Faulty Dell ST2210
  • Guest
    Faulty Dell ST2210
    So last night, (at about 2am or so) I found a random dell ST2210 lying beside a dustbin, so what the hell, I took it back home and powered it on and boy was I happy, I thought I got a free working 22" screen.
    So just now, I reconfigured my current setup (laptop beside 20" screen) to 22" beside 20" and laptop under the table. After much painful cable routing and re-routing, everything was ready to go.
    So I fired up the laptop and booted into my desktop. I immediately noticed that the whites on the Dell display were yellow-ish compared to the 20" LG beside it, so I calibrated the colours and stuff.
    I increased the brightness beyond 75% and the screen shut off. So I turn the switch off and then back on, the display was up again. after 10 mins (or so), it shut down again.
    So more searching on google tells me that there is a bad capacitor in there somewhere.
    After 1 hour of careful prying with my knife, I got the power supply and the main circuit boards out (the only boards in there anyway) and checked for blown/bloated caps - nothing
    So anybody has any ideas? I don't want this display to go to waste :P
    TL;DR
    My dell screen shuts down by itself after 10 mins of use, disassembly does not show me any bad caps on the circuit boards, any ideas?
    Thanks guys!
    -UPDATE-
    I got replacement caps and replaced everything on the psu board, still shutting down, any ideas?
    • 31316
    Re: Faulty Dell ST2210
    cfl tubes worn probably.
    btw - nice keyboard!
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Can you post good clear straight on pictures of both sides of the boards.
      When its gone off if you switch it back on does it come on straight away
      • Guest
        What tubes? O.o
        Its a cm storm tk, love it!
        The current picture on the main post the the board before cap replacement. I'll post new pics once I get back home later.
        When it goes off, it need to turn the main power off for half a minute before it lets me turn it back on. It also dies much faster on 100% brightness than 0%.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Tubes -- CCFL lamps in the panel - Reducing the brightness will help in short term
          There is another thread today on a Dell s2010 may have a similar problem but more developed.
          • Guest
            Can the tubes be replaced? O.o
            turning the brightness to 0% lets it run for 20 mins at best before shutting down
            • Guest
              Best I can do for the images, phone's camera focusing is a pain in the arse :/
              • Guest
                Back Side:
                Driver Board:
                PSU Board:
                  This model is known for having bad lamps, it uses only two lamps instead of 4 for the 22" so they are driven hard to get the same brightness as 4 lamps, cost cutting.
                  http://s807.photobucket.com/user/bud...?sort=3&page=1
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    Bulbs are quite difficult to replace - maybe the top one is in worse condition than the other
                    so try changing the cables around at the power board end and see if it makes any difference.
                    • Guest
                      I've always had high expectations for dell monitors :/
                      what do you mean by changing the cables around? O.o
                      Anyway, I did come across some lamps online some time back. Do you think I can replace the lamps? I've already spent some money on getting all the caps on the psu board replaced, I hope replacing the lamps will grant me another monitor to use :P
                      Also, the lamps are not all that expensive O.o Should I grab a spare pair incase I need to "reload" the monitor? or will the new lamps last me?
                        You should try using the test lamps to verify the inverter function.
                        https://www.badcaps.net/forum/showth...er+testing+cfl
                        • Guest
                          where would I get a test lamp from? ._.
                            • 31316
                            *if* you pull the lamps out and find how long they are in mm then you can look here for tubes or LED upgrade.
                            http://stores.ebay.com/lcd-led-parts
                              See the link on on post 12 on how to make test lamps.
                                • 31316
                                • Guest
                                  The placed I linked has the specific ones for this monitor.. also, it's possible to upgrade to led strips? O.o
                                  I don't happen to have a spare cfl lamp lying around :/ I do have an old viewsonic square monitor that has a busted panel but still turns on. Can I pull th e cfl tubes out of it and test the inverter using that?
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    There are two white sockets on the power supply that the lamps plug into.
                                    Take the plugs out and change them over.
                                    You do not need to take the bulbs out of your broken part
                                    just plug them in whilst still in the old panel
                                    • Guest
                                      what difference does swapping the plugs make?
                                      I already pulled them out, it's just one screw ._.
                                      • SteveNielsen
                                        Retired Tech
                                        • Jun 2012
                                        • 2327
                                        Yes, you can use the working tubes from the other monitor to test the inverter.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Borse2008
                                          Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                          by Borse2008
                                          Hi everyone,
                                          Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                          I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                          • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                          • There’s
                                          07-15-2025, 04:55 AM
                                        • master3112
                                          Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
                                          by master3112
                                          I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
                                          Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
                                          The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
                                          07-29-2025, 01:55 PM
                                          Dell Thunderbolt Firmware
                                          by SMDFlea
                                          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                                          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                                          The SKU is in brackets (****)
                                          EDIT: NVM65...
                                          01-26-2025, 06:22 AM
                                        • dell_sadness
                                          Dell Latitude 3440 - Service tag ending in 0001 - Locked!
                                          by dell_sadness
                                          BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
                                          Have extracted the BIN and want to know how to rebuild a clean BIOS
                                          I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
                                          I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
                                          Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
                                          11-12-2025, 02:54 PM
