Dell - ST2410 - Flickering screen light and dark
  • SkeeterUK
    • Jul 2014
    • 9
    Posted my problem in the New Members thread so ill just copy it to here.
    Hi im SkeeterUK. From the UK. I have registered with the site in hopes of some assistance with monitor repair.
    I have a dell st2410 monitor. It was flickering on the brightness. I suspected the cfl bulbs but was then told it could be bad caps inside. With it being unusable my monitor i thought why not and open it up to see if there was any.
    http://s1374.photobucket.com/user/Sk...slideshow/caps
    As you can see there wasnt but no buldging doesnt auto mean not a bad cap. I dont have a multimeter i dont know squat about electrics tho im good at pcs and building em. Anyhow, if it was bad caps i was gona get my cuson to solder new ones in if i could find out what caps was needed. Anyhow as pics, i duno if its caps afterall.
    Problem was, pink hue in the bottom left corner of the screen when viewing a all white screen like notepad open. When starting monitor it was all pink near the bottom not as bad on the top half but went away after 15 secs. This is from a cold boot. Later as of today. It was flickering light and dark. It wasnt too bad, then it stayed on longer and flickered more. Then once today it went black as if turned off (duno if it did turn in to standby or not cant recall color on power button) then came on about half a min later or somit.
    Anyhow, i cant post a new topic it seems, so any help would be appreciated.
    I had tried the 2 self tests dell told me without any cable in for the computer, still flickered, also tried vga and dvi cable both connecting to either onboard or dedicated gpu, still flickered. Was so bad i thought why not look at caps on it as someone at a different forum suggested it might be.
  • selldoor
    Slow Learner
    • 7870
    Re: Dell - ST2410 - Flickering screen light and dark
    Can you post good clear pictures of the power supply and main board
    Looking straight on , top and bottom. Post them using manage attachments
    jpg less then 3mb work ok.
    Pink tint suggests a faulty bulb as does flickering. Has it got many hours on it?
    • SkeeterUK
      • Jul 2014
      • 9
      Darn, ive put it back together now as i thought the pics in the link would have been enough.
      • selldoor
        Slow Learner
        • 7870
        Well, if it is bulbs you will need it in even more bits.
        • SkeeterUK
          • Jul 2014
          • 9
          I did try to access the bulbs but the thin frame bits around the actual lcd display was nerve racking so i stopped when i got up to a point where i thought hmm can i put this back together after i do this next bit...
          Little bit too far out of my comfort zone. The caps i might have managed with help from cuson to do the soldering but changing the bulbs i dont know if i can do it.
          • selldoor
            Slow Learner
            • 7870
            Ok - you may want to part it out then or sell as fault or try and buy one with
            a power supply fault.
            Something to try as you say the pink is predominantly at the bottom is
            to swap the leads to the bulbs over - That was one reason for the pics
            cant see them, anyway assume there are two one is usually for the top bulbs
            and one for the bottom so if you can swap them the pink should go to the top.
            If not then we can look elsewhere.
            Interesting to see two dells with a similar problem on here at the same time.
            • SkeeterUK
              • Jul 2014
              • 9
              Hmm link works for me, ah well here you are. Pics.
              • selldoor
                Slow Learner
                • 7870
                page doesnt exist that is the reason we ask for them to be posted using manage attachments
                • SkeeterUK
                  • Jul 2014
                  • 9
                  Pics updated in previous post.
                  • selldoor
                    Slow Learner
                    • 7870
                    Ok - talking at cross purpose, but thanks for those pictures - I was trying to say I cant see any
                    connectors for the lamps in the pictures not that I couldnt see the pictures.
                    Anyway assume there are two one is usually for the top bulbs
                    and one for the bottom so if you can swap them the pink tinge should go to the top
                    confirming a bulb problem.
                    • chozo4
                      Nothing Special
                      • 134
                      hmm, it could be a bad solder joint too. Inspect every solder joint closely on the through-hole components for a small hairline break around where the joints are soldered if there are any at all. Symptoms such as this can show poor functionality until the heat cycles causing on/off or variations thereof.
                      Just fixed a TV for a friend that wouldn't power on the screen at all and would exhibit power supply clicking. Was a bad solder joint at one of the transistors collector and fired right up upon fixing it.
                      This has some good examples on how to spot such a joint.
                      How to spot a dry joint, (fixing relay units or ecu)
                      http://mercedes-190.co.uk/topic/6581171/1/
                      and a video demonstrating it:
                      https://www.youtube.com/watch?v=9VYA9ufb4Jc
                      Even crap caps can be useful... such as blank rounds for prop gunfights.
