, still black.
                                          I started to search solution and tryed...
                                          07-06-2025, 06:18 AM
                                        • jake-b
                                          dell e6540 boots to black screen (no dell logo)
                                          by jake-b
                                          good morning all,
                                          i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                                          01-08-2024, 10:29 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • hcinne
                                          Dell G15 ryzen edition black screen 2 amber 1 white
                                          by hcinne
                                          I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                                          07-23-2024, 07:56 AM
