Re: Fix for Benq FP737s 17" (Q7T3)
Hi Everybody,
Thanks all of you for the useful postings which help me to repair a BenQ FP731.
It does not have any display with the green LED stays on.
Things done
1. Replaced fuse (BEL MS 3A), PF751 is open-circuit. I used a 2A pico fuse because I do not have a 3A fuse on hand.
2. Solder inverter transistors (2SC5707), Q739, Q740, Q759 and Q760. The solder cracked when I moved these 4 transistors.
3. Solder power MOSFETs (FU9024N), Q743 and Q751. The solder cracked when I moved these 2 MOSFETs.
4. Solder transformers, T751, T752, T753 and T754. No solder cracked, just re-solder to prevent dry joints.
5. After power on, left half of the monitor displays information correctly but right half has pink background with a continuous black line in the centre of the screen.
6. Remove the two flex-cables and clean the contacts (dirt found) with alcohol.
7. Power on and the monitor is in working condition.
Once again, thanks all you for the important information.
Have a nice weekend...Yong Seng
Thanks for the advice, and as far as the actual work of the board is concerned, I'm fairly confident on that score. In the past when I used to work for my living (now retired), I was for a few years in a data collection lab, and soldering strain gauges, some of which were only thirty thou long, and that included the two solder tags. So we had to work under a 30 to 1 microscope. I guess that's why I now need glasses. So like say the physical stuff I can deal with, it's the technical working of these modern electronics I know nothing about. It's all black boxes (Chips), and unless I know what each of these does and how it achieves it, I'm lost. So thanks for doing all the hard work, and I'll let you know once I've completed the task, if my confidence was well founded or not.
VicLeave a comment:
I feel I should add that to achieve the modification I describe you will need all the tools.
A soldering iron and self fluxing solder.
A PCB drill and bit 0.8 - 1 mm
A sharp knife to cut tracks.Leave a comment:
In response to a request for the final modification details
I have made this easy by posting the final versions at an online album here: http://picasaweb.google.com.au/davmax60/MonitorRepairs#
Use the full screen facility to see the detail.
Please note that there are two versions of current sense resistor, either a single resistor or two in parallel. Therefore the photo of the board underside shows the 0.082 ohm resistor version (alternately this resistor would be 0.56 ohm). The photo of the upper board shows the position of the 0.1 ohm resistor.Leave a comment:
Thanks, will look and see how to do that.
VicLeave a comment:
Originally posted by vicrowleyHi Dave,
I have recently been given one of these Benq 17” monitors, but only because it had died. I'm only an amateur dabbler in electronics, and I think I've just about been able to follow most of your circuit mods, and the reasoning behind them. Now I know from the dates on the posted articles, it was some time ago you were working on this monitor, but I was wondering if you now have a final definitive modification list, and final circuit diagrams. I ask this as reading through the various posts, you were obviously developing and changing things as you found new problems, and from reading through, it is hard to be sure I'm using your final solution for all the mods.
PS. I hope I've entered this in the right place, I'm new to this forum.
Vic
While the post is in the right place, you might want to PM davmax directly.Leave a comment:
Hi Dave,
VicLeave a comment:
Originally posted by BobdeeVery sharp, cant stop laughing, nice one
"You must replace the FU."
"Which one?"
"The one that is FU..."
Originally posted by KrankshaftHehe FU how ironic.
Think the component is telling you something?
Hehe FU how ironic.
Originally posted by diabolik_0newhile i been waiting your answer ..i try by my multimeter tester to measure and i found the fq11p06 short..so in this condition the backlights is always on , also the power button is off
i think to have the same problen in both monitor
well i hope to solved this problem ..and thank you very much for your helpLeave a comment:
Originally posted by diabolik_0nenow i repeir a benq model t905 i change two 5707 and the fuse 3 amp ....the Backlights now are ok and visualizze image ....but when i turn off to the power button....the Backlights still light on ....why?? if i turn off the monitor i cut the corrunt cable ...some help me please.
read this by Krankshaft it will help
https://www.badcaps.net/forum/showpo...&postcount=240Last edited by Bobdee; 05-31-2009, 10:17 AM.Leave a comment:
now i repeir a benq model t905 i change two 5707 and the fuse 3 amp ....the Backlights now are ok and visualizze image ....but when i turn off to the power button....the Backlights still light on ....why?? if i turn off the monitor i cut the corrunt cable ...some help me please.Leave a comment:
Originally posted by diabolik_0nethe lamp are light on... and the screen i see only white color if i connect the vga cable the screen to the pc i don't see any image i see only white colourLeave a comment:
Originally posted by diabolik_0nesorry for my last information it' no complete.....
i,ve just change the pico-fuse on mainb 3 amp. the lamp swicht on ,the screen only white colours....nothin image visualizze , i need to change other components??
but when the panel fuse is open the Backlights (lamps as you call them) do come on to give you white screen but no visual image,
So a dead panel fuse leaves you with white screen (lamps on) no imageLeave a comment:
i,ve just change the pico-fuse on mainb 3 amp. the lamp swicht on ,the screen only white colours....nothin image visualizze , i need to change other components??Leave a comment:
Originally posted by diabolik_0nehi, i have a benq monitor lcd fp737 , i've just change the some capacitor and the fuse,
now it swicth on but the screen is white, no image visualizze
i need help please
Also if that not problem check tiny fuse on panel (not much bigger than pinhead in most cases) that is under metal plate at top of screenLeave a comment:
i need help pleaseLeave a comment:
by x_orange90_xI just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
I don't know how exactly to test the inverter itself. Is it... -
by GentianI have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...03-06-2023, 07:07 AM -
by valvashonFor some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...1 Photo -
by eccerr0rIf I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
Next thing is trying to charge the batteries using solar power, but that's another issue ... -
by caseyjay_48I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,... - Loading...
