I've got an Acer H243H monitor with dimm and flickering backlight and a hissing noise. I opened the box to see what it's all about.
The PSU + backlight inverter board, InnoLux ILPI 129 and similar, is found in quite a couple of OEM brands and models. There is no sign of burn or overheating what I can see. Just some white residue of what I thought must be soldering flux underneath the board but only in the lower voltage department. I could easily clean it with alcohol. The source of the hissing sound, however, appeared to be the high-voltage department of the board.
Using a piece of plastic tubing as a 'stethoscope' I localized the loudest spot of the noise right between the two transformers where the low-voltage sides meet. Underneath the transformers on the soldering side of the board there's a parallel group of three 2.2 uF ceramic capacitors (according to service manual) of which one was broken. I replaced it but it made no change. I also replaced the other two but no change either.
Then I applied an 'Isolating Sillicone Oil Spray' onto and underneath the transformers. A very bad idea I have to admit. The hiss got even louder and the inverter switches itself off after a few seconds.
I'm still trying to remove that sticky fluid with benzine and alcohol. It's not easy since it still keeps leaking from the transformers to the PCB. It appears to be somehow dielectrically conductive. I even localized a 'noisy hotspot' at an unpopulated area of the PCB close to the high-voltage lines. Guess I'll have to de-solder both transformers and boil them in benzine.
Is it worth all the pain? Aliexpress lists a pair of SPW-136 transformers for about $7.50 but China is 4-6 weeks away.
I had a look at the AUO M240HW01V2 LCD's specs sheet. The CCFLs should burn at 900V / 7.5mA which is equivalent to a 120kOhms load. So I connected four dummy loads each consisting of a couple of series and parallel resistors totalling about 120kOhms plus a little glow lamp as a voltage indicator. The noise stayed about the same but the inverter doesn't switch off itself no more. The glow lamps glowed dimmer than expected and the resistors only got about hand warm. Feels like much less than the calculated 7 watts.
I couldn't measure voltages or currents, my digital multimeter is a bit deaf at 50 kHz. I'll have to build an HF rectifier probe and connect it to the lowest series resistor.
I'll try to upload some pictures and keep you updated. All hints welcome.
Best regards,
Badhat
Best regards,
Badhat