                      • SkeeterUK
                        • Jul 2014
                        • 9
                        I tapped the top corner of the screen when testing the self test colors when dissasembled and the flicker went away. So i put it back together, it lasted about 3-4 hours and then the screen went off and wont stay on. When the screen is turned on it flashes up like its ok then immediatly goes black but i can see a faint image of it working as when i press the start button i can just about make out the menu pop up that comes with clicking on start button.
                        Swear tho that when i looked at the caps they were fine lookin and not buldging. What could it be, caps bad but looks fine? a transistor of sorts? inverter whatever that is?
                          These st series is cost cutting design using just 2 lamps instead of 4 lamps so the lamps are driven hard and they just fail. They are just bad series, only 2 lamps for 22" and 24".
                          This the 22" version:
                          http://s807.photobucket.com/user/bud...?sort=3&page=1
                          https://www.badcaps.net/forum/showthread.php?t=39282
                          • Lumberjack777
                            • 464
                            That was a very good point selldoor made. A pinkish hue on a white screen is almost always a CCFL (bulb) that is going bad. By swapping top and bottom connections the pink hue would move to the top and you'd know for sure.
                            I don't think this is a cap problem. I think its a bulb problem. You'll need to get a set of test bulbs, or make some.
                            EDIT: I see you still type faster budm. Glad to see we came to the same conclusion
                            • SkeeterUK
                              • Jul 2014
                              • 9
                              I tried awhile ago see if they could be switched the cables for the bulbs, but while one would go in the other one the other one couldnt reach the other port so no it wouldnt work as one cable was too small.
                              • selldoor
                                Slow Learner
                                • 7870
                                Well its probably too late now if the bulb was bad tapping it will have finished it off possibly
                                taking the inverter with it. Best option now would be to make up two of Budms test lamps
                                from household cfls and try with those. Instructions are in Budms signature on th ebottom of most of his first posts in any thread.
                                • SkeeterUK
                                  • Jul 2014
                                  • 9
                                  Thanks for your replies but i think its too far gone for me to mess with now, saw a £20 acer 22" x223HQ so got that today, it works, will do till i can afford a decent one once again.
                                  Again cheers for replying.
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    Perhaps you can sell it for spares/repairs whatever dont throw it away -offer it on
                                    freecycle or freegle - id have had a go at it if it was in my area.
                                    Some Acers are also prone to bad bulbs - in search above type in the model and see if anything comes up.
                                    • techgirl107
                                      • Sep 2014
                                      I'm looking to fix a Dell st2410b for a friend and in need of an IC. It's located in the top left hand corner of the main board. It has four capacitors around it. I have tested this part and it is bad. The only thing is, I can't locate this part from the numbers on it anywhere on the net. It looks like some kind of IC regulator. If someone knows exactly what part this is, it would be greatly appreciated if you would let me know.
                                      • Lumberjack777
                                        • 464
                                        If you could attach a nice closeup picture that would help a lot. I'm a little curious how you could test it unless you know what the part is. If it's a voltage regulator you'll need to know if its fixed or adjustable. Also, the capacitors nearby can go bad and never show any outward signs. If you could get us a nice closeup we might be able to identify the IC, and/or isolate the problem.
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • Swedishpower
                                          Dell G3 15 3500 black screen
                                          by Swedishpower
                                          Hello
                                          I have search everywhere for a solution for my problem, but cant find it anywhere.
                                          When I was away to trow some garbage i always look in the electronic bin.
                                          and this time i find a laptop.
                                          Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
                                          the lamp for charmig is white.
                                          Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
                                          but no Dell logo.
                                          I tryed with a hdmi cable to another screen, still black.
                                          I started to search solution and tryed...
                                          07-06-2025, 06:18 AM
                                        • Ado02
                                          Lenovo Thinkpad X1 Gen 10 - Flickering Screen
                                          by Ado02
                                          We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the Intel® Iris® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
                                          The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
                                          12-16-2024, 02:33 PM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • siuras676
                                          Dell XPS Plus 9320 blue screen and rebooting
                                          by siuras676
                                          I have a Dell XPS 9320 in for repair, and the machine has a strange issue.
                                          First, a bit of history: the laptop came in after liquid damage and was completely dead. I've repaired all the broken traces, replaced the damaged components, and it now powers on.
                                          However, it's now showing a Windows blue screen related to hardware (as seen in the picture), along with another Dell error I've never seen before.
                                          Has anyone encountered this issue on a Dell machine before and could point me in the right direction? I've checked the power rails around...
                                          04-07-2025, 12:10 PM
