Hello, I have a Canon TS8350 printer. The problem is that when I turn it on, "CANON" appears on the screen, but it never goes away. You can leave it on for a whole day, and it doesn't go away. Does anyone know how to fix this? I've tried unplugging it, but nothing. I've also tried holding down POWER, but nothing. In fact, once it turns on, it can't be turned off with the Power button. I've also held down Power and then plugged it into the Power supply, and the power light flashes once and doesn't turn on, but then when I press Power again, it turns on. Currently, it's a nearly new paperweight, and I have no way to get it working. If anyone could help me, I'd appreciate it. I've looked for firmware, but I don't have it either. I have some machines for flashing micros or EEPROMs, but before I open it, I'd like to know if this has happened to anyone and how to fix it. Thanks!
Canon TS8350 Screen Freezes on Power On
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by grimacelordHello,
I have an HP 15-eh1070wm laptop that came to me for the same reasons I am starting this thread. The charging LED appears when the laptop power adapter is connected and the power LED appears when pressing the power button, but nothing appears on screen.
First thing I did was take off the bottom panel and remove the battery and then press and hold the power button for 30 seconds and then reinstall the battery and power on. The fan spins and this time, the back light illuminates and a brief message appears on the screen for about 1 second saying something along like,...-
Channel: BIOS Requests ONLY!
by AlicatHello,
Stopped by this site trying to fix my parents Panasonic Plasma TV.
Model number is TH-50PZ85U
Power comes on and the red power light stays on solid.
Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
I also hear a few clicks.
I also think my parents said there was a thunderstorm and the TV failed after that.
Section 6 in the service manual talks about power and no screen,...10-30-2024, 10:09 AM -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
Have had two Acer K272HUL monitors die with the same symptoms:
- Blue power light is illuminated while the monitor is plugged in
- Black screen (no splash screen, etc.)
- Power button doesn't do anything
Opened it up and checked for bad caps and components, evidence of burns, etc. - everything looks fine.
Power supply voltages are fine.
There are some signal lines on the power supply harness that goes from the power supply to the logic board, not sure what these should be at.
Anyone have any ideas?...-
12-09-2023, 10:22 PM -
- Loading...
