Dell 2005 FPW 2 and power flashing
  • Nightwolf
    • Mar 2015
    • 52
    I posted this in an old post and guess no one sees it any more, so posting a new thread.
    The monitor when first turned it on, the power lamp and the number 2 flashes on and off. Opened it up and unhooked the four cables going to the inverter, plugged it in and they didn't flash any more and I had all the voltages, 5 on the pins, 12 on the pins and 3.3 on pin 10. Connected the inverter plugs and they flash again. Monitor back light flashes on and off with the 2 lamps.Disconnected the cables again and how the 2 lamps are flashing. Reading across the caps in front of the inverters, I get between 5.7 and 5.8 M.
    Any direction from here?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4951
    • New Zealand
    Re: Dell 2005 FPW 2 and power flashing
    Can you post some photos of your boards and show where you are measuring these voltages?
    I don't know what you mean by "The number 2 flashes on and off" etc. Please explain or take a video?
    -David VanHorn
    • Nightwolf
      • Mar 2015
      • 52
      This is where I measured the 3.3 volts.
      Both boards.
      5 and 12 volt measurement
      Flashing number 2 light.
      I believe the number 2 is input 2. That and the power light both flash on and off.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4951
        • New Zealand
        When the lights are flashing, are the power rails steady or do they fluctuate?
        -David VanHorn
        • Nightwolf
          • Mar 2015
          • 52
          The 5 and 12 are steady, but the 3.3 fluctuate.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4951
            • New Zealand
            How much is it changing by? Does it change in time with the lights flashing?
            Could be your 3.3v regulator is bad or there is a short on that rail. Can you locate the 3.3v regulator on the logic board?
            -David VanHorn
            • Nightwolf
              • Mar 2015
              • 52
              Yes it does with the lights turning on and off. Re-read my first post about the lights.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4951
                • New Zealand
                Yes, but what I mean is, does the 3.3v rail change in voltage in time with the LEDs flashing?
                eg: If the LEDs flash once a second, does the 3.3v rail fluctuate once a second too?
                And can you measure how much it fluctuates by? Does it drop to 0v and go back to 3.3v again or what?
                -David VanHorn
                  https://www.badcaps.net/forum/attach...2&d=1426365626
                  Is the on/off (Backlights ON/OFF command pin) pin fluctuating?
                    https://www.badcaps.net/forum/attach...0&d=1426365626
                    "This is where I measured the 3.3 volts."
                    You are not checking the output of the 3.3V LDO regulator IC?
                    It looks like there are 3 LDO regulator ICs on the logic board.
                    • Nightwolf
                      • Mar 2015
                      • 52
                      Yes they are in time and from what I can see, the voltage goes up a little over 2 volts buts
                      it fast and the fluke isn't as fast.
                      • Nightwolf
                        • Mar 2015
                        • 52
                        Yes it goes from the power board to to the logic board. Schematics trouble shooting said that was a good place to check it.
                        • Nightwolf
                          • Mar 2015
                          • 52
                          Yes it is also. If the room is dark, you can see the screen flash on and off.
                          • Nightwolf
                            • Mar 2015
                            • 52
                            Readings on 3.3 volt regulators
                            U 608 output good.
                            U 610 output good.
                            U 612 pin 5 on and off 1.5 to 2.9 fluctuating. Input 3.3v-SW
                            Pin 1 0
                            Pin2 and 3 1.5 to 2.9 fluctuating
                            Pin 4 3.3v.
                            Pin 5 1.5 to 2.9 fluctuating.
                            Pin 6 3.3v.
                            Looks like 3.3v-SW goes back to R488 then to U402 pin AF9 GPIO_GO7_B<5>
                            Don't know what input to the display processor is controlling that output. Can't seem to find and info on the chip GM1501.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4951
                              • New Zealand
                              What is the part number on U612? Can you get a close up photo of it and the immediate area?
                              -David VanHorn
                              • Nightwolf
                                • Mar 2015
                                • 52
                                Here are close ups
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4951
                                  • New Zealand
                                  I don't see a voltage regulator there... Which one is U612?
                                  -David VanHorn
                                  • Nightwolf
                                    • Mar 2015
                                    • 52
                                    U612 is to the right of U609
                                    • Nightwolf
                                      • Mar 2015
                                      • 52
                                      Had to send it in to posts from the phone, mail is down on computer
                                        6-pin device U612 si3865, is the on/off pin fluctuating so the output will be fluctuating too.
                                        So need to find out why the control pin is going up and down.
                                        Do you have the link for the diagram or you can just upload it.
