Faulty Hanns-G HL272
+ More Options
Posts
  • terry
    • Oct 2007
    • 91
    • Milton Keynes, Bucks
    I have a Hanns-G HL272 27" monitor with a dead PSU. Can any one the me what this part is and where I can get a data sheet on it.
    Terry
  • terry
    • Oct 2007
    • 91
    Re: Faulty Hanns-G HL272
    Sorry here is the picture
      That is SMPS IC. What are numbers as printed on top? It looks like ????2136?
      • terry
        • Oct 2007
        • 91
        It looks like 722136
          Nothing I can find. Can you zoom out a little so I can see how it is connected to other section of the board?
          Also the pictures of whole board both sides.
          • terry
            • Oct 2007
            • 91
            Here are some more pictures, Thanks for your help.
            Terry
            • retiredcaps
              • Apr 2010
              • 9271
              What readings do you have to suggest IC1 is bad?
              Any secondary DC voltages or voltage across the big filter capacitor?
              --- begin sig file ---
              --- end sig file ---
                • 31111
                fuse looks too dark,
                flash-mark near R28
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Originally posted by stj
                  flash-mark near R28
                  Yes, I noticed that too, but forgot to mention it.
                    I would expect that the fuse is already been checked by the OP.
                    • Face275
                      • Sep 2014
                      My HL272;s backlighting has gone out and I'm having a heckuva time trying to do the simplest thing...getting the case open. There are only 4 measly screws along the bottom, but no others. I checked under the sticker in the middle...
                      ..how do you get the case off? I'm at an impasse without ricking snapping something.
                      • Face275
                        • Sep 2014
                        OK, I got it off...about broke the frame in the process....I was able to find another close-enough model here on these forums to help guide me.
                        • gschroeder
                          • Oct 2014
                          @Face275 I have the same issue with the same monitor. Any tips or pics of how to crack the case? I have done this many times with other monitors, but this one is tight and if there is a proper way to crack it I would appreciate any info.
                          Thanks1
                          • videodima
                            • Aug 2019
                            I'm going to reply here in case anyone in the future runs into this thread like I did just now 5 years later. Getting this thing off is simple but annoying. The screw on the back don't really do anything in this regard. You need to get a pry tool or credit card or flathead screw driver. and starting from the corners start slightly prying the outside front frame open. once you get it a little loose, you can just grab the frame with both hands. It gonna feel like its going to break but you need to yank it REALLY hard, and the corners EVEN harder.
                            Once you get the frame off to get the screen out simply use a flathead screwdriver and use the leverage to push it out. The rest is pretty simple. Do it slowly, you will be frustrated.
                            • Fagintheblagger
                              • Oct 2020
                              • Scotland
                              Good morning everyone, sorry to jump on this thread with another problem (Admins please move to the correct area if this is inappropriate) as I am a newbie lol.
                              I have stumbled across this forum while searching for help with a Hanns.G HL272 monitor that has suddenly gone very dim, you can only just see the picture.
                              I have successfully managed to open the monitor and have removed the PSU board upon doing this I have found that there is evidence of severe heating up around Semiconductor Q11 and diodes D22 & D23.
                              I am not sure of what Q11 does or indeed what type of semiconductor it is as I can't make out any identification on the component but it will need to be replaced.
                              Does anyone have any help they can give me on the dim display fault, my thinking is that there is an issue with the 12vdc supply for the LED backlights, if someone has a circuit diagram they could give me that would be a massive help too.
                              I will post pictures once I have fathomed out how to do it.
                              • Borse2008
                                Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                by Borse2008
                                Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                • There’s
                                07-15-2025, 04:55 AM
                                by momaka
                                03-15-2023, 10:17 PM
                              • paparazzo79
                                what's faulty monitor,cable,or graphics card on wake from sleep?
                                by paparazzo79
                                Hi friends.
                                I was having this issue since I purchased the monitor,but then again it maybe works like that.
                                Back at that time I didn't want to RMA the monitor due to covid and waiting toooo long for return.
                                So the monitor CJG50 32 " from Samsung has 3 inputs (DP+2HDMI).
                                I have 3 PCs hooked up to all 3 ports.
                                But only over displayport input monitor wakes up from standby and I do get picture.
                                Over both HDMI I had to manually select the source over monitor settings (OSD settings built into monitor).
                                Input source was selected to automatic by default in...
                                09-03-2021, 10:29 AM
                              • wattage
                                AOC AG493UCX 49-inch monitor - Firmware request
                                by wattage
                                Hello Badcaps Community,
                                The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                07-13-2025, 04:41 PM
                              • ant3202
                                HP 27es - LED monitor - Monitor Flashing On - Off
                                by ant3202
                                Hi Everyone
                                Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                https://www.badcaps.net/forum/troubl...lashing-on-off
                                The monitor is HP 27es LED Monitor
                                https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                The monitor will randomly blackout and display no signal and will recover again.
                                Sometimes need to power and off again to restore the display but...
                                03-20-2025, 07:30 PM
