benq gl2450 no power
  • gasinmars
    • Apr 2013
    • 53
    • israel
    i have a problem with this screen , when i plug it to the elecricity it doesnt turn on and the orange light beside the power button "turns on" all the time .
    bytheway i opened the screen and didnt see any blown caps but in the logic board the main chip is so hot .............
    could some one help me ?
  • gasinmars
    • Apr 2013
    • 53
    • israel
    Re: benq gl2450 no power
    any helppppppppppppppp
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      What voltage readings do you get ?
      • viziks
        • Mar 2012
        • 33
        • India
        In the component view of Powerboard the bottom right corner is scorched below which is a smd Mosfet.Check that for shorts and voltage on all 3 legs.
        When you press power switch does orange light switch off ?
        Seems the smd mosfet and or 16pin chip below it could be defective.These components feed the LED backlight of the panel.
        • gasinmars
          • Apr 2013
          • 53
          • israel
          yeah still orange color when i press it.
          so how could i messure the voltage of the 3 pins and what each pins should display in voltages ?
            Did you check the capacitance and the ESR of those 4 caps to the right of the main yellow power transformer? if those caps are bad, it can cause over heat problem.
            Bad caps can look normal.
            Also check the rectifier diode (I cannot read the designator of the Diode) that feeds the DC to those caps for the LED BACKLIGHTS Voltage booster circuit.
            • gasinmars
              • Apr 2013
              • 53
              • israel
              zoom in to the mosfet you will see that i wrote the voltages in the right side
              • gasinmars
                • Apr 2013
                • 53
                • israel
                here is the voltages
                • gasinmars
                  • Apr 2013
                  • 53
                  • israel
                  anyone could help me?
                  • konecma
                    • Sep 2013
                    • 7
                    • Czech
                    same problem, LCD in standby, voltage ok
                    Motherboard fail
                    • rddube
                      Aspiring Expert
                      • Jun 2013
                      • 931
                      You might want to read this thread, it's the large chip on the mainboard that is probably shorted.
                      https://www.badcaps.net/forum/showthread.php?t=67285
                      If you want to confirm it, check the resistance on the mosfet I circled in the photo which is 3.3v in and 1.8V out...i was getting approx. 80 ohms. I replaced that big chip twice to find out that it was the mosfet on the power board providing the 5 volts to the mainboard that was the problem. After I changed that mosfet on the power board AND the big TSUM chip, monitor came back to life....I also installed a small video card fan inside the monitor as it has a tendency to heat up.
                      If confirmed, you can either get a new board but change the mosfet on the power board first.
                      In my tinkering, I came across a board that had the same board number as mine but different monitor model number but I bought it. I arrived after I had fixed the monitor but the monitor was still open so I tried it and lo and behold, it worked! Didn't need it anymore, so I put it up for sale on Ebay http://www.ebay.ca/itm/202291559401?...84.m1558.l2649
                      • rddube
                        Aspiring Expert
                        • Jun 2013
                        • 931
                        Sorry, in my previous post:
                        should have read
                        on the power board providing the 3.3V to the mainboard.
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • grimacelord
                          HP 15-EH1070wm - Black Screen With Power LED.
                          by grimacelord
                          I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
                          First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...
                          01-28-2023, 10:50 AM
                        • joaquinmjuan
                          Canon TS8350 Screen Freezes on Power On
                          by joaquinmjuan
                          Hello, I have a Canon TS8350 printer. The problem is that when I turn it on, "CANON" appears on the screen, but it never goes away. You can leave it on for a whole day, and it doesn't go away. Does anyone know how to fix this? I've tried unplugging it, but nothing. I've also tried holding down POWER, but nothing. In fact, once it turns on, it can't be turned off with the Power button. I've also held down Power and then plugged it into the Power supply, and the power light flashes once and doesn't turn on, but then when I press Power again, it turns on. Currently, it's a nearly new paperweight,...
                          05-07-2025, 12:26 AM
                        • Alicat
                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                          by Alicat
                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                          Model number is TH-50PZ85U
                          Power comes on and the red power light stays on solid.
                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                          I also hear a few clicks.
                          I also think my parents said there was a thunderstorm and the TV failed after that.
                          Section 6 in the service manual talks about power and no screen,...
                          10-30-2024, 10:09 AM
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
