Viewsonic VG2230wm backlight flashes when no signal - even if powered off
  • emailjunk2me
    • May 2014
    • 4
    I acquired three VG2230wm monitors which were malfunctioning or not working. I have repaired two by replacing bad caps.
    The third works when it is fed an input signal. When the PC is shut down or goes to sleep the backlight flashed rapidly. It flashes even if turned off via the power button.
    The power board is a Delta DAC-19M009AF if that helps. Any ideas on what the problem might be?
    Thanks,
    Vince:
    • 31090
    Re: Viewsonic VG2230wm backlight flashes when no signal - even if powered off
    i saw something like this once.
    does it use a seperate invertor, or is it on the psu?
    the prblem i saw was a transistor controlling the BL-ON signal was leaky and turning itself on.
    the result was the backlights never turned off.
    • emailjunk2me
      • May 2014
      • 4
      The inverter and power board are integrated.
      I was kind of thinking it might be something other than a capacitor....
      I have attached a pic of the board, if that helps...
      Vince
        • 31090
        any chance of a better pic of the lower right so i can read the writing next to the vertical board.
        also - the other side probably has the controller on it.
        • emailjunk2me
          • May 2014
          • 4
          Picture of the lower right attached.
          Also, I found the schematic, but it has been many years since I read one, so it looks almost foreign to me...
          What do you mean by controller?
          Thanks for your assistance.
            "What do you mean by controller?' The board which it has the VGA/DVI connector, that board is also plugged into the power supply board.
            • bammbammfran
              • Apr 2014
              • 476
              The backlight controller chip that I believe STJ wanted to see is the 20 pin chip under the power board
              connect the two boards and plug them in and then see what the voltage is on the pins that connect the two boards together.
              the two you want to check are the two that are closest to the center of that side of the board.
              one is the dim pin and the other is the on/off pin
              the on-off pin might be the one that is pulsing and trying to light the bulbs
                Per your SCH page 35, CN5 pin 15 is the Inverter enable pin (there are labels on the connector) you need to monitor the DC Voltage. <1V = backlights off, >2vdc = backlights on. See if the voltage is bouncing around when you turn off the monitor.
                http://s807.photobucket.com/user/bud...?sort=3&page=1
                BTW, there are more than one version of this model.
                  • 31090
                  suspect parts to check:
                  zd200
                  q200
                  q202
                  q207
                  • howardc64
                    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                    by howardc64
                    Failure Symptom
                    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                    Where is the short?
                    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                    05-27-2025, 02:56 PM
                  • JayPoorJay
                    Converting +/- 5v to a Usable Hz Signal
                    by JayPoorJay
                    Good morning.
                    I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
                    This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
                    The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
                    08-07-2022, 08:35 AM
                  • lostone
                    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                    by lostone
                    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                    05-19-2024, 11:40 AM
                  • cajoeg
                    Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                    by cajoeg
                    Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                    The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                    02-10-2025, 04:01 PM
                  • Scruit
                    What is a normal composite signal range for a C64?
                    by Scruit
                    Hello all,
                    Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
                    More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
                    https://imgur.com/gallery/PpqcqPY
                    My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
                    More detail:
                    Symptoms are that that I get...
                    04-28-2022, 05:33 AM
