I acquired three VG2230wm monitors which were malfunctioning or not working. I have repaired two by replacing bad caps.
The third works when it is fed an input signal. When the PC is shut down or goes to sleep the backlight flashed rapidly. It flashes even if turned off via the power button.
The power board is a Delta DAC-19M009AF if that helps. Any ideas on what the problem might be?
Thanks,
Vince:
Thanks,
Vince:
