LG Flatron L194WT inverter board; light flicker
  • uengin
    • Jan 2014
    • 32
    Here I have the board only from a an LG Flatron L194WT. When a friend gave this to me because it was playing up and I didn't have time to fix it nor did I want it taking up space, so I just took the inverter board and tossed it out. So, for a learning experience I'd like to fix it.
    Tied BL_ON high to 5V rail. Hook it up to known good CCFLs. CCFL light flickers and slightly fainted. Capacitors are SAMXON, no bulging evident but not always have to bulging. Voltage rails are all good.
    I know I can test component, but I don't want to start testing at random. Where to start trouble shooting?
    Thanks everyone.
    Re: LG Flatron L194WT inverter board; light flicker
    Post good clear pictures of the board, both sides, will be a good start.
    • uengin
      • Jan 2014
      • 32
      yeah, photos coming soon
      • selldoor
        Slow Learner
        • 7870
        You may need another jumper resistor from 5v to dim (if there is a dim pin)
        Test the secondary windings (Ohms 2000 range) on the inverter transformer/s
        • uengin
          • Jan 2014
          • 32
          Ok, here's the photos. I don't know if it's the lighting or what, had so much trouble getting focussed images. Probably because I'm using a Nikon, I much prefer the Canons... Anyway, that's another story.
          • uengin
            • Jan 2014
            • 32
            Ok, so there is a DIM line. Question is is it active high or active low? Pulling it high seems to me it will make it dim out? No?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4477
              • Italy - Milan
              Dim is not a digital signal, you have minimum brightness at 1,5v for example (i don't remember) and maximum at 3v so test which voltage you have with the resistor to 5v. Anyway i see there are output values printed near output connector, test those and compare to what's printed.
              • fixit007
                Samsung flicker - BN44-00932T board or else?
                by fixit007
                I picked up this TV that the prior owner said - just died.
                Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                05-04-2024, 06:14 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • lostone
                Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                by lostone
                Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                05-19-2024, 11:40 AM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
