Samsung flicker - BN44-00932T board or else?
This topic has been answered.
  • fixit007
    • Sep 2023
    • 8
    I picked up this TV that the prior owner said - just died.
    Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
    Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
    Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick as the input again. Tried unplugging, even factory reset, still flicker, but Firestick dropping out disappeared. Then turning on Fire stick - flicker, switch back to antenna, still flicker. Turn off with remote / on, antenna does not flicker. A few times like that. Switch to stick - immediate flicker. Lots of intermittent flicker.
    A member of the household starts watching a longer program after a bit of time - and no more flicker for now.
    This was a rather wet week around here, so probably in-house humidity came up to good 70%.My theory now is that something adsorbed moist - and now dried up.
    LED flicker seems to implicate the power board, but the HDMI input glitches are farther from the power board, although, they did happen as the screen turned dark.
    I don't see many components around the LED connector, so moist issues would likely happen in the connector itself. The first pic is the stock, the 2nd is my actual replacement board.
    With TV only used casually, attached to a wall, and having a clipped back cover, I'd probably just leave it for observation.
    But any thoughts what could be happening? If it's the connectors - I could probably clean them to avoid future corrosion. But how? i thought I seated the board fully and properly, but who knows ...
  • Answer selected by fixit007 at 05-05-2024, 01:09 PM.
    CapLeaker
    Leaking Member
    • Dec 2014
    • 8329
    Turn the backlights down to 70%. It shouldn’t flicker anymore. Probably a led going bad.
    • EazyBone
      • Jun 2023
      • 1354
      • United states
      Test backlights, use led tester and see if one line has less voltage use then the other. Need model of tv not power board. But I'm gonna say LEDs need testing
      • Storyteller12
        • Jun 2020
        • 625
        I agree with EazyBone. Sounds like backlights for sure. Unplug mainboard from psu and see if the lights flicker after sometime or stay on without issues.
        • fixit007
          • Sep 2023
          • 8
          Many thanks!!! Appreciate the ideas! So sounds like everyone is very positive its not the power board?
          Full TV model is this: UN65RU7300FXZA
          For now it does not flicker at all - so no point in testing anything, until it comes back.
          • EazyBone
            • Jun 2023
            • 1354
            • United states
            PSU, probably not. It's likely the backlights are going bad. If I were you I would change them before more damage is done to the diffuser which may have already occurred.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8329
              • fixit007
                • Sep 2023
                • 8
                Turn the backlights down to 70%. It shouldn't flicker anymore. Probably a led going bad.
                OK, great!!!
                For what the TV is used for I'll probably let it slowly die I guess. Sadly, while I waited for the power board, my little child decided to climb in the area, and dropped the TV on the carpet floor. It was a slow drop, by a drop nonetheless. No immediate damage, but I guess maybe latent one. Also, opening the backside was a bit of a harsh process - given all the clips.
                These are 1 time use devices - not repair friendly.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • ohren
                  Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                  by ohren
                  I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                  I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                  The models launched in 2018 and 2019 respectively....
                  09-08-2023, 05:24 PM
                • C152Heavy
                  Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                  by C152Heavy
                  Summary for TL-DR readers:
                  • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                  • Have obtained Samsung schematic & service documents - Can upload if helpful.
                  • Have read ALL applicable threads
                  • C1818 and CP820 replaced as low hanging fruit
                  • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                  • VCC pin (18) of PFC...
                  01-11-2023, 02:53 PM
                  09-07-2024, 05:50 AM
