Troubleshoot a Dell 2209wa (will not stay on after flickering)
  • elagil
    • Oct 2013
    • 44
    Re: Troubleshoot a Dell 2209wa (will not stay on after flickering)
    As I said, the resistance of the rubber is relatively high. This is not a problem because there is a high voltage but low current. Consequently there is a low voltage drop across the junction of lamp an rubber. That is to say that you do no need to use a very low resistance material.
    Still silver is certainly the best conductor, followed by copper. Gold does oxidize the least. Just use copper coated with silver or tin. You can wrap the tube's wire with that other wire (should be thin). If it fails again you know where to look
    • selldoor
      Slow Learner
      • 7870
      #42
      I was wondering about the shielding that some cables have - I have used tv coax shielding as soldermop before. Only thing is that for the short length required it may unravel.
      Perhaps something out of an audio cable or datacable if you have any.
      Soldermop/solderwick is usually impregnated with flux so perhaps need to try and clean that before using for this?
      • elagil
        • Oct 2013
        • 44
        That might be even better. Flux indeed does not conduct well.
        • 3va41570
          • Nov 2016
          • Spain
          #44
          This post is quite all but I want to say I fount on it the problem of my 2209.
          I had the same issue with the bulbs and failing contact.
          I am attaching pictures might people help to solve their problems.
          I need to buy a replacement for my bulb and I am considering in buying somehow based on led lamps....
          http://www.ebay.es/itm/490mm-LED-Bac...-/281750783944
          Can you assist me in order to buy a replacement please?
          In the meant time the pictures of my reparation.
          Regards.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • openminded
            Dell G15 5510 troubleshoot non-working dGPU or disabling it
            by openminded
            hi,
            I have a Dell G15 5510 with an intel 10th gen 8 core and I believe a RTX 3060.
            I bought it as is and it seems to have had some liquid spill.
            Currently the dGPU is not shown in the BIOS and does not seem to work at all ( not in dev manager either ).
            Besides that, some keys on the keyboard don“t work, but it seems everything else is ok - works from power, battery, charges. etc.
            I found the schematic here : https://www.badcaps.net/forum/troubl...mobile-devices...
            08-26-2024, 03:49 AM
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
          • master3112
            by master3112
            07-29-2025, 01:55 PM
