BENQ FP91G+ problem
  • simke
    • Jan 2014
    • 5
    • Croatia
    BENQ FP91G+ problem
    I have problem with BENQ FP91G+ lcd monitor.Monitor won't to power up.
    When I plug in power cord in monitor I hear quiet whistling from back of the monitor,when i press power button on monitor whistling stops,screen is on for a moment with Benq logo and then turn off.Any help would be much appreciated.Thanks.
  • Davi.p
    Hobbist
    • Sep 2009
    • 4261
    • Italy - Milan
    Re: BENQ FP91G+ problem
    Is a well known fault, search the forum for the keys "Benq FP71g" or "C5707"
    • selldoor
      Slow Learner
      • 7870
      or just "FP91G"
      see here
      https://www.badcaps.net/forum/showth...ighlight=FP91g
        Check the C5707 transistors, solder joints on the transistors and inverter transformers. Check the black fuse PFxxx, it should be less than 1 Ohm.
        • mejohn
          • Mar 2015
          • 8
          • germany
          I got a very similar problem and exactly the same board! If I switch the monitor on, the green led lights up and for a fraction of a second I see the blue benq label on the monitor. Then the monitor is dead again.
          I already checked the black fuse PF801 and the LDO regulator on the logic board, there I measured to voltages 3.3V and 1.8V.
          I couldn't find the C5707, please give me a hint. The capacitors all look very good, none is curved or vented.
            Just to be sure, you need to upload good clear pictures of YOUR board for us to look at.
            • mejohn
              • Mar 2015
              • 8
              • germany
              Here you are. If you want specific pictures, please don't hesitate to ask.
                "I couldn't find the C5707"
                Q808, 809, 815, 816.
                These boards are know for having lots of bad solder joints in the inverter section (transformer legs, transistor legs, cap legs etc), and bad tuning caps (grey rectangular caps, lose its capacitance).
                • Lumberjack777
                  • 464
                  If I might add budm - I'd also check Q812 & Q805. I've had one of them go on occassion.
                  And resolder those transformer legs etc, as budm said, or it will happen again.
                  Here's a typical repair kit for similar models. http://www.ebay.com/itm/REPAIR-KIT-E...item54042beafc
                  • mejohn
                    • Mar 2015
                    • 8
                    • germany
                    I checked all components including the mosfets (Q805, Q812) and found that two C5707 are gone (Q808 and Q809). In approximately 4-6 weeks I get the parts from china and I am going to post the result.
                    Thank you very much!
                    • mejohn
                      • Mar 2015
                      • 8
                      • germany
                      Success! After replacing the two faulty c5706 and resoldering a lot of legs the monitor works fine again.
                      • theone111
                        by theone111
                        3. Problem: TV shuts down
                        07-22-2024, 10:36 AM
                      • Zeonalbasta
                        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                        by Zeonalbasta
                        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                        09-13-2024, 01:17 PM
                      • Gibon378
                        Problem with stopping audio and video for no reason
                        by Gibon378
                        PC Specs:
                        • CPU: Ryzen 5 1600
                        • GPU: GTX 1080 Palit JetStream
                        • MOBO: ASRock ab350 PRO4
                        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                        • PSU: XFX 650W (don't remember what model)
                        • OS SSD: ADATA SP920
                        • OS: Windows 10 21H2
                        Problem description:
                        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                        11-19-2022, 09:41 AM
                      • perzyk23
                        Lenovo T580 - LCD Panel problem - error 0288
                        by perzyk23
                        Good morning,
                        I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                        10-25-2024, 12:42 AM
                      • SDNarcia
                        Dell 15R-5521 keyboard problem (KBC?)
                        by SDNarcia
                        Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                        As additional information,...
                        07-20-2024, 10:47 PM
